LCD Do not initialize using PORTs A and E.
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Fri Sep 29, 2017 9:03 am     Reply with quote
I have to ask, again, why don't you use a known, good KBD driver, the flex_kbd.c version?
It works, can be modifed for any set I/O pins and oh yeah, works.
There's even an ISR based one in the code library, though I've never tried it.
Jay
jacktaylor
temtronic KDB driver
PostPosted: Sat Sep 30, 2017 5:20 pm     Reply with quote
Temtronic! So where in this library will I change working with the pins RC0, RC1 and RC2 for the columns and RD0, RD1, RD2, RD3 for the lines? For these are the connected pins available for the keyboard on my board.. This is why I could not use this driver.
////                             KBDD.C                                ////
////                  Generic keypad scan driver                       ////
////  kbd_init()   Must be called before any other function.           ////
////  c = kbd_getc(c)  Will return a key value if pressed or /0 if not ////
////                   This function should be called frequently so as ////
////                   not to miss a key press.                        ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
////////////////// The following defines the keypad layout on port D
Source file mostly deleted.
Reason: CCS forum rule #10:
10. Don't post the CCS example code or drivers, or ask for such code and drivers
Forum rules:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
- Forum Moderator
PostPosted: Sat Sep 30, 2017 7:22 pm     Reply with quote
What you posted (and shouldn't have...CCS forum rule...) is their driver NOT the 'flexible keypad driver'.
\This link...
http://www.ccsinfo.com/forum/viewtopic.php?t=26333
should get you there...
if not, just goto the code library, it's about 7 or 8 entries from the top.
I've been using a $2 3x4 keypad with just 10K pullups attached to an 18F46K22 for about 3 months and no problems.
Someone has posted an ISR driven version, though I've not tested it, too little time, too many outdoor chores to do before Old Man Winter arrives...
Jay
jacktaylor
variable number did not print on lcd
PostPosted: Tue Oct 03, 2017 3:25 pm     Reply with quote
Hello friends! Could someone explain to me why variable number did not print on lcd? or print and the value does not appear or is reset, making it impossible to be displayed?
// Program scans matrix keyboard and flashes LED number of times according to key pressed.
#include <16f877a.h>
#fuses hs, nowdt, nolvp, put, brownout
#use delay (clock=20M)
#use fast_io(a)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
#define LCD_DB4   PIN_A4
#define LCD_DB5   PIN_A3
#define LCD_DB6   PIN_A2
#define LCD_DB7   PIN_A1
#define LCD_RS    PIN_E0
#define LCD_E     PIN_A5
#include <lcd4bitsMicrostronic.c>
//****Set Keyboard Keyboard Pins.
//#define col0 PIN_C0
#define col0 PIN_E1
#define col1 PIN_C1
#define col2 PIN_C2
#define row0 PIN_D0
#define row1 PIN_D1
#define row2 PIN_D2
#define row3 PIN_D3
//*** Global Variables
 #define Led1 PIN_D4
 #define Led2 PIN_D5
 #define Led3 PIN_D6
char control = 0x01;    // Keyboard control variable.!!!!created to scan the columns.
char cont =    0x00;    // Interrupt control !!! Timer counter increment variable 0.
int number = 0x00;           // Variable stores the keystroke number
//***prototype das funçoes
void pulse(char teclakeypad); // function returns keyboard number and shows on LCD and LED flashes.
//** Interrupt directive of TIMER0.
#int_timer0
void TIMER0(void)
                   //  250*0,2us*256(prescaler)= 13ms
    cont++;
    if (cont == 17)    // 13ms x17= 0,22ms
         output_toggle(Led1);
    if(input(col0) && control == 0x01)  // column 1 at high level? control equal to 1?
      control = 0x02;
      output_low(col0);
      output_high(col1);
      output_high(col2);
      if (!input(row0))       pulse(1);
      else if (!input(row1)) pulse (4);
      else if (!input(row2)) pulse (7);
      else if (!input(row3)) pulse (11);
    else if(input(col1)&& control == 0x02)
      control = 0x03;
      output_high(col0);
      output_low (col1);
      output_high(col2);
      if (!input(row0)) pulse(2);
      else if (!input(row1)) pulse (5);
      else if (!input(row2)) pulse (8);
      else if (!input(row3)) pulse (0);
    else if(input(col2)&& control == 0x03)
      control = 0x01;
      output_high(col0);
      output_high(col1);
      output_low(col2);
      if (!input(row0)) pulse(3);
      else if (!input(row1)) pulse (6);
      else if (!input(row2)) pulse (9);
      else if (!input(row3)) pulse (12);
       } //  End Else If
   cont=0x00;
   set_timer0(0);
//** Inicio da main
   set_tris_a(0b00000001);//RA0 as input.
   set_tris_c(0x00);
   set_tris_d(0x0f);
   set_tris_e(0x00);// Port_E as output
   output_a(0x00);
   output_c(0x07);
   output_d(0x0f);
   output_E(0x02);
   setup_timer_0(rtcc_internal|rtcc_div_256);
   set_timer0(0);
   lcd_init();
   lcd_putc("\fEnter password:");
   while(1)  //
   }// End while(true)
 }// End da main
//****** void pulse function, the led flashes the number of times the key is pressed
void pulse (char teclakeypad)
   char i;
   number = teclakeypad;
   lcd_gotoxy(1,1);
   printf(lcd_putc,"\fnumber entered:");
   lcd_gotoxy(7,2);
   if     (number == 11) lcd_putc("*");
   else if(number == 12) lcd_putc("#");
   else lcd_putc(number);
 for (i=0; i<teclakeypad; i++)
         output_high(Led3);
         delay_ms (400);
         output_low(Led3);
         delay_ms (400);
PostPosted: Tue Oct 03, 2017 5:11 pm     Reply with quote
one possibility...
lcd_init();
while(1)  //
  } // End while(true)
After you display 'Enter password', your program 'loops forever' and nowhere within the Timer ISR , do you tell the PIC to print anything.
It's actually bad form to print within an ISR anyway, you should set a flag then have main() decide what to do with the flag.
Now if 'enter password' isn't being displayed on the LCD module, it's probably becuse you do not have a delay_ms(500) BEFORE the lcd_init() function. ALL LCD modules require time to 'boot/warm up/setup to default' BEFORE any micro sends commands to them. 500ms has been my standard delay for the past 25 years and every LCD module has worked fine after that delay.
Jay
jacktaylor
PostPosted: Tue Oct 03, 2017 8:29 pm     Reply with quote
Thank you friend for your help!
I was able to find the error. The error was in the print function. Substituting the command for:
lcd_gotoxy (7.2);
if (number == 11) printf (lcd_putc, "*");
else if (number == 12) printf (lcd_putc, "#");
else printf (lcd_putc, "% u", number);
It worked in my code.
      //waiting for interruption timer0
}// End while(true)
Now number is printed on the LCD according to the key pressed and led3 flashes the number set to number.
Now I will continue developing the code.
PostPosted: Wed Oct 04, 2017 7:53 am     Reply with quote
OK, Now I see that the ISR calls the 'pulse' function which has the printing inside it.
It is seriously BAD to have any delays inside an ISR and those 400ms delays are really bad.
ISRs need to be small and fast! Simply set a flag or two and get out, letting main() decide what to do otherwise the ISr will never work properly and you'll miss data or get erratic operation.
Jay
jacktaylor
PostPosted: Wed Oct 04, 2017 8:47 pm     Reply with quote
Ok thanks temtronic, thank you very much. but as an implement this is your tip: "Simply set the flag or two and get out, letting main () decide what to do otherwise." Would it be using 2 clocks?
The intention of putting these 400ms in led3 was for testing only. But I would liked it be using 2 clocks.
now I'm creating another function below the void pulse (char keykeypad) called void inputpassword (void). but the program is only executing void pulse (char keykeypad), the new function "void inputpassword (void)" will read the password saved in a vector n [5] and check if the input is right or wrong. I declare the prototype of the new function, but the program does not execute the same one.
jeremiah
PostPosted: Thu Oct 05, 2017 7:03 am     Reply with quote
Similar to the flag method, you can just put in a countdown variable in the ISR and use that in your main. For example, if I split out most of your ISR code into a separate function...we'll call it do stuff...and use a countdown variable:
#define CONT_DEFAULT 17
char cont = CONT_DEFAULT;
#int_timer0
void TIMER0(void)
   //this just causes a count down from whatever value you wanted.
   if(cont){
      cont--;
void do_stuff(){
      control = 0x02;
      output_low(col0);
      output_high(col1);
      output_high(col2);
      control = 0x03;
      output_high(col0);
      output_low (col1);
      output_high(col2);
      control = 0x01;
      output_high(col0);
      output_high(col1);
      output_low(col2);
    } //  End Else If
Then in your main, you can check the count down variable until it is 0 and then call do_stuff. Like this:
   set_tris_c(0x00);
   set_tris_d(0x0f);
   output_a(0x00);
   output_c(0x07);
   output_d(0x0f);
   output_E(0x02);
   set_timer0(0);
   lcd_init();
   while(1)  //
       while(cont);  //loop until cont is 0, then continue
       cont = CONT_DEFAULT;  //reset to start over for next pass
       do_stuff();
   }// End while(true)
 }// End da main
This will have a similar effect to your code without bogging down the ISR at all.
Note that I don't have a compiler in front of me to verify if this compiles. The idea should be ok, but you may have to tweak it if I miss copy/pasted.
jacktaylor
PostPosted: Thu Oct 05, 2017 7:23 am     Reply with quote
Thank you very much friend jeremiah. I'll work on that example.
jeremiah
PostPosted: Fri Oct 06, 2017 7:53 am     Reply with quote
One correction. I accidentally used a while loop in the ISR. I meant it to be an IF statement:
#int_timer0
void TIMER0(void)
   if(cont){
      cont--;
my apologies.
jacktaylor
variable bitest3 does not go to 1.
PostPosted: Sun Oct 15, 2017 1:25 pm     Reply with quote
Hello friends, I am doing a program for the clock. I'm having a problem with a variable that does not update its value by pressing the adj_watch button. Can anyone tell me why the value of variable bitest3 does not go to one while pressing the adj_watch button inside the void function Set _watch ()? The variable remains with the value zero. This is only part of the program. PIN_D6 is just an LED to test the program's input into the function.
#define  adj_watch   PIN_B4;
char control_adj_watch = 0x05;
void Set _watch ()                          // Set watch
     char bitest3= 0x00;
     if(input(adj_watch))
      bitest3= 0x01;
     if(!input(adj_watch) && bitest3==1)
        bitest3= 0x00;
        control_adj_watch++;        // Increment adjustment control variable
        output_high(PIN_D6);
        delay_ms(10500);
        output_low(PIN_D6);
        // Restarts control variable if it is greater than 4:
        if(control_adj_watch > 0x04)     control_adj_watch = 0x00;
         } //end if adj_watch
Rolling Eyes
PostPosted: Sun Oct 15, 2017 1:39 pm     Reply with quote
Several separate things that may be causing problems:
What pulls the pin up?. Remember a button needs a pull up resistor...
Big problem though is timing and the variable.
You arrive in the routine. Bittest3 is set to '0'.
If it sees the pin go high Bittest3 gets set to 1.
It'll only proceed into the next part if this is '1', and the input is low (remember it is low to set Bitest to 1...). Unless the input drops exactly in the few uSec between the first test and the second, this will never happen.
jacktaylor
Thank you Ttelmah
PostPosted: Mon Oct 16, 2017 11:57 am     Reply with quote
Obrigado Ttelmah.
It's true, you're right, I've seen the mistake. I modified the code. Now start bitest3 = 0x01 and when the button is pressed the same goes to zero.
What does the pin up? Pin B4 starts at 1 through a pull-up resistor. The side of the resistor that is connected to the Pin is also connected to a button, this button is connected to the GND. That is, the resistor is pull-up and when the button is pressed, it sends GND to the input B4.
I'll sequence my code. Thank you for your big help.
     char bitest3= 0x01;
        bitest3= 0x00;
        output_low(PIN_D6);
jacktaylor
Assign value to the bit of a declared variable.
PostPosted: Wed Oct 18, 2017 1:22 pm     Reply with quote
Hi friends, I have one more doubt.
When declaring a variable for example:
char test, an 8-bit memory space is reserved for this variable. The question is: How to set a value for a given bit of this variable? If I needed to put 1 only in bit 4 of the variable test What would be the command?
I know there is the #bit directive in ccs, which can be used for example with the PORT_A bits: #bit ra0 = 0x05.0; #bit ra1 = 0x05.1; #bit ra2 = 0x05.1; or with registers #bit T0IF = 0x b.2. But I do not know how to direct to the specific bit of the variable declared char test bit 4.
Could you help me how would it be?
Page 3 of 4
