kbd.c problem
glenjoy
kbd.c problem
PostPosted: Sat Jan 19, 2008 8:57 am     Reply with quote
How to connect the 4x3 keypad to a pic using the kbd.c, the code does not say which i/o is for the column or for the row.
Thanks.
PostPosted: Sat Jan 19, 2008 9:08 am     Reply with quote
Search the forum for kbd.c and you will find many posts on the subject asking the same question you are.
It is best to do a little re(search) in this forum before asking a question. A lot of questions have been asked (and answered) many times before. It saves a lot of time for everyone (including you) because reading the threads will gives you a wealth of information beyond just the connections. This way folks on the board don't end up answering the inevitable followup questions that have already been addressed.
glenjoy
PostPosted: Sat Jan 19, 2008 9:13 am     Reply with quote
Searched them and no answer regarding connections.
PostPosted: Sat Jan 19, 2008 10:47 am     Reply with quote
My post in this thread has an explanation of the keypad connections.
http://www.ccsinfo.com/forum/viewtopic.php?t=21852
Mark's post in this thread explains how to interpret the CCS #define
statements for the pin connections in kbd.c.
http://www.ccsinfo.com/forum/viewtopic.php?t=25488
Another thread with helpful information on the keypad connections:
http://www.ccsinfo.com/forum/viewtopic.php?t=23467
glenjoy
PostPosted: Sat Jan 19, 2008 8:52 pm     Reply with quote
How to choose from black or blue keypad?
I am trying to simulate in proteus but no luck.
PostPosted: Sat Jan 19, 2008 9:21 pm     Reply with quote
I don't want to work on Proteus problems.
ayman
help
PostPosted: Tue Aug 04, 2009 11:03 am     Reply with quote
I need a 4*4 kbd library in c language in c compiler.
PostPosted: Tue Aug 04, 2009 5:22 pm     Reply with quote
Please use the forum's search page:
http://www.ccsinfo.com/forum/search.php
Type this in the top box:
keypad
In the Search Options/ Forum box, set it to search this forum:
Code Library
You will get 8 hits.
The first hit has a link to a 4x4 keypad driver.
