[closed] 18F47J53 as usb-serial programmer not reliable :(
Goto page Previous  1, 2, 3  Next
spilz
PostPosted: Tue Nov 29, 2016 8:23 am     Reply with quote
I'm using V5.059
But the issue is still here when I don't use printf :(
By the way how to solve the issue with printf ?
PostPosted: Tue Nov 29, 2016 8:41 am     Reply with quote
You show us a 'test' program, but not the rest of this (fuses, other code etc..).
Now what you show should work, but could easily be made 'not to work' by other things. For instance if there is an INT_RDA hander that does not correctly handle the received characters after a few mSec this can completely hang the chip. Or you could have the watchdog triggering (this would be the most likely cause for a failure after a time....).
spilz
PostPosted: Tue Nov 29, 2016 8:52 am     Reply with quote
I'm not at home right now, I will post a full test program and verify if it works.
To close the parenthese about printf, how to solve it ?
PostPosted: Tue Nov 29, 2016 9:04 am     Reply with quote
You've just proved you don't have an issue with printf, since you say it does the same with putc....
spilz
PostPosted: Tue Nov 29, 2016 9:11 am     Reply with quote
But it always good to be aware when an issue is known.
PostPosted: Tue Nov 29, 2016 9:13 am     Reply with quote
your 'program' couple of posts up show that global intrrupts are enabled yet there are no 'handlers'. That alone will 'freeze the PIC'...
Jay
PostPosted: Tue Nov 29, 2016 11:10 am     Reply with quote
No it won't Temtronic.
The USB driver has a handler, and will enable the USB interrupt unless USB_ISR_POLLING is selected. It wouldn't work with this (since this requires USB_task to be called very frequently), but you must enable the global interrupt to make this all work.
Key question we still have not had answered is what compiler version?.
I'd honestly suspect the watchdog is enabled.
PostPosted: Tue Nov 29, 2016 11:54 am     Reply with quote
I was thinking he might have some other interrupt that was crashing the 'program'.
While the USB diver handles the USN interrupt, what about 'something' earlier, not seen?
So far I've only seen code 'fragments', not the whole thing. He could have 'something' ahead of the 'program' he posted a few entries ago.
also having the WDT enable could be it...no 'fuses' shown in the program either...
Bottom line we aren't getting the whole, complete picture.....so it is hard to decide what exactly is causing the problem.
Jay
PostPosted: Tue Nov 29, 2016 2:30 pm     Reply with quote
Agreed. I said this several posts ago...
spilz
PostPosted: Tue Dec 06, 2016 8:06 am     Reply with quote
this is an exemple of code :
#include <18F47J53.h>
#device ADC=16
#fuses HSPLL,SOSC_HIGH,NOCLOCKOUT,NOFCMEN
#fuses WDT128,PLL1,PLLEN,STVREN,NODEBUG,NOCPUDIV
#use delay(clock=48 MHz,crystal=4 MHz,restart_wdt)
#define LED_G_pin                      pin_B2
#define LED_R_pin                      pin_D4
#define LED_G(x)                       output_bit(LED_G_pin,x)
#define LED_R(x)                       output_bit(LED_R_pin,x)
#include <usb_cdc.h>
int32 TIMER0_Seconde = 0;
#INT_TIMER0
void  TIMER0_isr(void)
   set_timer0(18661);         // 1s overflow
   TIMER0_Seconde++;
char c =0;
void blink(){
   output_toggle(LED_R_PIN);
   if(usb_cdc_carrier.dte_present){
      usb_cdc_putc(c++);
int sequence_B_state = -1;
int32 sequence_B_Seconde_last = 0;
void sequence_B(void){
   int32 delta = 0;
   if(TIMER0_Seconde<sequence_B_Seconde_last)
      sequence_B_Seconde_last = TIMER0_Seconde;
   delta = (TIMER0_Seconde-sequence_B_Seconde_last);
   if(delta >= 7){
      blink();
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);      //1,4 s overflow
   setup_wdt(WDT_OFF);
   LED_R(0);
   LED_G(0);
   usb_init_cs();
   usb_task();
   sequence_B_state = 1;
   while(true){
      restart_wdt();
      usb_task();
      sequence_B();
      LED_G(usb_cdc_carrier.dte_present);
   reset_cpu();
The red led should toggle every 7secondes and send 1 byte, but with this code, led and sending become crasy.
So maybe an issue with timer
or an issue with memory (cf https://www.ccsinfo.com/forum/viewtopic.php?t=55734)
I'm using V5.064
any idea ?
thaks again for your help
PostPosted: Tue Dec 06, 2016 8:53 am     Reply with quote
Without looking any further, one disastrous thing. You are not enabling the voltage regulator to feed the USB
Without this, you need to be feeding 3.3v into the VUSB pin.
I suspect this should be on.
#fuses VREGEN
spilz
PostPosted: Tue Dec 06, 2016 8:55 am     Reply with quote
actually my VUSB is connected to 3.3v
should I add
#fuses VREGEN
PostPosted: Tue Dec 06, 2016 9:23 am     Reply with quote
Sorry thought you were on one of the chips with the internal VREG.
How is the Vusb connected and smoothed?.
Your unreliability is typical for a problem with this level.
The same would apply on this chip with a problem on the Vcore smoothing. What capacitor have you got on this?. How close to the chip?.
spilz
PostPosted: Tue Dec 06, 2016 9:27 am     Reply with quote
It's connected to 3.3v and has a 470nF to ground, as close as possible on pcb
PostPosted: Tue Dec 06, 2016 9:48 am     Reply with quote
What about Vcore?. They recommend a 10uF multilayer ceramic for this.
Page 2 of 3
