pyu
three DS18B20... |
Posted: Tue Feb 10, 2009 4:26 pm |
Hi.
I have 3 DS18B20, pic16F887 and LCD.
I managed to use one sensor, and it's show ok.
But now, I want to use 3 sensors, on a single pic pin.
Can somebody help me with some sources (all code)?
I tried Kenny code http://www.ccsinfo.com/forum/viewtopic.php?t=19255 , but I have many errors. |
Kenny
pyu
pyu
Posted: Thu Feb 12, 2009 12:51 pm |
Here is the code:
(Kenny code)
main.c:
#include <16F887.H>
#device *=16 // FULL RAM ACCESS
#device adc = 10 // ADC de 10 bits
#include <math.h>
//#fuses
#FUSES HS //High speed Osc (> 4mhz)
#FUSES BROWNOUT //Brownout reset
#FUSES PUT // Power Up Timer
#use delay(clock = 20000000)
#include "Flex_LCD420.c"
//header
#include "DS18B20.h"
//source
#include "DS18B20.c"
void init_adc()
//Set up RA0 as the only analog input
setup_adc_ports(sAN0);
//Turn on ADC and use Fosc/2? as the conversion clock
//Fosc=20Mhz->Fosc/2=100ns ---- Fosc=8Mhz->Fosc/2=250ns
//Fosc=20Mhz->Fosc/8=400ns ---- Fosc=8Mhz->Fosc/8=2.0us
//Fosc=20Mhz->Fosc/32=1.6us ---- Fosc=8Mhz->Fosc/32=8.0us
setup_adc(ADC_CLOCK_DIV_2);
//Set channel for conversion to AN0 (on RA0)
set_adc_channel(0);
//delay 10 uS
delay_ms(10);
float voltmetru()
int16 adc_value;
float volts;
adc_value = read_adc();
delay_ms(10);
volts = (float)(adc_value *5)/1023.0;
return volts;
void init_io()
// set up PORTA so RA0, RA1 is an input for the ADC, RA2-RA7 are outputs
SET_TRIS_A(0x01); // bit 0 = output, 1 = input
// set up PORTB so RB0 is an input for the switch SW1, RB1-RB7 are outputs
SET_TRIS_B(0x01); // bit 0 = output, 1 = input
// set up remaining ports to be all outputs
OUTPUT_C(0x00);
OUTPUT_D(0x00);
OUTPUT_E(0x00);
//main function
float temperature=0;
float volts=0;
int8 i;
signed int16 stemp16; // Raw temperature data in 2's complement
int8 scratch[10]; // Lowest two bytes are for temperature
// Set up MCU
init_io();
//Set up the ADC
init_adc();
//init LCD
// Clear the LCD.
printf(lcd_putc, "\f");
output_float(DQ); // 4k7 pullup on bus
FindDevices(); // Find all owb devices get their codes, and output them
ow_reset();
//init timers
init_timers();
//for 10 bit resolution mod
//onewire_write(0xCC);
//onewire_write(0x4E);
//onewire_write(125);
//onewire_write(-55); //this should be done for proper working of DS18B20
//onewire_write(127);
//onewire_reset();
//onewire_write(0x48);
delay_ms(15);
while (1)
//read temperature from PIN_A1 - DS18B20 sensor
//temperature = ds1820_read();
//read volts from PIN_A0
volts = voltmetru();
//reading temps from 3 DS18B20 sensors
// If not using parasitic power can send the temperature convert
// command to all DS18B20 and/or DS1822 devices on the bus.
if (!ow_reset()) // If a device is present
write_byte(0xCC); // Skip Rom command
write_byte(0x44); // Temperature convert command
output_float(DQ);
delay_ms(750); // Max. conv. time is 750mS for 12 bit
ow_reset();
// Now get the device raw temperature data using Match ROM with the
// addresses obtained with FindDevices(). Scale to deg. C, scaling is
// 0.0625 (1/16) deg. C/bit with default 12 bit res. Could reduce res.
// and therefore shorten conversion time if necessary.
// Output the temperatures in whole degrees, apply rounding by adding
// half denom.
for (numRoms=1;numRoms<=8;numRoms++)
if (Send_MatchRom())
write_byte(0xBE); // Read scratch pad command
dowcrc = 0; // Reset the crc to start a new calculation
for (i=0;i<=7;i++)
scratch[i] = read_byte();
ow_crc(scratch[i]); // Accumulate the crc
scratch[8] = read_byte(); // Received crc byte
ow_reset();
// If calculated crc from incoming bytes equal to crc byte
// then data is valid. Calculate and output temperature.
if (scratch[8] == dowcrc)
stemp16 = (signed int16) make16(scratch[1],scratch[0]);
stemp16 = (stemp16 + 8)/16;
//printf("%4ld ",stemp16);
printf(lcd_putc, "%4ld ",stemp16);
//printf("xxx"); // There was an error in the data
printf(lcd_putc,"\nThere was an error in the data");
//putc('\n'); putc('\r');
//print to LCD
printf(lcd_putc,"\fTemp= %3.1f \uC", temperature);
printf(lcd_putc, "\nV= %3.1f", volts);
pyu
DS18B20.h:
#define DQ PIN_A1
// Global variables
int8 Rom_Bit[8]; // Rom_Bit bit
int8 lastDiscrep = 0;
short doneFlag = 0;
int8 FoundROM[7][8]; // Table of found ROM codes, 8 bytes for each
int8 numROMs;
int8 dowcrc; // crc is accumulated in this variable
// crc lookup table
int8 const dscrc_table[] = {
0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
// Returns 0 for one wire device presence, 1 for none
int8 ow_reset(void);
// Read bit on one wire bus
int8 read_bit(void);
void write_bit(int8 bitval) ;
int8 read_byte(void) ;
void write_byte(int8 val) ;
// One wire crc
int8 ow_crc(int8 x) ;
// Searches for the next device on the one wire bus. If there are no more
// devices on the bus then false is returned.
int8 Next(void);
// Resets current state of a ROM search and calls Next to find the first device
// on the one wire bus.
int8 First(void);
void FindDevices(void);
// Sends Match ROM command to bus then device address
int8 Send_MatchRom(void);
pyu
Posted: Thu Feb 12, 2009 12:52 pm |
and DS18B20.C
int8 ow_reset(void)
int8 presence;
output_low(DQ);
delay_us(488); // Min. 480uS
output_float(DQ);
delay_us(72); // Takes 15 to 60uS for devices to respond
presence = input(DQ);
delay_us(424); // Wait for end of timeslot
printf(lcd_putc, "\fPresence= %i", presence);
return(presence);
int8 read_bit(void)
output_low(DQ);
delay_us(1); // 1uS min. Original code relied on 8051 being slow
output_float(DQ);
delay_us(20); // Wait at least 15mS from start of time slot
return(input(DQ)); // Delay to finish time slot (total 60 to 120uS)
} // must be done next.
output_low(DQ);
if(bitval == 1) {
output_float(DQ);
delay_us(105); // Wait for end of timeslot
output_float(DQ);
int8 i;
int8 val = 0;
for(i=0;i<8;i++)
if(read_bit()) val |= (0x01 << i);
delay_us(120); // To finish time slot
return val;
int8 i;
int8 temp;
for (i=0;i<8;i++)
temp = val >> i;
temp &= 0x01;
write_bit(temp);
delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
dowcrc = dscrc_table[dowcrc^x];
return dowcrc;
int8 Next(void)
int8 m = 1; // ROM Bit index
int8 n = 0; // ROM Byte index
int8 k = 1; // Bit mask
int8 x = 0;
int8 discrepMarker = 0;
int8 g; // Output bit
int8 nxt; // Return value
short flag;
nxt = FALSE; // Reset next flag to false
dowcrc = 0; // Reset the dowcrc
flag = ow_reset();
if (flag||doneFlag) // If no parts return false
lastDiscrep = 0; // Reset the search
return FALSE;
write_byte(0xF0); // Send SearchROM command
do
x = 0;
if (read_bit() == 1)
x = 2;
delay_us(120);
x |= 1; // And it's complement
if (x == 3) // There are no devices on the one wire bus
if (x > 0) // All devices coupled have 0 or 1
g = x >> 1; // Bit write value for search
// If this discrepancy is before the last discrepancy on a previous
// Next then pick the same as last time.
if (m < lastDiscrep)
g = ((Rom_Bit[n] & k) > 0);
// If equal to last pick 1
g = (m == lastDiscrep); // If not then pick 0
// If 0 was picked then record position with mask k
if (g == 0) discrepMarker = m;
// Isolate bit in Rom_Bit[n] with mask k
if (g == 1)
Rom_Bit[n] |= k;
Rom_Bit[n] &= ~k;
write_bit(g); // ROM search write
m++; // Increment bit counter m
k = k << 1; // and shift the bit mask k
// If the mask is 0 then go to new ROM
if (k == 0)
{ // Byte n and reset mask
ow_crc(Rom_Bit[n]); // Accumulate the crc
n++;
k++;
} while (n < 8); // Loop through until through all ROM bytes 0-7
if (m < (65||dowcrc)) // If search was unsuccessful then
lastDiscrep = 0; // reset the last Discrepancy to zero
else // Search was successful, so set lastDiscrep, lastOne, nxt
lastDiscrep = discrepMarker;
doneFlag = (lastDiscrep == 0);
nxt = TRUE; // Indicates search not yet complete, more parts remain
return nxt;
int8 First(void)
lastDiscrep = 0;
doneFlag = FALSE;
return Next(); // Call Next and return it's return value;
int8 m;
if(!ow_reset())
if(First()) // Begins when at least one part found
numROMs = 0;
do
numROMs++;
for (m=0;m<8;m++)
FoundROM[numROMs][m] = Rom_Bit[m]; // Identifies ROM no. on device
//printf("Device No.%u address ",numROMs);
printf(lcd_putc, "\f%1i ",numROMs);
//printf("%X%X%X%X%X%X%X%X\n\r",
//FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
//FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
//FoundROM[numROMs][1],FoundROM[numROMs][0]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][7]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][6]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][5]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][4]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][3]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][2]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][1]);
printf(lcd_putc, "\f%1x ",FoundROM[numROMs][0]);
} while (Next() && (numROMs<10)); // Continues until no additional
// devices found.
printf(lcd_putc, "\fno ROM found");
printf(lcd_putc, "\fno ROM found2");
int8 i;
if (ow_reset()) return FALSE; // 0 if device present
write_byte(0x55); // Match ROM
for (i=0;i<8;i++)
write_byte(FoundRom[numROMs][i]); // Send ROM code
return TRUE;
pyu
Posted: Thu Feb 12, 2009 12:57 pm |
the result:
Code: | printf(lcd_putc, "\fPresence= %i", presence); |
presence = 1
and the next thing that is show:
Code: | printf(lcd_putc, "\fno ROM found2"); |
What is wrong in my program?
The ds18B20 sensor is ok, if I run the project only for one sensor, it display the correct temp. |
Kenny
Posted: Thu Feb 12, 2009 4:31 pm |
pyu wrote: | Here is the code:
(Kenny code)
main.c:
It's your code, not mine
All I suggested in reply to your PM was to change the variable name ROM[] to something else because in version 4 of the compiler ROM is a reserved word. You have done that.
I suggest for testing that you strip everything off not relevant to the problem, eg voltage measurement, setting tris, etc., and start again with the code I posted.
Sorry, can't help any further. |
pyu
Posted: Sat Feb 14, 2009 7:25 am |
I wanted to say that is based on your sample code, with my modifications
I have been corected and now, my program looks like this:
main.c:
Code: | #include <16F887.H>
//#device *=16 // FULL RAM ACCESS
//#device adc = 10 // ADC de 10 bits
#include <math.h>
//#fuses
#define DQ PIN_A1 // One Wire Bus pin assignment
//header
//source
int8 i;
ow_reset();
output_float(DQ);
ow_reset();
// half denom.
for (i=0;i<=7;i++)
ow_reset();
else printf(lcd_putc,"\f XXX"); // There was an error in the data
printf(lcd_putc,"\f aaa");
delay_ms(200);
printf(lcd_putc,"\f !ow_reset - false");
delay_ms(200);
DS18B20.h:
// Global variables
short doneFlag = 0;
int8 numROMs;
// crc lookup table
// One wire crc
int8 Next(void);
int8 First(void);
DS18B20.c:
int8 ow_reset(void)
int8 presence;
output_low(DQ);
output_float(DQ);
//printf(lcd_putc, "\fPresence= %i", presence);
//delay_ms(500);
return(presence);
int8 read_bit(void)
output_low(DQ);
output_float(DQ);
output_low(DQ);
if(bitval == 1) {
output_float(DQ);
output_float(DQ);
int8 i;
int8 val = 0;
for(i=0;i<8;i++)
return val;
int8 i;
int8 temp;
for (i=0;i<8;i++)
temp = val >> i;
temp &= 0x01;
write_bit(temp);
delay_us(105);
// One wire crc
int8 ow_crc(int8 x)
return dowcrc;
int8 Next(void)
int8 x = 0;
short flag;
flag = ow_reset();
return FALSE;
do
x = 0;
x = 2;
delay_us(120);
if (g == 1)
Rom_Bit[n] |= k;
Rom_Bit[n] &= ~k;
if (k == 0)
n++;
k++;
return nxt;
int8 First(void)
lastDiscrep = 0;
doneFlag = FALSE;
int8 m;
if(!ow_reset())
numROMs = 0;
do
numROMs++;
for (m=0;m<8;m++)
// devices found.
//delay_ms(500);
//delay_ms(500);
int8 i;
for (i=0;i<8;i++)
return TRUE;
The result is not what I expected :(
On the lcd:
Something is still wrong on my program. |
Kenny
Posted: Sat Feb 14, 2009 3:38 pm |
Very good
I will test it on hardware at work.
The lcd_init() statement should be before FindDevices() though. |
pyu
Posted: Sun Feb 15, 2009 9:15 am |
Ok, thanks.
I use CCS C Compiler version 4.0.13. |
Posted: Sun Feb 15, 2009 9:27 am |
Ouch....
You might want to read the 'sticky thread' at the top of this forum about the early V4 releases. 4.013, is very likely to give problems, if you try to use functions much beyond 'basic' operations. You might want to see if you can upgrade to save yourself a lot of grief.
pyu
Posted: Sun Feb 15, 2009 12:13 pm |
I have now installed the version 4.084.
The result is the same :( |
Posted: Sun Feb 15, 2009 1:19 pm |
I just tested your code using four DS18B20s after making three changes:
1. I removed the LCD related stuff (i.e lcd_putc) and printed just to an
RS232 terminal connection.
2. I changed the processor to an 18F4520 since this is what I already had
set up to test.
3. I used E2 as the DQ pin rather than A1
Once I made those changes, your code basically worked correctly and it
properly enumerated the multiple DS18B20s in the circuit. The temps for
all the units displayed correctly and the temps went up when I was
touching them. This proves the core code is good.
I would recommend for you to do the same thing, get rid of the extra stuff
and concentrate on getting the basic code working then add a piece at
a time.
Using printfs I displayed the interim data for the first two DS18B20s so
you can see the results. The incoming data is good, you have some "math" issues left to resolve.
Quote: |
stemp16 (hex) result: 0154 Your math result (degrees C): 21 The CRC is: fd
stemp16 (hex) result: 0147 Your math result (degrees C): 20 The CRC is: 93
pyu
Posted: Sun Feb 15, 2009 2:52 pm |
What version of compiler did you used? |
