The same old float printf problem
Goto page Previous  1, 2
hadeelqasaimeh
PostPosted: Tue Mar 27, 2007 5:59 pm     Reply with quote
thank you
i will try now
hadeelqasaimeh
PostPosted: Wed Mar 28, 2007 4:33 am     Reply with quote
oh my god ,,each time i find new proplem
first of all here is a test code:
#include <16f877a.h>
#include <string.h>
#fuses xt,NOWDT,NOLVP
#include <stdlib.h>
#include <ftoa_ts.c>
static char RX[15] ,MX[10],S1[20],S2[20], buffer[20];
float value;
char prec, format;
int8 i,j;
void main() {
      prec=0;
      format='f';
      strcpy(RX,"1111");
      strcpy(MX,"2222");
      strcpy(S1,"*");
      strcpy(S2,"#");
      value=22;
while (1)
{/      putc('A');
      ftoa(value, buffer, prec, format);
      putc('B');
      strcat(S1,RX);
      putc('C');
      strcat(S1,MX);
      putc('D');
      strcat(S1,S2);
      putc('E');
      strcat(S1,buffer);
      putc('F');
i see the output on hyperterminal as the following:
ABCDEFABCDEFABCD
then lock up
also i try the following:
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
//#include "lcd_kbd1.c"
#include <stdlib.h>
float f;
char buffer[30];
char prec;
char format;
float f1 = 1;
     [color=red] prec = 1;[/color]
      format = 'f';
    while (TRUE)
      ftoa(f1, buffer, prec, format);
   printf("%s",buffer);
      f1=f1 + 2;
output:
1.0
3.0
5.0
7.0
9.00
11.0
13.000.0
13.0
15.013.0
15.013.0
14.9
17.0
19.0
21.0
23.0
25.0
as u see there is error
i need to get large numbers
so i change the following
float f1 = 11111;
      prec = 0;
and
      f1=f1 + 11111;
output was
11111
22221
33267
]‹++0
55405
64666
77777
88888
99999
111110
other sample
288886
299997
311107
322219
333330
344441
003
ھ
366663
377774
388885
399996
411107
other sample:
955546
966657
977768
988879
999990
1011101
1022212
1033323
1044433
1055545
after all this i try other way
#include <string.h>
#include <stdlib.h>
int16 value;
//char prec, format;
int8 i,j;
void main() {
   value= 1;
   strcpy(S1,"#\r\n");
while(1) {
    //printf("*1$&","%04.3w",value,"#\r\n");
         printf("%6.3f *1$&",value,"%s ",S1);
  // printf("%04.3f",value*1.2207E-3);
   value= value+3;
i want to get value and send:
*1$&value#
and then recieve it on other pic and get it a gain
sorry Embarassed
hadeelqasaimeh
PostPosted: Wed Mar 28, 2007 4:35 am     Reply with quote
http://www.ccsinfo.com/forum/viewtopic.php?p=78127&sid=26670b91d4d566859412fb1f7a93a5e4
i use this link
PostPosted: Wed Mar 28, 2007 11:44 am     Reply with quote
What's your compiler version ? I copied and pasted your test program
into MPLAB and compiled it first with vs. 3.249 and then with vs. 4.030.
I ran it in the MPLAB simulator, and used 'UART1' to display the results
in the Output Window. I added a '\r' to your printf statement, to get
each number displayed on a new line. It worked absolutely perfectly.
1.0
3.0
5.0
7.0
9.0
11.0
13.0
15.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
31.0
33.0
etc.
Post your compiler version.
hadeelqasaimeh
PostPosted: Wed Mar 28, 2007 3:42 pm     Reply with quote
version 3.249
PostPosted: Wed Mar 28, 2007 3:56 pm     Reply with quote
I installed PCM vs. 3.249. I copied and pasted your program into an
MPLAB project. I added one line, to do a carriage-return/linefeed after
displaying the string. I compiled and programmed it into a 16F877A
on my PicDem2-Plus board. It works. I let it run for a few minutes
while I was typing this in, and it never fails. It always works.
I suggest that you re-install your compiler. I can't really help any more.
Here is the output, displayed in a terminal window on my PC:
1.0
3.0
5.0
7.0
9.0
11.0
13.0
15.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
31.0
Here is the test program:
#include <stdlib.h>
float f;
char buffer[30];
char prec;
char format;
float f1 = 1;
prec = 1;
format = 'f';
while (TRUE)
   printf("\n\r");   // Added this line.
   f1=f1 + 2;
hadeelqasaimeh
PostPosted: Wed Mar 28, 2007 4:19 pm     Reply with quote
i will try
thank you
Page 2 of 2
