ICD U64 data monitoring
tripper269
PostPosted: Fri Feb 23, 2018 3:36 pm     Reply with quote
Hello Everyone,
Has anyone used data streaming with ICD U64, as explained in the below link
http://www.ccsinfo.com/content.php?page=stream_icd_offer
I tried but couldn't make it.
PostPosted: Fri Feb 23, 2018 5:12 pm     Reply with quote
I studied this by compiling the following test program and looking at
the .LST file. I didn't test it with an ICD64 in actual operation.
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#use rs232(ICD)
printf("Start \n\r");
while(TRUE);
Conclusions:
1. It uses a software UART (bit-banged).
2. It transmits at 38400 baud.
3. It defaults to transmitting on Pin B7 and receiving on Pin B6.
4. You can change the transmit pin to Pin C6 by doing this:
#use rs232(ICD, xmit=PIN_C6)
5. You can change the default receive pin to C7 by doing this:
#use rs232(ICD, xmit=PIN_C6, rcv=PIN_C7)
6. Adding the #use rs232(ICD) line causes the compiler to insert a 4.5
second delay at the start of main(). The program won't do anything until
that delay has passed. I verified this delay time with the MPLAB v8.92
simulator's stopwatch feature.
allenhuffman
Re: ICD U64 data monitoring
PostPosted: Fri Jul 05, 2019 10:45 am     Reply with quote
tripper269 wrote:
Hello Everyone,
Did you ever figure it out?
Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
http://www.whywouldyouwanttodothat.com ?
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606.
PostPosted: Fri Jul 05, 2019 11:39 am     Reply with quote
CCS Data Streaming Video Tutorial:
https://www.youtube.com/watch?v=EnSazS39MeA
allenhuffman
PostPosted: Fri Jul 05, 2019 12:21 pm     Reply with quote
Fantastic! That helped.
Running it using "Build & Run" did pop up the terminal, which helps.
I have yet to get any output when in Debug mode, though.
At least now I know it works. Thank you so much.
jeremiah
PostPosted: Fri Jul 05, 2019 7:43 pm     Reply with quote
it won't work in debug mode. It uses the same pins that debug mode does.
