hadeelqasaimeh
Posted: Tue Mar 27, 2007 5:59 pm |
thank you
i will try now |
hadeelqasaimeh
Posted: Wed Mar 28, 2007 4:33 am |
oh my god ,,each time i find new proplem
first of all here is a test code:
Code: | #include <16f877a.h>
#include <string.h>
#fuses xt,NOWDT,NOLVP
#include <stdlib.h>
#include <ftoa_ts.c>
static char RX[15] ,MX[10],S1[20],S2[20], buffer[20];
float value;
char prec, format;
int8 i,j;
void main() {
prec=0;
format='f';
strcpy(RX,"1111");
strcpy(MX,"2222");
strcpy(S1,"*");
strcpy(S2,"#");
value=22;
while (1)
{/ putc('A');
ftoa(value, buffer, prec, format);
putc('B');
strcat(S1,RX);
putc('C');
strcat(S1,MX);
putc('D');
strcat(S1,S2);
putc('E');
strcat(S1,buffer);
putc('F');
i see the output on hyperterminal as the following:
then lock up
also i try the following:
#fuses XT, NOWDT, PUT, BROWNOUT, NOLVP
//#include "lcd_kbd1.c"
#include <stdlib.h>
float f;
char buffer[30];
char prec;
char format;
float f1 = 1;
[color=red] prec = 1;[/color]
format = 'f';
while (TRUE)
ftoa(f1, buffer, prec, format);
printf("%s",buffer);
f1=f1 + 2;
output:
Quote: |
1.0
3.0
5.0
7.0
9.00
11.0
13.000.0
13.0
15.013.0
15.013.0
14.9
17.0
19.0
21.0
23.0
25.0 |
as u see there is error
i need to get large numbers
so i change the following
Code: | float f1 = 11111;
prec = 0;
and
output was
Quote: | 11111
22221
33267
]‹++0
55405
64666
77777
88888
99999
111110 |
other sample
Quote: | 288886
299997
311107
322219
333330
344441
003
ھ
366663
377774
388885
399996
411107 |
other sample:
Quote: | 955546
966657
977768
988879
999990
1011101
1022212
1033323
1044433
1055545 |
after all this i try other way
#include <string.h>
#include <stdlib.h>
int16 value;
//char prec, format;
int8 i,j;
void main() {
value= 1;
strcpy(S1,"#\r\n");
while(1) {
//printf("*1$&","%04.3w",value,"#\r\n");
printf("%6.3f *1$&",value,"%s ",S1);
// printf("%04.3f",value*1.2207E-3);
value= value+3;
i want to get value and send:
and then recieve it on other pic and get it a gain
sorry |
hadeelqasaimeh
Posted: Wed Mar 28, 2007 11:44 am |
What's your compiler version ? I copied and pasted your test program
into MPLAB and compiled it first with vs. 3.249 and then with vs. 4.030.
I ran it in the MPLAB simulator, and used 'UART1' to display the results
in the Output Window. I added a '\r' to your printf statement, to get
each number displayed on a new line. It worked absolutely perfectly.
Quote: |
1.0
3.0
5.0
7.0
9.0
11.0
13.0
15.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
31.0
33.0
etc. |
Post your compiler version. |
hadeelqasaimeh
Posted: Wed Mar 28, 2007 3:42 pm |
version 3.249 |
Posted: Wed Mar 28, 2007 3:56 pm |
I installed PCM vs. 3.249. I copied and pasted your program into an
MPLAB project. I added one line, to do a carriage-return/linefeed after
displaying the string. I compiled and programmed it into a 16F877A
on my PicDem2-Plus board. It works. I let it run for a few minutes
while I was typing this in, and it never fails. It always works.
I suggest that you re-install your compiler. I can't really help any more.
Here is the output, displayed in a terminal window on my PC:
Quote: |
1.0
3.0
5.0
7.0
9.0
11.0
13.0
15.0
17.0
19.0
21.0
23.0
25.0
27.0
29.0
31.0
Here is the test program:
#include <stdlib.h>
float f;
char buffer[30];
char prec;
char format;
float f1 = 1;
prec = 1;
format = 'f';
while (TRUE)
printf("\n\r"); // Added this line.
f1=f1 + 2;
hadeelqasaimeh
Posted: Wed Mar 28, 2007 4:19 pm |
i will try
thank you |
