usb 18f26j50
Goto page Previous  1, 2
alan
PostPosted: Sun Dec 27, 2015 3:05 pm     Reply with quote
UART2 normally uses int rda2
Regards
sebalitter
PostPosted: Thu Dec 31, 2015 10:18 am     Reply with quote
Regards
you are right, i miss the ports, C6 and C7 are from UART1, i changed now but still don't work.
#PIN_SELECT U2TX=PIN_C6
 #PIN_SELECT U2RX=PIN_C7
 #USE RS232(UART1,ERRORS,BAUD=9600,STREAM=WIFI,ERRORS)
PostPosted: Thu Dec 31, 2015 3:50 pm     Reply with quote
I'm surprised the compiler doesn't complain about this.
TX1, and RX1, are not relocatable.
Repeat 50*. "You can _only_ use 'select' statements on peripherals that are relocatable"....
UART1, just needs:
INT_RDA1
//and the code in this must fgetc from 'WIFI'
For UART2, you have to select the pins, and the pins used must be RP pins.
Look at table 10-13 in the data sheet, which shows what input devices can be relocated, and 10-14, which shows the relocatable output devices.
It's honestly getting like trying to pull teeth using a pair of tweezers....
PostPosted: Thu Dec 31, 2015 5:12 pm     Reply with quote
It's gotta be a 'net' thing..seems no one actually gets real, hard copy books and reads them cover to cover anymore......
Jay
sebalitter
PostPosted: Sat Jan 02, 2016 8:36 am     Reply with quote
I will pay more attention to the documentation.
The console display wrong or even connect to uart.
- get mac
Mac Addr=00:06:66:9c:
ERR: ?-Cmd
<4.41>
- get ip
IF=UP
DHCP=SERVER
IP2TG
get ip
IF=UP
DHCP=SERVER
IP2TG
- get ssid
SleepTmr=0
WakeTmr=oxb
sometimes the first legend is
&«Kc#Ó&‹VvƦ
otrers:
server init
This is the code. Not always work.
#include <18F26J50.h>
 #include <string.h>
 #include <ctype.h>
 #FUSES NOWDT
 #FUSES NODEBUG
 #FUSES NOXINST
 #FUSES NOPROTECT
 #FUSES NOFCMEN
 #FUSES NOIESO
 #FUSES NOCPUDIV
 #FUSES HSPLL
 #FUSES PLL3
 #FUSES RTCOSC_INT
 #use delay(crystal=12Mhz, clock=48Mhz)
 #include <usb_cdc.h>
 #define BUFFER_SIZE 32
 BYTE buffer[BUFFER_SIZE];
 BYTE next_in = 0;
 BYTE next_out = 0;
 #int_rda
 void serial_isr() {
    int t;
    buffer[next_in]=fgetc();
    t=next_in;
    next_in=(next_in+1) % BUFFER_SIZE;
    if(next_in==next_out)
      next_in=t;           // Buffer full !!
 #define bkbhit (next_in!=next_out)
 BYTE bgetc()
    BYTE c;
    while(!bkbhit) ;
    c=buffer[next_out];
    next_out=(next_out+1) % BUFFER_SIZE;
    return(c);
 void inicbuff(void){ // Inicia a \0 cbuff -------------------
   int i;
   for(i=0;i<BUFFER_SIZE;i++){   // Bucle que pone a 0 todos los
     buffer[i]=0x00;          // caracteres en el buffer
 void main() {
    char palabra[BUFFER_SIZE];
    usb_init();
    delay_us(100);
    inicbuff(); // Borra buffer al inicio
    enable_interrupts(int_rda);
    enable_interrupts(global);
    int i=0;
    delay_ms(50);
        delay_ms(50);
        if(bkbhit)
            printf(usb_cdc_putc,"%c" ,bgetc());
        usb_task();
        if (usb_enumerated())
            if (usb_cdc_kbhit())
                printf(usb_cdc_putc,"\r\n");      //limpia la pantalla
                get_string_usb(palabra,BUFFER_SIZE);     //obtiene la palabra escrita en el teclado
                inicbuff();
                if(palabra[0]!=0x00)
                    fputs(palabra,WIFI);                  //  manda la palabra del teclado al modulo
Happy new year
sebalitter
PostPosted: Sun Jan 03, 2016 6:30 pm     Reply with quote
Hello, someone
Several posters on sparkfun report having problems passing data from PICs to the RN-171 device, but no-one mentions the possibility that an inverter is needed between the two to make the communication from PIC to RN-171 work.
The ploblem is that the RN171 dont receive data from the pic or it does with wrong data.
Someone had the same problem?
Page 2 of 2
