Strange compilation problem
lukyluke
PostPosted: Fri Feb 18, 2011 1:32 pm     Reply with quote
Hello!
I'm working on a very simple project with a 12F629 but I'm stuck in a problem I can't understand...
C Code:
#include "C:\ServoDecoder_PIC\servodecoder.h"
void main() {
   while(1) {
      output_bit(PIN_A0, !input(PIN_A0));
H Code:
#include <12F629.h>
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
#FUSES BANDGAP_HIGH
When I compile, here's the ASM:
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
0004:  CALL   3FF
As you can see, it calls the last (3FF) address of program memory and stops... do you see any mistakes in my H file?
If I remove #FUSES declarations, the assembly is ok:
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   018
0003:  NOP
.................... void main() {
0018:  CLRF   04
Thanks!
PostPosted: Fri Feb 18, 2011 1:41 pm     Reply with quote
What's your compiler version ?
lukyluke
PostPosted: Fri Feb 18, 2011 1:44 pm     Reply with quote
Hello
4.057, with a further investigation it seems INTRC_IO is the problem, if I change to XT (for example) the ASM generated is correct...
PostPosted: Fri Feb 18, 2011 1:57 pm     Reply with quote
It works for me. I installed vs. 4.057, and took your code and pasted it
into an MPLAB project as one program (no separate servodecoder.h file).
The .LST file doesn't stop at 0004.
CCS PCM C Compiler, Version 4.057, xxxxx       18-Feb-11 11:55
               Filename: 12F629_Test.lst
               ROM used: 55 words (5%)
                         Largest free fragment is 969
               RAM used: 6 (9%) at main() level
                         7 (11%) worst case
               Stack:    1 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
0004:  CALL   3FF
0005:  BSF    03.5
0006:  MOVWF  10
0007:  MOVLW  00
0008:  MOVWF  0A
0009:  GOTO   01E
#include <12F629.h>
#FUSES BANDGAP_HIGH
void main() {
   while(1) {
lukyluke
PostPosted: Fri Feb 18, 2011 2:03 pm     Reply with quote
thanks for your support... very strange I've just copy&paste your source code in my C file, and here's the result:
CCS PCM C Compiler, Version 4.057, xxxxx               18-feb-11 21.01
               Filename: C:\ServoDecoder_PIC\servodecoder.lst
                         7 (11%) worst case
               Stack:    1 locations
0000:  MOVLW  00
0001:  MOVWF  0A
0002:  GOTO   004
0003:  NOP
0004:  CALL   3FF
0
lukyluke
PostPosted: Fri Feb 18, 2011 2:11 pm     Reply with quote
mmm maybe I wasn't clear in my explanation: my ASM source doesn't stop at 0004, but the instruction at that address make a CALL to the last memory address (CALL 3FF) and the program stops (with a simulator or with a "real" circuit the led doesn't blink)
PostPosted: Fri Feb 18, 2011 3:35 pm     Reply with quote
OK, now I understand. Your problem is not with the .LST file. It's with
program execution. See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=27234
PostPosted: Fri Feb 18, 2011 3:44 pm     Reply with quote
And to explain 'why'. The chip's come from the factory, with a single instruction at address 0x3FF, 'preprogrammed' by the manufacturer. The instruction is a RETLW, returning a value designed to calibrate the internal oscillator. This is called the 'OSCCAL' (oscillator calibration) value.
Yours has had this value erased.
The thread PCM programmer points you to, shows how to put a 'mid range' value back into this location, but understand that the calibration will have been lost, so frequencies won't be that good.
For 'future reference', look into your programmer settings. there should be an option to 'save OSCCAL', or 'preserve calibration', and you need to select this, otherwise you will do the same to the next chip you try....
lukyluke
PostPosted: Sat Feb 19, 2011 4:55 am     Reply with quote
Friends,
Thanks for your suggestion and the explanation (very interesting, I never investigated about the OSCCAL feature): it worked fine and I was able to find - in my software - the flag to preserve the value at 0x3FF address when programming my HEX.
