spilz
Posted: Tue Nov 29, 2016 8:23 am |
I'm using V5.059
But the issue is still here when I don't use printf :(
By the way how to solve the issue with printf ? |
Posted: Tue Nov 29, 2016 8:41 am |
You show us a 'test' program, but not the rest of this (fuses, other code etc..).
Now what you show should work, but could easily be made 'not to work' by other things. For instance if there is an INT_RDA hander that does not correctly handle the received characters after a few mSec this can completely hang the chip. Or you could have the watchdog triggering (this would be the most likely cause for a failure after a time....). |
spilz
Posted: Tue Nov 29, 2016 8:52 am |
I'm not at home right now, I will post a full test program and verify if it works.
To close the parenthese about printf, how to solve it ? |
Posted: Tue Nov 29, 2016 9:04 am |
| You've just proved you don't have an issue with printf, since you say it does the same with putc.... |
spilz
Posted: Tue Nov 29, 2016 9:11 am |
| But it always good to be aware when an issue is known. |
Joined: 01 Jul 2010 Posts: 9632 Location: Greensville,Ontario
Posted: Tue Nov 29, 2016 9:13 am |
your 'program' couple of posts up show that global intrrupts are enabled yet there are no 'handlers'. That alone will 'freeze the PIC'...
Posted: Tue Nov 29, 2016 11:10 am |
No it won't Temtronic.
The USB driver has a handler, and will enable the USB interrupt unless USB_ISR_POLLING is selected. It wouldn't work with this (since this requires USB_task to be called very frequently), but you must enable the global interrupt to make this all work.
Key question we still have not had answered is what compiler version?.
I'd honestly suspect the watchdog is enabled. |
Posted: Tue Nov 29, 2016 11:54 am |
I was thinking he might have some other interrupt that was crashing the 'program'.
While the USB diver handles the USN interrupt, what about 'something' earlier, not seen?
So far I've only seen code 'fragments', not the whole thing. He could have 'something' ahead of the 'program' he posted a few entries ago.
also having the WDT enable could be it...no 'fuses' shown in the program either...
Bottom line we aren't getting the whole, complete picture.....so it is hard to decide what exactly is causing the problem.
Posted: Tue Nov 29, 2016 2:30 pm |
| Agreed. I said this several posts ago... |
spilz
Posted: Tue Dec 06, 2016 8:06 am |
this is an exemple of code : | Code: | #include <18F47J53.h>
#device ADC=16
#fuses HSPLL,SOSC_HIGH,NOCLOCKOUT,NOFCMEN
#fuses WDT128,PLL1,PLLEN,STVREN,NODEBUG,NOCPUDIV
#use delay(clock=48 MHz,crystal=4 MHz,restart_wdt)
#define LED_G_pin pin_B2
#define LED_R_pin pin_D4
#define LED_G(x) output_bit(LED_G_pin,x)
#define LED_R(x) output_bit(LED_R_pin,x)
#include <usb_cdc.h>
int32 TIMER0_Seconde = 0;
#INT_TIMER0
void TIMER0_isr(void)
set_timer0(18661); // 1s overflow
TIMER0_Seconde++;
char c =0;
void blink(){
output_toggle(LED_R_PIN);
if(usb_cdc_carrier.dte_present){
usb_cdc_putc(c++);
int sequence_B_state = -1;
int32 sequence_B_Seconde_last = 0;
void sequence_B(void){
int32 delta = 0;
if(TIMER0_Seconde<sequence_B_Seconde_last)
sequence_B_Seconde_last = TIMER0_Seconde;
delta = (TIMER0_Seconde-sequence_B_Seconde_last);
if(delta >= 7){
blink();
void main() {
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256); //1,4 s overflow
setup_wdt(WDT_OFF);
LED_R(0);
LED_G(0);
usb_init_cs();
usb_task();
sequence_B_state = 1;
while(true){
restart_wdt();
usb_task();
sequence_B();
LED_G(usb_cdc_carrier.dte_present);
reset_cpu();
The red led should toggle every 7secondes and send 1 byte, but with this code, led and sending become crasy.
So maybe an issue with timer
or an issue with memory (cf https://www.ccsinfo.com/forum/viewtopic.php?t=55734)
I'm using V5.064
any idea ?
thaks again for your help |
Posted: Tue Dec 06, 2016 8:53 am |
Without looking any further, one disastrous thing. You are not enabling the voltage regulator to feed the USB
Without this, you need to be feeding 3.3v into the VUSB pin.
I suspect this should be on.
#fuses VREGEN |
spilz
Posted: Tue Dec 06, 2016 8:55 am |
actually my VUSB is connected to 3.3v
should I add ? |
Posted: Tue Dec 06, 2016 9:23 am |
Sorry thought you were on one of the chips with the internal VREG.
How is the Vusb connected and smoothed?.
Your unreliability is typical for a problem with this level.
The same would apply on this chip with a problem on the Vcore smoothing. What capacitor have you got on this?. How close to the chip?. |
spilz
Posted: Tue Dec 06, 2016 9:27 am |
| It's connected to 3.3v and has a 470nF to ground, as close as possible on pcb |
Posted: Tue Dec 06, 2016 9:48 am |
| spilz wrote: | | It's connected to 3.3v and has a 470nF to ground, as close as possible on pcb |
What about Vcore?. They recommend a 10uF multilayer ceramic for this. |
