Send Nibble by printf- pic18f26k22
AlbertCharles
PostPosted: Tue Aug 12, 2025 5:35 am     Reply with quote
Hi guys, i need to send  one size of file with 36k = 36 * 1024 = 36864 bytes
 36kb, converted to Hexadecimal , i have  0x9000.
However,  I need to show that hexa byte in parts.
In the following way:  spliting 0x900  in  two parts , like that, 0x90    and   0x00.
 Can someone help me?    ( CCS 5.115)
#include <18F26K22.h>
#fuses   NOWDT,NOBROWNOUT,NOPUT,NOMCLR  ,PLLEN ,INTRC_IO
#use delay(clock= 64MHZ)
#use rs232(baud=9600, xmit=PIN_C0, rcv=PIN_C1)
void main(){
  unsigned char myByte = 0x9000;
  unsigned char FirstP;
  unsigned char SecondP;
  FirstP = (myByte >> 8) & 0x0F;
  SecondP = myByte & 0x0F;
  printf("Original byte: %X\n", myByte);     //  ==>  00  ??
  printf("First part: %X\n", FirstP); //  ==>  00  ??
  printf("Second part: %X\n", SecondP);   //  ==>  00  ??
gaugeguy
PostPosted: Tue Aug 12, 2025 6:17 am     Reply with quote
0x9000 is not a byte. It is a 16 bit integer.
0x90 is not a nibble. It is a byte (8 bit integer).
PostPosted: Tue Aug 12, 2025 8:14 am     Reply with quote
The biggest hurdle is that 'USE RS-232' doesn't allow for 4 bit data transmission ! You'll need to create your own 'driver' or 'function' to send the 4 bits( aka nibble or nybble). This will have to be 'bit banged' and NOT use the internal UART.
Splitting bytes into nibbles is easy though.
Curious as to what is going to receive the data. Communicating using 4 data bits is not very common.
Jerson
Re: Send Nibble by printf- pic18f26k22
PostPosted: Tue Aug 12, 2025 8:15 am     Reply with quote
AlbertCharles wrote:
Hi guys, i need to send  one size of file with 36k = 36 * 1024 = 36864 bytes in nibbles.
However, on the other side, I need to receive the hexa byte in nibbles.
In the following way:  spliting 0x900  in   0x90    and 0x00.
void main(){
  unsigned char highNibble;
  unsigned char lowNibble;
  highNibble = (myByte >> 4) & 0x0F;
  lowNibble = myByte & 0x0F;
  printf("High nibble: %X\n", highNibble); //  ==>  00  ??
  printf("Low nibble: %X\n", lowNibble);   //  ==>  00  ??
You could try this
unsigned int myWord = 0x9000;
and then
printf("the word is %04X\n", myWord); // print 4 hex digits with leading 0s
which will print out 9000 <LF> where <LF> is the expansion for the \n specifier.
If you'd rather do it in bytes, then you would print an unsigned char with the %02X specifier which will put out 2 hex digits
AlbertCharles
PostPosted: Tue Aug 12, 2025 8:27 am     Reply with quote
Gaugeguy, ( Tnks fou u repply!)
I don't know if I expressed myself badly, but in short, I need to convert the number 38864 into hexadecimal which gives me 0x9000. After that, I need to divide them into parts (nibble) and send them (e.g.: 0x90 then 0x00). Each one by printf.
AlbertCharles
PostPosted: Tue Aug 12, 2025 8:51 am     Reply with quote
Mr. gaugeguy, Mr. temtronic and Mr Jerson,
i edited and corrected my post. Please review it.!!
Mny thnks fou u repply.
PostPosted: Tue Aug 12, 2025 9:05 am     Reply with quote
As others have said, you seem to be misunderstanding what a nibble 'is'.
On the hexadecimal number 0x8000, each of the digits corresponds to a
nibble. A nibble is just 4 bits. So in 'nibbles', there are four characters
to send. Yet you are talking about sending bytes 0x80, is a byte, not a
nibble.
Are you then wanting to send bytes?. If so, what format do you want to
send them in?. As a raw byte?. As hex. As decimal?.
You also then try to store a 16bit value into an int8. Not going to fit.
You seem to be trying to send bytes in hex. If so:
  unsigned int16 myWhole = 0x9000; //this value won't fit in a char
  printf("Original value: %04X\n", myWhole);     //  ==>  9000
  printf("High byte: %02X\n", make8(myWhole,1)); //  ==>  90
  printf("Low byte: %02x\n", make8(myWhole,0));   //  ==>  00
AlbertCharles
PostPosted: Tue Aug 12, 2025 9:13 am     Reply with quote
Mr. Thelmah, regarding the nibbles, I really expressed myself poorly. I know the difference between them. I corrected my post above.
Do I still apply your correction to the code?
PostPosted: Tue Aug 12, 2025 9:19 am     Reply with quote
Yes.
What I posted (if I typed it right, on a touch screen, not my normal desktop),
Will output the separate bytes as the comments show.
AlbertCharles
PostPosted: Tue Aug 12, 2025 9:23 am     Reply with quote
Mny thnks....I´ll try.
AlbertCharles
PostPosted: Tue Aug 12, 2025 10:03 am     Reply with quote
Mr Thelmah:
Original value: 0000 // => 9000 ???
High byte: 90
Low byte: 00
gaugeguy
PostPosted: Tue Aug 12, 2025 1:21 pm     Reply with quote
Post your current code.
PostPosted: Wed Aug 13, 2025 2:00 am     Reply with quote
%04Lx
Problem is that 'x' on its own handles 8 bit integers. For the 16 bit value
you need the added 'L' (long).
I would have expected there to have been a warning message on the
compile for this.
jeremiah
PostPosted: Wed Aug 13, 2025 7:37 am     Reply with quote
needs to be changed to:
unsigned int16 myWord = 0x9000;
So it is big enough to hold the value you want. You'll need to change all references of myByte to myWord
