alan
Joined: 12 Nov 2012 Posts: 358 Location: South Africa
Posted: Sun Dec 27, 2015 3:05 pm |
UART2 normally uses int rda2
Regards |
sebalitter
Posted: Thu Dec 31, 2015 10:18 am |
| alan wrote: | UART2 normally uses int rda2
Regards |
you are right, i miss the ports, C6 and C7 are from UART1, i changed now but still don't work.
#PIN_SELECT U2TX=PIN_C6
#PIN_SELECT U2RX=PIN_C7
#USE RS232(UART1,ERRORS,BAUD=9600,STREAM=WIFI,ERRORS)
Posted: Thu Dec 31, 2015 3:50 pm |
I'm surprised the compiler doesn't complain about this.
TX1, and RX1, are not relocatable.
Repeat 50*. "You can _only_ use 'select' statements on peripherals that are relocatable"....
UART1, just needs:
INT_RDA1
//and the code in this must fgetc from 'WIFI'
For UART2, you have to select the pins, and the pins used must be RP pins.
Look at table 10-13 in the data sheet, which shows what input devices can be relocated, and 10-14, which shows the relocatable output devices.
It's honestly getting like trying to pull teeth using a pair of tweezers.... |
Joined: 01 Jul 2010 Posts: 9633 Location: Greensville,Ontario
Posted: Thu Dec 31, 2015 5:12 pm |
It's gotta be a 'net' thing..seems no one actually gets real, hard copy books and reads them cover to cover anymore......
sebalitter
Posted: Sat Jan 02, 2016 8:36 am |
I will pay more attention to the documentation.
The console display wrong or even connect to uart.
- get mac
Mac Addr=00:06:66:9c:
ERR: ?-Cmd
<4.41>
- get ip
IF=UP
DHCP=SERVER
IP2TG
get ip
IF=UP
DHCP=SERVER
IP2TG
- get ssid
SleepTmr=0
WakeTmr=oxb
sometimes the first legend is
&«Kc#Ó&‹VvƦ
otrers:
server init
This is the code. Not always work.
#include <18F26J50.h>
#include <string.h>
#include <ctype.h>
#FUSES NOWDT
#FUSES NODEBUG
#FUSES NOXINST
#FUSES NOPROTECT
#FUSES NOFCMEN
#FUSES NOIESO
#FUSES NOCPUDIV
#FUSES HSPLL
#FUSES PLL3
#FUSES RTCOSC_INT
#use delay(crystal=12Mhz, clock=48Mhz)
#include <usb_cdc.h>
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
int t;
buffer[next_in]=fgetc();
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=t; // Buffer full !!
#define bkbhit (next_in!=next_out)
BYTE bgetc()
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
next_out=(next_out+1) % BUFFER_SIZE;
return(c);
void inicbuff(void){ // Inicia a \0 cbuff -------------------
int i;
for(i=0;i<BUFFER_SIZE;i++){ // Bucle que pone a 0 todos los
buffer[i]=0x00; // caracteres en el buffer
void main() {
char palabra[BUFFER_SIZE];
usb_init();
delay_us(100);
inicbuff(); // Borra buffer al inicio
enable_interrupts(int_rda);
enable_interrupts(global);
int i=0;
delay_ms(50);
delay_ms(50);
if(bkbhit)
printf(usb_cdc_putc,"%c" ,bgetc());
usb_task();
if (usb_enumerated())
if (usb_cdc_kbhit())
printf(usb_cdc_putc,"\r\n"); //limpia la pantalla
get_string_usb(palabra,BUFFER_SIZE); //obtiene la palabra escrita en el teclado
inicbuff();
if(palabra[0]!=0x00)
fputs(palabra,WIFI); // manda la palabra del teclado al modulo
Happy new year |
sebalitter
Posted: Sun Jan 03, 2016 6:30 pm |
Hello, someone
Several posters on sparkfun report having problems passing data from PICs to the RN-171 device, but no-one mentions the possibility that an inverter is needed between the two to make the communication from PIC to RN-171 work.
The ploblem is that the RN171 dont receive data from the pic or it does with wrong data.
Someone had the same problem?
Thanks |
