sudarsan
| pic16f877a and t6963 glcd c code tested and working |
Posted: Thu Nov 08, 2012 1:04 am |
/* main file */
/* copy this code into notepad and save as (urfilename).c */
#include <16F877a.h>
#Fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#use delay(clock=20000000)
#include "t6963.h"
#include "t6963.c"
GDispInit(); //T6963C display initialization
GDispSetMode(XOR_MODE|INT_CG_MODE); //Exclusive OR mode, internal CG character RAM
GDispSetMode(TEXT_GRH_ON); //Text ON, Graphics ON
GDispClrTxt(); //Clear the text area
GDispClrGrh(); //Clear the graphics area (dot-by-dot!)
GDispGoto(0,0);
GDispChar(0x85);
sudarsan
| t6963.c file |
Posted: Thu Nov 08, 2012 1:07 am |
/* t6963.c file */
#include "font5x7.h" //custom-defined 5x7 font, for GDispPixFontAt(...)
* LOCAL CONSTANTS
#define CURSOR_PTR_SET 0x21 //Cursor Pointer Set
#define OFFSET_REG_SET 0x22 //Set Offset Command
#define ADDR_PTR_SET 0x24 //Set Address Pointer Command
#define TEXT_HOME_SET 0x40 //Text Home Address Set: Data = low, high addr
#define TEXT_AREA_SET 0x41 //Text Area Set: Data = columns, 0
#define GRAPH_HOME_SET 0x42 //Graphics Home address Set: Data = low, high addr
#define GRAPH_AREA_SET 0x43 //Graphics Area Set: Data = columns, 0
#define SCREEN_PEEK 0xE0 //Read data from screen command
#define SCREEN_COPY 0xE8 //Screen Copy
#define AUTO_WR_ON 0xB0
#define DATA_AUTO_RD 0xB1
#define AUTO_WR_OFF 0xB2
#define DATA_WR_INC 0xC0 // Data write and increment addrespointer
#define DATA_RD_INC 0xC1 // Data read and increment addrespointer
#define DATA_WR_DEC 0xC2 // Data write and decrement addrespointer
#define DATA_RD_DEC 0xC3 // Data read and decrement addrespointer
#define DATA_WR 0xC4 // Data write - no addr change
#define DATA_RD 0xC5 // Data read - no addr change
* LOCAL FUNCTION PROTOTYPES
static void GDispCmdAddrSend(unsigned int16 Addr, unsigned char cmd);
* SEND ADDRESS COMMAND
* Description : This function sends screen address with a command to the LCD screen
* Arguments : 'Addr' is the screen address to send
* 'cmd' is the command
* Returns : none
* Notes : Most often a graphic LCD needs a screen address for command setup.
* Example, set Graph Home Address is the command GRAPH_HOME_SET (0x42), at the ram address
* GRH_HOME_ADDR (0x0200), say.
unsigned int8 c;
c = Addr&0x00FF;
GDispDataWr(c); //Send LSB of 'Addr' first
c = Addr >> 8;
GDispDataWr(c); //Send MSB of 'Addr' afterwards
GDispCmdSend(cmd);
* DISPLAY DRIVER INITIALIZATION
* Description : This function initializes the display driver
* Arguments : none
* Returns : none
* Notes :
void GDispInit(void)
//Reset the LCD module and perform a hardware port init
GDispInitPort();
//Set Text Home address to TEXT_HOME_ADDR
GDispCmdAddrSend(TEXT_HOME_ADDR,TEXT_HOME_SET);
//Set Graph Home address to GRH_HOME_ADDR
GDispCmdAddrSend(GRH_HOME_ADDR,GRAPH_HOME_SET);
//Set Text Area to COLUMN column mode
GDispCmdAddrSend(COLUMN,TEXT_AREA_SET);
//Set Graph Area to COLUMN column mode
GDispCmdAddrSend(COLUMN,GRAPH_AREA_SET);
//Set Offset register to 0x0002, CG Ram start address = $1400 (CG_HOME_ADDR)
//first character code $80 for CG Ram
GDispCmdAddrSend(0x0002,OFFSET_REG_SET);
* SET MODE FOR DISPLAY/MODE/CURSOR/TEXT_ATTRIBUTE
* Description : This function sets mode
* Arguments : 'mode' , refer to mode available in t6963.h, MODE Section, CURSOR MODE, TEXT ATTRI
* Returns : none
* Notes :
void GDispSetMode(unsigned int8 mode)
GDispCmdSend(mode);
* CLEAR TEXT SCREEN
* Description : This function clears the text clear in font mode
* Arguments : none
* Returns : none
* Notes :
void GDispClrTxt(void)
unsigned int16 row;
unsigned int16 col;
//Set address pointer to address (TEXT_HOME_ADDR)
GDispCmdAddrSend(TEXT_HOME_ADDR,ADDR_PTR_SET);
//Set Auto Write ON
GDispCmdSend(AUTO_WR_ON);
//row runs from 0 ... (MAX_ROW_PIXEL/8 -1), in form of a cell of (FontSize x 8) bits
for(row=0; row < MAX_ROW_PIXEL/8; row++)
{ //write blank to clear screen the first page only, col = 0...(COLUMN-1)
for(col=0; col < COLUMN; col++)
GDispAutoDataWr(0x00);
//Set Auto Write OFF
GDispCmdSend(AUTO_WR_OFF);
* CLEAR THE GRAPHIC AREA
* Description : This function clears the graphic area pixel by pixel
* Arguments : none
* Returns : none
* Notes :
void GDispClrGrh(void)
unsigned int16 row;
unsigned int16 col;
//Set address pointer to address (GRH_HOME_ADDR)
GDispCmdAddrSend(GRH_HOME_ADDR, ADDR_PTR_SET);
//row runs from 0 ... (MAX_ROW_PIXEL-1), in form of a byte size of (FontSize x 1) bits
for(row=0; row < MAX_ROW_PIXEL; row++)
for (col=0; col < COLUMN; col++)
GDispCmdSend(AUTO_WR_OFF); //Set Auto Write OFF
* GOTO A POSITION (row, col)
* Description : This function sets the screen address pointer to a position row, col
* Arguments : 'row' row = 0...(MAX_ROW_PIXEL/8 - 1), the cell number in 8 bits height
* 'col' col = 0...(COLUMN-1), is the column position in font width (6/8 font)
* Returns : none
* Notes :
void GDispGoto(unsigned int16 row, unsigned int16 col)
unsigned int16 addr;
addr = row*COLUMN + col + TEXT_HOME_ADDR;
GDispCmdAddrSend(addr,ADDR_PTR_SET); //Set address pointer
* DISPLAY A CHARACTER AT THE CURRENT SCREEN ADDRESS POINTER
* Description : This function is used to display a single character on the display device at row, col
* col, row should have been set by GDispGoto(row, col) before. AUTO ADDRESS POINTER INC!
* Arguments : 'c' is the ASCII character to write
* Returns : none
* Notes : This function gets around the problem that pointers cannot be created to constant string
* in PCM. Referring to CCS Reference Manual (page 67), a function that has one CHAR
* parameter will accept a constant string where it is called. PCM will generate a loop
* that will call the function once for each character in the string.
* Example :
* GDispGoto(5,5);
* GDispChar("Hello there!");
void GDispChar(unsigned char c)
GDispDataWr(c - 0x20); //Adjust standard ASCII to T6963 ASCII
GDispCmdSend(DATA_WR_INC); //Address pointer increment ON
* DISPLAY A CHARACTER AT A POSITION (row, col)
* Description : This function is used to display a single character on the display device, address
* auto increment OFF!
* Arguments : 'row' row = 0...(MAX_ROW_PIXEL/8 - 1), the row pos of the cursor (MAX_ROW_PIXEL/8-1)
* 'c' is the ASCII character to write
* Returns : none
* Notes : COLUMN constant determines the number of page, can be > physical size of the LCD
void GDispCharAt(unsigned int16 row, unsigned int16 col, unsigned char c )
GDispGoto(row, col);
GDispCmdSend(DATA_WR);
* SET CURSOR AT A POSITION
* Description : This function sets cursor at a position (row, col), of certain mode & type
* Arguments : 'mode' is the mode of cursor. It should be bitwise OR with a TEXT / GRAPH mode to work
* mode = TEXT_GRH_ON|CURSOR_BLINK_ON
* TEXT_ON|CURSOR_ON_BLINK_OFF....
* TEXT_ON, without bitwise OR any cursor mode only will clear cursor
* 'row' is the MSB of screen address, the row position of the cursor
* 'col' is the LSB of the screen address, the column position of the cursor
* 'type' is cursor type
* type = LINE_1_CURSOR / LINE_8_CURSOR
* Returns : none
* Notes : Cursor address is not like text address pointer. Cannot use GDispGoto(row,col).
void GDispSetCursor(unsigned int8 mode, unsigned int16 row, unsigned int16 col, unsigned int8 type)
addr = row << 8;
addr = addr|(col&0x00FF);
GDispCmdAddrSend(addr, ADDR_PTR_SET);
GDispCmdSend(CURSOR_PTR_SET); //Set cursor position
GDispCmdSend(mode);
GDispCmdSend(type); //cursor mode
* SET PIXEL AT X, Y POSITION
* Description : This function sets a pixel with color = BLACK / WHITE (defined in t6963.h)
* Arguments : 'X' 0....MAX_COL_PIXEL is matrix position in horizontal direction
* 'Y 0....MAX_ROW_PIXEL is matrix position in vertical direction
* 'color' sets BLACK / WHITE standing for pixel ON/OFF
* Returns : none
* Notes :
void GDispSetPixel(unsigned int16 X, unsigned int16 Y, unsigned int8 color)
unsigned int16 row, col;
unsigned char cmd;
row = Y;
col = X/8;
addr = row*COLUMN + col + GRH_HOME_ADDR;
if (color == BLACK)
cmd = (0b11111000)|(8- 1 -(X%8));
cmd = (0b11110000)|(8- 1 -(X%8));
GDispCmdSend(cmd);
void glcd_3Dbox(int16 x,int16 y,int16 width, int16 height, int depth, int1 color)
int16 i,j;
for(i=x;i<=x+width;i++)
GDispSetPixel(i,y,1);
GDispSetPixel(i,y+height,1);
for(i=y;i<=y+height;i++)
GDispSetPixel(x,i,1);
GDispSetPixel(x+width,i,1);
for(j=1;j<=depth;j++)
for(i=y+j;i<=y+height+j;i++)
GDispSetPixel(x-j,i,1);
for(i=x-j;i<=(x-j+width);i++)
GDispSetPixel(i,y+height+j,color);
* SET TEXT ATTRIBUTE (NOT COMPLETE DEBUG)
* Description : This function sets / clears text attribute mode
* 'mode' = ATTR_REVERSE, ATTR_INHIBIT, ATTR_BLINK_REVERSE, ATTR_BLINK_INHIBIT...
* (see TEXT ATTRIBUTE MODE in t6963.h for available mode)
* Returns : none
* Notes : After function call to GDispSetAttrb(row,col,ATTR_BLINK_REVERSE),
* should use GDispSetAttrib(row,col, ATTR_NORMAL) before using graphic area again to avoid
* graphic area data write error!
void GDispSetAttrb(unsigned int16 row, unsigned int16 col, unsigned int8 mode)
GDispAutoDataWr(mode);
GDispCmdSend(TEXT_ATTR_MODE);
GDispCmdSend(TEXT_GRH_ON);
* SET CUSTOM DEFINED CHARACTER TO CG RAM
* Description : This function assigns a custom created pattern of 8 BYTE with an id number
* Arguments : 'id' is the identifier for the pattern created. Range of 'id' is 0...127 for T6963.
* 'pat' is a pointer to an 8 BYTE array containing the dot pattern
* Returns : none
* Notes : Pointers cannot be created to constant arrays in PCM. Thus, a global CGBuffer[]'s created
* in t6963.h to store a constant array to RAM space.
* Code Example ::
* char i;
* const char CUSTOM_PAT[8] = {0x00, 0x23, 0x45, 0x56, 0x89, 0xAB, 0xFF, 0xEE};
* for(i=0;i<8;i++) CGBuffer[i] = CUSTOM_PAT[i] //assign CUSTOM_PAT[] to CGBuffer[]
* GDispDefCGChar(0, &CGBuffer[0]); //create a pattern in CG RAM with id '0'
void GDispDefCGChar(unsigned int8 id, unsigned char *pat)
unsigned int8 i;
GDispCmdAddrSend(CG_HOME_ADDR+(unsigned int16)id*8, ADDR_PTR_SET);
for(i=0; i<8; i++)
GDispDataWr(*pat++);
* DISPLAY AN EXTERNAL CG CHARACTER AT THE CURRENT SCREEN ADDRESS POINTER
* Description : This function shows a pre-defined CG RAM character at the current screen address pointer
* Returns : none
* Notes :
void GDispCGChar(unsigned int8 id)
GDispDataWr(0x80 + id); //Adjust standard ASCII to T6963 ASCII
GDispCmdSend(DATA_WR_INC); //'0x80 + id's range 0 to 255, good for GDispDataWr(char)
* DISPLAY AN EXTERNAL CG CHARACTER AT ROW, COL
* Description : This function shows a pre-defined CG RAM character at (row, col) coordinates
* Returns : none
* Notes :
void GDispCGCharAt(unsigned int16 row, unsigned int16 col, unsigned int8 id)
GDispGoto(row,col);
GDispCGChar(id);
* DISPLAY A BLANK ICON OF 32x32 MATRIX AT ROW, COL
* Description : This function clears the 32x32 ICON at (row, col) coordinates
* Returns : none
* Notes :
void GDispBlkIcon32X32At(unsigned int16 row, unsigned int16 col)
unsigned int16 row_cnt, col_cnt;
for(row_cnt = row; row_cnt < (row+4); row_cnt++)
for(col_cnt = col; col_cnt < (col+4); col_cnt++)
GDispCharAt(row_cnt, col_cnt, ' ');
* CONVERT A STRING TO PIXEL DATA AND DISPLAY AT X,Y IN GRAPHIC MODE
* Description : This function outputs a string in graphic mode from a char* textptr pointer
* 'textptr' pointer to the string to write
* 'size' should be non-zero, 1 = 5x7, 2 = 10x14, ..., basically "enlarge" the font
* defined under font5x7.h.
* 'color' BLACK / WHITE
* Returns : none
* Notes : Copyright (c) 2004 Sentinel Systems Corporation
* Example, declare a string
* char str[] = "Hello World!";
* main()
* GDispPixFontAt(0,20,&str[0],2,BLACK); //Display the "Hello World!" string starting
* //at (x,y)=(0,20), in size font size 2 (10x14)
* //color in black
void GDispPixFontAt(unsigned int16 X, unsigned int16 Y, unsigned char* textptr, unsigned char size, int1 color)
const BYTE bytes_per_char = 5;
int i, j, k, l, m; // Loop counters
BYTE pixelData[bytes_per_char]; // Stores character data
for(i=0; textptr[i] != '\0'; ++i, ++X) // Loop through the passed string
if(textptr[i] < 'S') // Checks if the letter is in the first or second array
memcpy(pixelData, FONT1[textptr[i]-' '], bytes_per_char);
else if(textptr[i] <= '~') // Check if the letter is in the second array
memcpy(pixelData, FONT2[textptr[i]-'S'], bytes_per_char);
else // Default to space if character out of range
memcpy(pixelData, FONT1[0], bytes_per_char);
if(X+5*size >= MAX_COL_PIXEL) // Performs character wrapping
X = 0; // Set X at far left position
Y += 7*size + 1; // Set Y at next position down
for(j=0; j<bytes_per_char; ++j, X+=size) // 5 bytes per character
for(k=0; k<7*size; ++k) // Loop through the vertical pixels
if(bit_test(pixelData[j], k)) // Check if the pixel should be set
for(l=0; l<size; ++l) // The next two loops change the character's size
for(m=0; m<size; ++m)
{ // Draws the pixel
GDispSetPixel(X+m, Y+k*size+l, color);
} //for(i = 0; textptr[i] != '\0';...)
* I/O PORT INITIALIZATION
* Description : This initializes the I/O ports used by the display driver
* Arguments : none
* Returns : none
* Notes :
void GDispInitPort(void)
LCD_RST = 0;
LCD_CD = 1;
LCD_CE = 1;
LCD_RD = 1;
LCD_WR = 1;
LCD_DATA = 0x00;
//Set all control line as output
LCD_CE_TRIS = 0;
LCD_RD_TRIS = 0;
LCD_CD_TRIS = 0;
LCD_WR_TRIS = 0;
LCD_RST_TRIS = 0;
LCD_DATA_TRIS = 0x00;
//Turn on LCD module after reset
#asm
nop
#endasm
LCD_RST=1;
* BUSY CHECK
* Description : This function checks command execution capability, & data read/write capability
* Arguments : none
* Returns : none
* Notes :
void GDispBusyChk(void)
GDispCmdRd;
GDispChipEn;
#asm
nop
#endasm
while (!STA0) // Busy Check here
while (!STA1)
GDispChipDi; //Chip disable to finish
* AUTO MODE DATA WRITE CHECK
* Description : This function checks auto mode data write capability
* Arguments : none
* Returns : none
* Notes :
void GDispAutoWrChk(void)
GDispCmdRd;
GDispChipEn;
#asm
nop
#endasm
while(!STA3)
GDispChipDi;
* WRITE DATA TO LCD MODULE
* Description : This function sends a single data byte to the display device
* Arguments : 'data' is the BYTE to send to the display device
* Returns : none
* Notes :
void GDispDataWr(unsigned char data)
GDispBusyChk(); // Wait for LCD to be ready
LCD_DATA = data; // Data write
#asm
nop
#endasm
GDispDatWr;
GDispChipEn;
#asm
nop //delay one cycle for port stablize
#endasm
GDispChipDi;
* WRITE DATA TO LCD MODULE, SCREEN ADRESS AUTO-INCREMENTED
* Description : Send a single data byte to the screen with screen address auto'ly incremented
* Returns : none
* Notes :
void GDispAutoDataWr(unsigned char data)
GDispAutoWrChk(); // Auto write mode check
#asm
nop
#endasm
GDispDatWr;
GDispChipEn;
#asm
#endasm
GDispChipDi;
* WRITE COMMAND TO LCD MODULE
* Description : This function sends a single byte as command to the display device
* Arguments : 'cmd' is the COMMAND BYTE to send to the display device
* Returns : none
* Notes :
void GDispCmdSend(unsigned char cmd)
LCD_DATA = cmd;
GDispCmdWr;
GDispChipEn;
#asm
nop
#endasm
GDispChipDi;
sudarsan
| t6963.h file |
Posted: Thu Nov 08, 2012 1:09 am |
| Code: | /*
* PORT DEFINITION
#byte PORTA = 0x05
#byte TRISA = 0x85
#bit PORTA0 = PORTA.0
#bit PORTA1 = PORTA.1
#bit PORTA2 = PORTA.2
#bit PORTA3 = PORTA.3
#bit PORTA4 = PORTA.4
#bit PORTA5 = PORTA.5
#bit TRISA0 = TRISA.0
#bit TRISA1 = TRISA.1
#bit TRISA2 = TRISA.2
#bit TRISA3 = TRISA.3
#bit TRISA4 = TRISA.4
#bit TRISA5 = TRISA.5
#byte PORTB = 0x06
#byte TRISB = 0x86
#bit PORTB0 = PORTB.0
#bit PORTB1 = PORTB.1
#bit PORTB2 = PORTB.2
#bit PORTB3 = PORTB.3
#bit PORTB4 = PORTB.4
#bit PORTB5 = PORTB.5
#bit PORTB6 = PORTB.6
#bit PORTB7 = PORTB.7
#bit TRISB0 = TRISB.0
#bit TRISB1 = TRISB.1
#bit TRISB2 = TRISB.2
#bit TRISB3 = TRISB.3
#bit TRISB4 = TRISB.4
#bit TRISB5 = TRISB.5
#bit TRISB6 = TRISB.6
#bit TRISB7 = TRISB.7
#byte PORTC = 0x07
#byte TRISC = 0x87
#bit PORTC0 = PORTC.0
#bit PORTC1 = PORTC.1
#bit PORTC2 = PORTC.2
#bit PORTC3 = PORTC.3
#bit PORTC4 = PORTC.4
#bit PORTC5 = PORTC.5
#bit PORTC6 = PORTC.6
#bit PORTC7 = PORTC.7
#bit TRISC0 = TRISC.0
#bit TRISC1 = TRISC.1
#bit TRISC2 = TRISC.2
#bit TRISC3 = TRISC.3
#bit TRISC4 = TRISC.4
#bit TRISC5 = TRISC.5
#bit TRISC6 = TRISC.6
#bit TRISC7 = TRISC.7
#byte PORTD = 0x08
#byte TRISD = 0x88
#bit PORTD0 = PORTD.0
#bit PORTD1 = PORTD.1
#bit PORTD2 = PORTD.2
#bit PORTD3 = PORTD.3
#bit PORTD4 = PORTD.4
#bit PORTD5 = PORTD.5
#bit PORTD6 = PORTD.6
#bit PORTD7 = PORTD.7
#bit TRISD0 = TRISD.0
#bit TRISD1 = TRISD.1
#bit TRISD2 = TRISD.2
#bit TRISD3 = TRISD.3
#bit TRISD4 = TRISD.4
#bit TRISD5 = TRISD.5
#bit TRISD6 = TRISD.6
#bit TRISD7 = TRISD.7
#byte PORTE = 0x09
#byte TRISE = 0x89
#bit PORTE0 = PORTE.0
#bit PORTE1 = PORTE.1
#bit PORTE2 = PORTE.2
#bit TRISE0 = TRISE.0
#bit TRISE1 = TRISE.1
#bit TRISE2 = TRISE.2
//I/O port for data definition
#ifndef T6963_H
#define T6963_H
#define LCD_DATA PORTD // LCD data port
#define LCD_DATA_TRIS TRISD // LCD Data port Tris
#define STA0 PORTD0 // Check command execution capability
#define STA1 PORTD1 // Check data read/write capability
#define STA2 PORTD2 // Check Auto mode data read capability
#define STA3 PORTD3 // Check Auto mode data write capability
#define STA5 PORTD5 // Check controller operation capability
#define STA6 PORTD6 // Error flag. Used for screen peek and screen copy
#define STA7 PORTD7 // Check the blink condition
//Control pin setting
#define LCD_CE PORTC2 // LCD Enable control line pin number
#define LCD_CE_TRIS TRISC2 // LCD Enable control line direction pin #
#define LCD_RD PORTC1 // LCD Read control line pin number
#define LCD_RD_TRIS TRISC1 // LCD Read control line direction pin #
#define LCD_WR PORTC0 // LCD Write control line pin number
#define LCD_WR_TRIS TRISC0 // LCD Write control line irection pin #
#define LCD_CD PORTB7 // LCD Control/data Select line
#define LCD_CD_TRIS TRISB7 // LCD Control/data Select line direction
#define LCD_RST PORTB6 // LCD RST_ line
#define LCD_RST_TRIS TRISB6 // LCD RST_line direction
* GLOBAL CONSTANTS
* Note : The T6963 controller's RAM address space from $0000 - $FFFF, total 64kbyte RAM.
* It is just the RAM address set, not the actual RAM amount can be set!
* However, everything manufacturer may mount different amount of RAM on its
* module. Example, Powertip's PG12864-F has 4 kbyte RAM only.
* RAM space to handle 128x64 dots in 8 font = 128x64/8 = 1,024 byte.
* Thus, the LCD's actual visible screen area is 1 kbyte.
* For 8-font, 16 COLUMN,
* TEXT_HOME_ADDR starts 0x0000 ending 0x01FF -> 512 bytes (for text use)?
* GRH_HOME_ADDR starts 0x0200 ending 0x05FF -> 1,024 bytes ?
* CG_HOME_ADDR starts 0x1400 ending 0x147F -> 128 bytes (custom characters) ?
#define TEXT_HOME_ADDR 0x0000
#define GRH_HOME_ADDR 0x0200
#define CG_HOME_ADDR 0x1400
#define COLUMN 30 //Set column number to be e.g. 32 for 8x8 fonts, 2 pages
#define MAX_ROW_PIXEL 64 //MAX_ROW_PIXEL the physical matrix length (y direction)
#define MAX_COL_PIXEL 240 //MAX_COL_PIXEL the physical matrix width (x direction)
#define ENABLE 1
#define DISABLE 0
#define BLACK 1
#define WHITE 0
* DISPLAY MODE
#define DISPLAY_OFF 0x90 //0b10010000, display off
#define CURSOR_ON_BLINK_OFF 0x92 //0b1001xx10, cursor on without blinking
#define CURSOR_BLINK_ON 0x93 //0b1001xx11, cursor on with blinking
#define TEXT_ON 0x94 //0b100101xx, text on, graphics off
#define GRAPHIC_ON 0x98 //0b100110xx, text off, graphics on
#define TEXT_GRH_ON 0x9C //0b100111xx, text on, graphics on
* MODE
* Example: OR_MODE|EXT_CG_MODE -> OR mode, external CG ram mode
* AND_MODE -> AND mode, internal CG ROM mode
* In internal CG ROM MODE (INT_CG_MODE), character codes 00h - 7Fh represent the
* pre-defined "internal" CG ROM characters, and codes 80h - FFh represent the
* users' own "external" characters. In external CG ROM MODE (EXT_CG_MODE),
* all 256 codes from 00h - FFh can be used to represent the users' own characters.
#define INT_CG_MODE 0x80 //0b10000xxx, Internal CG ROM mode
#define EXT_CG_MODE 0x88 //0b10001xxx, External CG RAM mode
#define OR_MODE 0x80 //0b1000x000, OR mode, internal CG ROM mODE
#define XOR_MODE 0x81 //0b1000x001, XOR mode, internal CG ROM mode
#define AND_MODE 0x83 //0b1000x011, AND mode, internal CG ROM mode
#define TEXT_ATTR_MODE 0x84 //0b1000x100, text attribute mode, internal CG ROM mode
* CURSOR MODE
#define LINE_8_CURSOR 0xA7 //8-line cursor mode
#define LINE_7_CURSOR 0xA6 //7-line cursor mode
#define LINE_6_CURSOR 0xA5 //6-line cursor mode
#define LINE_5_CURSOR 0xA4 //5-line cursor mode
#define LINE_4_CURSOR 0xA3 //4-line cursor mode
#define LINE_3_CURSOR 0xA2 //3-Line cursor mode
#define LINE_2_CURSOR 0xA1 //2-Line cursor mode
#define LINE_1_CURSOR 0xA0 //1-Line cursor mode
* TEXT ATTRIBUTE MODE
#define ATTR_NORMAL 0x00 //Normal Display
#define ATTR_REVERSE 0x05 //Reverse Display
#define ATTR_INHIBIT 0x03 //Inhibit Display
#define ATTR_BLINK 0x08 //Blinking of Normal Display
#define ATTR_BLINK_REVERSE 0x0D //Blinking of Reverse Display
#define ATTR_BLINK_INHIBIT 0x0B //Blinking of Inhibit Display
* GLOBAL VARIABLES
unsigned int8 DisplayMode; /* Keeps state of the display mode (DISPLAY MODE) */
unsigned int8 Mode; /* Keeps state of the MODE */
// extern unsigned const FontSize; /* 6 font or 8 font */
unsigned char CGBuffer[8]; /* Buffer for custom pattern */
* FUNCTION PROTOTYPES
void GDispInit(void);
void GDispSetMode(unsigned int8 mode);
void GDispClrTxt(void);
void GDispClrGrh(void);
void GDispGoto(unsigned int16 row, unsigned int16 col);
void GDispChar(unsigned char c);
void GDispCharAt(unsigned int16 row, unsigned int16 col, unsigned char c);
void GDispSetCursor(unsigned int8 mode, unsigned int16 row, unsigned int16 col, unsigned int8 type);
void GDispSetPixel(unsigned int16 X, unsigned int16 Y, unsigned int8 color);
void GDispSetAttrb(unsigned int16 row, unsigned int16 col, unsigned int8 mode);
void GDispDefCGChar(unsigned int8 id, unsigned char *pat);
void GDispCGChar(unsigned int8 id);
void GDispCGCharAt(unsigned int16 row, unsigned int16 col, unsigned int8 id);
void GDispBlkIcon32X32At(unsigned int16 row, unsigned int16 col);
void GDispPixFontAt(unsigned int16 X, unsigned int16 Y, unsigned char* textptr, unsigned char size, int1 color);
void glcd_3Dbox(int16 x,int16 y,int16 width, int16 height, int depth, int1 color);
* HARDWARE SPECIFIC
#define GDispChipEn LCD_CE = 0 /* Low level Chip Enable macro */
#define GDispChipDi LCD_CE = 1 /* Low level Chip Disable macro */
#define GDispCmdWr LCD_DATA_TRIS = 0x00; \
LCD_RD = 1; LCD_CD = 1; \
LCD_WR = 0 /* Low level command write macro */
#define GDispCmdRd LCD_DATA_TRIS = 0xFF; \
LCD_RD = 0; LCD_CD = 1; \
LCD_WR = 1 /* Low level command read macro */
#define GDispDatWr LCD_DATA_TRIS = 0x00; \
LCD_RD = 1; LCD_CD = 0; \
LCD_WR = 0 /* Low level data write macro */
#define GDispDatRd LCD_CD = 0; LCD_WR = 1 /* Low level data read macro */
void GDispInitPort(void);
void GDispBusyChk(void);
void GDispAutoWrChk(void);
void GDispDataWr(unsigned char data);
void GDispAutoDataWr(unsigned char data);
void GDispCmdSend(unsigned char cmd);
sudarsan
| font 5x7.h |
Posted: Thu Nov 08, 2012 1:11 am |
const unsigned char FONT1[51][5] =
0x00, 0x00, 0x00, 0x00, 0x00, // SPACE
0x00, 0x00, 0x5F, 0x00, 0x00, // !
0x00, 0x03, 0x00, 0x03, 0x00, // "
0x14, 0x3E, 0x14, 0x3E, 0x14, // #
0x24, 0x2A, 0x7F, 0x2A, 0x12, // $
0x43, 0x33, 0x08, 0x66, 0x61, // %
0x36, 0x49, 0x55, 0x22, 0x50, // &
0x00, 0x05, 0x03, 0x00, 0x00, // '
0x00, 0x1C, 0x22, 0x41, 0x00, // (
0x00, 0x41, 0x22, 0x1C, 0x00, // )
0x14, 0x08, 0x3E, 0x08, 0x14, // *
0x08, 0x08, 0x3E, 0x08, 0x08, // +
0x00, 0x50, 0x30, 0x00, 0x00, // ,
0x08, 0x08, 0x08, 0x08, 0x08, // -
0x00, 0x60, 0x60, 0x00, 0x00, // .
0x20, 0x10, 0x08, 0x04, 0x02, // /
0x3E, 0x51, 0x49, 0x45, 0x3E, // 0
0x04, 0x02, 0x7F, 0x00, 0x00, // 1
0x42, 0x61, 0x51, 0x49, 0x46, // 2
0x22, 0x41, 0x49, 0x49, 0x36, // 3
0x18, 0x14, 0x12, 0x7F, 0x10, // 4
0x27, 0x45, 0x45, 0x45, 0x39, // 5
0x3E, 0x49, 0x49, 0x49, 0x32, // 6
0x01, 0x01, 0x71, 0x09, 0x07, // 7
0x36, 0x49, 0x49, 0x49, 0x36, // 8
0x26, 0x49, 0x49, 0x49, 0x3E, // 9
0x00, 0x36, 0x36, 0x00, 0x00, // :
0x00, 0x56, 0x36, 0x00, 0x00, // ;
0x08, 0x14, 0x22, 0x41, 0x00, // <
0x14, 0x14, 0x14, 0x14, 0x14, // =
0x00, 0x41, 0x22, 0x14, 0x08, // >
0x02, 0x01, 0x51, 0x09, 0x06, // ?
0x3E, 0x41, 0x59, 0x55, 0x5E, // @
0x7E, 0x09, 0x09, 0x09, 0x7E, // A
0x7F, 0x49, 0x49, 0x49, 0x36, // B
0x3E, 0x41, 0x41, 0x41, 0x22, // C
0x7F, 0x41, 0x41, 0x41, 0x3E, // D
0x7F, 0x49, 0x49, 0x49, 0x41, // E
0x7F, 0x09, 0x09, 0x09, 0x01, // F
0x3E, 0x41, 0x41, 0x49, 0x3A, // G
0x7F, 0x08, 0x08, 0x08, 0x7F, // H
0x00, 0x41, 0x7F, 0x41, 0x00, // I
0x30, 0x40, 0x40, 0x40, 0x3F, // J
0x7F, 0x08, 0x14, 0x22, 0x41, // K
0x7F, 0x40, 0x40, 0x40, 0x40, // L
0x7F, 0x02, 0x0C, 0x02, 0x7F, // M
0x7F, 0x02, 0x04, 0x08, 0x7F, // N
0x3E, 0x41, 0x41, 0x41, 0x3E, // O
0x7F, 0x09, 0x09, 0x09, 0x06, // P
0x1E, 0x21, 0x21, 0x21, 0x5E, // Q
0x7F, 0x09, 0x09, 0x09, 0x76 // R
const unsigned char FONT2[44][5]=
0x26, 0x49, 0x49, 0x49, 0x32, // S
0x01, 0x01, 0x7F, 0x01, 0x01, // T
0x3F, 0x40, 0x40, 0x40, 0x3F, // U
0x1F, 0x20, 0x40, 0x20, 0x1F, // V
0x7F, 0x20, 0x10, 0x20, 0x7F, // W
0x41, 0x22, 0x1C, 0x22, 0x41, // X
0x07, 0x08, 0x70, 0x08, 0x07, // Y
0x61, 0x51, 0x49, 0x45, 0x43, // Z
0x00, 0x7F, 0x41, 0x00, 0x00, // [
0x02, 0x04, 0x08, 0x10, 0x20, // \
0x00, 0x00, 0x41, 0x7F, 0x00, // ]
0x04, 0x02, 0x01, 0x02, 0x04, // ^
0x40, 0x40, 0x40, 0x40, 0x40, // _
0x00, 0x01, 0x02, 0x04, 0x00, // `
0x20, 0x54, 0x54, 0x54, 0x78, // a
0x7F, 0x44, 0x44, 0x44, 0x38, // b
0x38, 0x44, 0x44, 0x44, 0x44, // c
0x38, 0x44, 0x44, 0x44, 0x7F, // d
0x38, 0x54, 0x54, 0x54, 0x18, // e
0x04, 0x04, 0x7E, 0x05, 0x05, // f
0x08, 0x54, 0x54, 0x54, 0x3C, // g
0x7F, 0x08, 0x04, 0x04, 0x78, // h
0x00, 0x44, 0x7D, 0x40, 0x00, // i
0x20, 0x40, 0x44, 0x3D, 0x00, // j
0x7F, 0x10, 0x28, 0x44, 0x00, // k
0x00, 0x41, 0x7F, 0x40, 0x00, // l
0x7C, 0x04, 0x78, 0x04, 0x78, // m
0x7C, 0x08, 0x04, 0x04, 0x78, // n
0x38, 0x44, 0x44, 0x44, 0x38, // o
0x7C, 0x14, 0x14, 0x14, 0x08, // p
0x08, 0x14, 0x14, 0x14, 0x7C, // q
0x00, 0x7C, 0x08, 0x04, 0x04, // r
0x48, 0x54, 0x54, 0x54, 0x20, // s
0x04, 0x04, 0x3F, 0x44, 0x44, // t
0x3C, 0x40, 0x40, 0x20, 0x7C, // u
0x1C, 0x20, 0x40, 0x20, 0x1C, // v
0x3C, 0x40, 0x30, 0x40, 0x3C, // w
0x44, 0x28, 0x10, 0x28, 0x44, // x
0x0C, 0x50, 0x50, 0x50, 0x3C, // y
0x44, 0x64, 0x54, 0x4C, 0x44, // z
0x00, 0x08, 0x36, 0x41, 0x41, // {
0x00, 0x00, 0x7F, 0x00, 0x00, // |
0x41, 0x41, 0x36, 0x08, 0x00, // }
0x02, 0x01, 0x02, 0x04, 0x02 // ~
