		| Author | Message |
		| jallum
				| Master and slave I2C implemented on one PIC |
				|  Posted: Thu Mar 06, 2008 1:33 pm |   |
				| If you are trying to set up your PIC as master of an I2C bus using SW implementation, and slave of an altogether different bus (or even the same bus I suppose) using the HW SSP module, here is some code for you:
  	  | Code: |  	  | #include <16F877A.h>
 #device adc=10
 #FUSES NOWDT                     //No Watch Dog Timer
 #FUSES HS                        //High speed Osc (> 4mhz)
 #FUSES PUT                       //Power Up Timer
 #FUSES PROTECT                   //Code protected from reads
 #FUSES NODEBUG                   //No Debug mode for ICD
 #FUSES BROWNOUT                  //Brownout reset
 #FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
 #FUSES NOCPD                     //No EE protection
 #FUSES NOWRT                     //Program memory not write protected
 #use delay(clock=20M)
 //NOTE: Must declare MASTER before SLAVE, i2c_isr_state() returns 0
 //      when MASTER is the most recent #use i2c
 #use i2c(MASTER, sda=PIN_C1, scl=PIN_C0, stream=I2CM)
 #use i2c(SLAVE, sda=PIN_C4, scl=PIN_C3, address=0x60, force_hw, stream=I2CS)
 #use rs232(baud=57600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8, stream=COM1)
 #use fast_io(D)
 int rcv_buf[0x10];
 int wrt_buf[0x10];
 int cmd=0xFF;
 #int_SSP // interrupt on i2c activity
 void  i2c_isr(void)
 int state, incoming;
 state = i2c_isr_state();
 if(state < 0x80)
 incoming = i2c_read(I2CS);
 if (state == 1)
 cmd = incoming;
 else if (state > 1)
 rcv_buf[state-2]=incoming;
 i2c_write(I2CS,wrt_buf[state-0x80]);
 enable_interrupts(INT_SSP);
 printf("\n\rbegin");
 while (TRUE)
 if (cmd<0xFF)
 printf("\n\rcmd: %x", cmd);
 i2c_start(I2CM);
 i2c_write(I2CM,0xa0);      //i2c address of a slave device
 i2c_write(I2CM,0x2e);      //1st byte to slave
 i2c_write(I2CM,0xa0);      //2nd byte to slave
 i2c_stop(I2CM);
 It is VERY important to declare the SLAVE after the MASTER. It appears that i2c_isr_state() will return 0 if the MASTER declaration is the most recently encountered #use statement, although i2c_isr_state() should only read the state of the SLAVE SSP hardware.
		| XyVy
				|  Posted: Wed Sep 10, 2008 3:16 am |   |
				| Hello Jallum, I need to do work i2c master and slave in the same PIC, but when I introduce the #use i2c(master...) the slave side does not work, but if I delete the #use i2c(master...) line, the slave side works okey again.
 What is wrong?
 My code is:
  	  | Code: |  	  | #include <16F876A.h>
 #FUSES XT                       //Crystal osc <= 4mhz
 #byte port_b=0x06
 #use i2c(MASTER, FAST, sda=PIN_A0, scl=PIN_A1, address=0xB0, force_sw, stream=i2cM)
 #use i2c(SLAVE, FAST, sda=PIN_C4, scl=PIN_C3, address = 0x08, force_hw, stream = i2cS)
 // Comandos soportados por el PIC 16F876 en nuestro software
 #define INIT            0x01
 #define CONSULTA_MOTOR1 0x02
 #define CONSULTA_MOTOR2 0x03
 #define MUEVE_MOTOR1    0x04
 #define MUEVE_MOTOR2    0x05
 #define INTERRUPTOR1    0x06
 #define INTERRUPTOR2    0x07
 #define INTERRUPTOR3    0x08
 #define INTERRUPTOR4    0x09
 #define STOP_MOTOR1     0x0A
 #define STOP_MOTOR2     0x0B
 // definimos los datos para usar i2c
 char data;
 char cuenta;
 BYTE state;
 BYTE comando;
 BYTE dato;
 void inicializa()
 output_high(PIN_B2);
 i2c_start(i2cM);
 i2c_write(i2cM, 0xB0);   // Dirección del dispositivo
 i2c_write(i2cM, 0x00);   // Registro de Modo
 i2c_write(i2cM, 0x01);   // Motor1 detenido
 i2c_stop(i2cM);
 output_low(PIN_B2);
 void MueveMotor1(char dato)
 i2c_start(i2cM);
 i2c_write(i2cM, 0x01);  // Registro de modo
 i2c_write(i2cM, dato);   // Registro Velocidad motor 1
 i2c_stop(i2cM);
 output_low(PIN_B2);
 void MueveMotor2(char dato)
 i2c_start(i2cM);
 i2c_write(i2cM, 0x02);   // Velocidad de los motores
 i2c_write(i2cM, dato);   // Velocidad del motor2
 i2c_stop(i2cM);
 output_low(PIN_B2);
 void StopMotor1()
 i2c_start(i2cM);
 i2c_write(i2cM, 0x01);   // Registro de Modo
 i2c_write(i2cM, 128);
 i2c_stop(i2cM);
 output_low(PIN_B2);
 void StopMotor2()
 i2c_start(i2cM);
 i2c_write(i2cM, 128);   // velocidad del motor1
 i2c_stop(i2cM);
 output_low(PIN_B2);
 #INT_SSP
 void ssp_interupt ()
 if(state<0x80)                 //master is sending data
 if(state == 0)
 } else if (state == 1)                   //first received byte
 comando = i2c_read(i2cS);
 } if (state==2) {   // 2º byte recibido
 dato=i2c_read(i2cS);
 }else if (state == 0x80) {               //master is requesting data
 output_high(PIN_B1);
 if (input(PIN_B4)) {
 i2c_write(i2cS, 1);
 } else {
 i2c_write(i2cS, 0);
 i2c_write(i2cS, cuenta);  //send requested data
 cuenta++;
 char data;
 int pulsado=0;
 char sw=0;
 int activo;
 cuenta=0;
 port_b=0;
 sw=0;
 pulsado=0;
 while (1) {
 activo=input(PIN_B4);
 if (activo && (sw==0) && (!pulsado)) {
 output_low(PIN_B2);
 MueveMotor1(255);
 StopMotor2();
 pulsado=1;
 sw=1;
 } else if (activo && (sw==1) && (!pulsado)) {
 MueveMotor2(255);
 StopMotor1();
 pulsado=1;
 sw=0;
 delay_ms(50);
 if (!input(PIN_B4)) {
 output_low(PIN_B2);
 pulsado=0;
 delay_ms(50);
 Thanks in advance!
		| XyVy
				|  Posted: Thu Sep 11, 2008 2:40 am |   |
				| Good news guys!
 I have solved my problem.
 I put the uses like:
 #use i2c(MASTER, sda=PIN_A0, scl=PIN_A1, address=0xB0, stream=i2cM)
 #use i2c(SLAVE, sda=PIN_C4, scl=PIN_C3, address = 0x08, force_hw, stream = i2cS)
 But, I believe the problem was in the following function:
  	  | Code: |  	  | #INT_SSP
 state = i2c_isr_state(i2cS);
 if(state == 0)
 i2c_write(i2cS, 1);
 } else {
 i2c_write(i2cS, 0);
 cuenta++;
 I forgot put the "i2cS" stream in the i2c_isr_state.
 The PIC works okey!!
 Thanks!
 | You cannot post new topics in this forum You cannot reply to topics in this forum
