Syntax of structs
Backfire
Syntax of structs
PostPosted: Thu Oct 23, 2025 6:05 am     Reply with quote
Hi all,
I'm hoping someone can shed some light on an issue I've been facing. I am currently working on a library that I am porting over to use the CCS compiler, and a large amount of the library is implemented as structs of data.
I would like to typedef them to improve readability; but when it comes to compiling I see failure at compilation time if my code is as shown in Example #2. However I was under the impression that both Example #1 and Example #2 are valid 'C'...?
Thanks in advance for any help!
//Example #1 - Compiles without issue
typedef struct
   int8 Var1;
   int8 ByteArray[];
}ExampleStruct;
ExampleStruct MyStruct = {0x01, 0x00};
//Example #2 - Fails compilation with Error "Expecting a ("
typedef struct ExampleStruct
   int8 Var1;
   int8 ByteArray[];
PostPosted: Thu Oct 23, 2025 10:07 am     Reply with quote
The former is the correct syntax. the later generates an anonymous structure type, which some compilers will accept, but is not how K&R
suggests this is done.
The really full syntax, would be to give the structure a name, and then
give the type a name as well. So (for example)
typedef structure datanode {
   unsigned int16 size;
   unsigned int16 next_prtr;
} datanode_t;
//then access as
datanode_t node;
Which makes the type nice and obviously a type (_t), and also gives
the structure itself a name.
Backfire
PostPosted: Thu Oct 23, 2025 12:02 pm     Reply with quote
Hi Ttelmah,
and thanks for your reply.
I'm a little confused though, my Example #1 is surely the "anonymous structure type"?
I thought my Example #2, was defined in a more 'C standard compliant' format, yet it is Example #2 that fails.
This just seemed like a compiler quirk. Is this behaviour somehow being caused by the 'Flexible Array Member (ByteArray)' I am using?
I will be using your recommened full syntax style at any rate moving forwards, thanks again.
bkamen
PostPosted: Wed Oct 29, 2025 8:45 pm     Reply with quote
} datanode_t;
//then access as
datanode_t node;
And it's worth mentioning that the convention using "_t" is (to my travels) how all the Unix/Linux pros/veterans typedef defines stuff.
So "get used to it now. you're going to see it a lot". Smile Razz
PostPosted: Wed Oct 29, 2025 11:51 pm     Reply with quote
Yes. Also the using ALL_CAPITALS for macros.
Little 'standards' that make interpretation much easier.
