what should I modify to kbd.c to use port C?
runtime
PostPosted: Mon Feb 14, 2005 6:43 pm     Reply with quote
Hello All,
Would someone please tell me what should be modified in kbd.c to use port C? (PIC18F252).
Thank you in advance
Peter
// Un-comment the following define to use port B
// #define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#if defined(__PCH__)
#if defined use_portb_kbd
   #byte kbd = 0xF81                   // This puts the entire structure
#else
   #byte kbd = 0xF83                   // This puts the entire structure
#else
   #byte kbd = 6                  // on to port B (at address 6)
#else
   #byte kbd = 8                 // on to port D (at address 8)
   #define set_tris_kbd(x) set_tris_b(x)
#else
   #define set_tris_kbd(x) set_tris_d(x)
//Keypad connection:   (for example column 0 is B2)
//                Bx:
#ifdef blue_keypad  ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
PostPosted: Mon Feb 14, 2005 7:55 pm     Reply with quote
The lines that you need to change are shown in bold below.
I'm going to let you look in the data sheet to see the register
address for Port C in the 18F252. The change to the 2nd
bolded line should be obvious.
Also remember that you need to put 4 external pull-up
resistors (10K) on the Row pins.
#else
#else
#else
#else
runtime
keypad connection?
PostPosted: Tue Feb 15, 2005 12:31 pm     Reply with quote
Hello PCM programmer,
I've already modified the 2 lines to:
#byte kbd = 0xF82 // This puts the entire structure
#define set_tris_kbd(x) set_tris_c(x)
would you please explain to me how to connect the keypad to port c?
I've already have the pull-up resistors, what I don't know is to which pins do I connect COLS and to which pins do I connect ROWS...
Peter
PostPosted: Tue Feb 15, 2005 12:38 pm     Reply with quote
Can you give the manufacturer and part number of your keypad ?
If you have a link to the web page, post that too.
I would like to look at keypad's connector pinout in the data sheet.
runtime
keypad info
PostPosted: Tue Feb 15, 2005 2:43 pm     Reply with quote
www.storm-keypads.com
Graphic Series
12 KEY PAD
Part No: GS120203
Contact Connections ('o' are pins, as viewed from rear of keypad):
o o o o o o o o
8 7 6 5 4 3 2 1
Key Location: ('o' are keys, as viewed from front of keypad)
A 1 2 3
B o o o
C o o o
D o o o
Contact Matrix:
Pin - Row Column:
1-A
2-B
3-1
4-2
5-3
6-Not used
7-D
8-C
Peter
PostPosted: Tue Feb 15, 2005 4:20 pm     Reply with quote
Let's assume that you wire the keypad connector to the PIC
in a 1:1 manner. That is, pin 1 on the keypad goes to pin C0
on the PIC, pin 2 on the keypad goes to pin C1 on the PIC,
and so on. This chart shows the connections:
 Keypad     Keypad    PIC     CCS signal   10K Pull-up
pin name    pin       pin       name        required
   A         1        C0        Row0         Yes
   B         2        C1        Row1         Yes
   1         3        C2        Col0         No
   2         4        C3        Col1         No
   3         5        C4        Col2         No
   -         6        NC           -         No
   D         7        C6        Row3         Yes
   C         8        C7        Row2         Yes
Then your bitmask statements would be:
#define COL2 (1 << 4)
#define ROW0 (1 << 0)
#define ROW1 (1 << 1)
#define ROW2 (1 << 7)
#define ROW3 (1 << 6)
The equivalent binary notation for the bitmasks is:
#define COL0  0b00000100
#define COL1  0b00001000
#define COL2  0b00010000
#define ROW0  0b00000001
#define ROW1  0b00000010
#define ROW2  0b10000000
#define ROW3  0b01000000
Here is a thread that explains how this is done:
http://www.ccsinfo.com/forum/viewtopic.php?t=2671
runtime
Thank you!
PostPosted: Tue Feb 15, 2005 5:03 pm     Reply with quote
I just wanted to say thank you. It worked perfectly!
Best Regards
