Why does this code stop
Goto page Previous  1, 2
PostPosted: Wed Feb 25, 2015 3:58 pm     Reply with quote
I just compared your .LST file with mine and they're the same. So it's
got to be a hardware problem somewhere.
PostPosted: Wed Feb 25, 2015 4:04 pm     Reply with quote
You have the RS232 passing through the LS157. Are you sure it's selected
for the correct channel ?
Ringo42
PostPosted: Wed Feb 25, 2015 4:05 pm     Reply with quote
That makes sense but if I load old code on the board it runs fine. That's what confusing me. This was part of a much larger program, I just wanted to start printing out the rssi values. When I started making changes is when it got weird. Old HEX Files Still Run. Unfortunately I don't keep old lst files.
Ringo Davis
PostPosted: Wed Feb 25, 2015 4:09 pm     Reply with quote
Can you find or re-create a source file that will run on that board ?
Ringo42
PostPosted: Wed Feb 25, 2015 4:25 pm     Reply with quote
The mux pin is what selects which 232 to use.
So when it is set incorrectly you should miss the message.
My issue is that is seems to just quit.
I tried this
#include "18f452.h"
#fuses hs,NOWDT,noprotect,put,nolvp
#device adc=10
#define TX_PIN      PIN_C6
#define RX_PIN      PIN_C7
#define BAUD_RATE 19200
#define Mux_sel     PIN_E2
#define Mux_sel2     PIN_D4
#use rs232(baud=BAUD_RATE,xmit=TX_PIN,rcv=RX_PIN,errors,bits=8,parity=N,restart_wdt)
output_low(MUX_Sel);
output_low(MUX_Sel2);
printf("Start\r\n");
printf("Just set mux sel low \n\r");
delay_ms(254);
output_high(MUX_Sel2);
output_high(MUX_Sel);
printf("Just set mux sel high \n\r");
delay_ms(254);
while(TRUE);
and I get the message that the pin went low. Then the pin goes high (both of them) and it just stops.
Damn I'm an idiot...................................
I didn't catch the the while(TRUE); at the end. I always put that in the beginning with brackets around everything so it runs forever. That is what I have been looking for.
I moved it to the front and now it works.
Guess its been way too long since I worked on this stuff.
Ringo Davis
gpsmikey
PostPosted: Wed Feb 25, 2015 11:35 pm     Reply with quote
Glad to see I'm not the only one that does things like that. Amazing how many times I have been part way through trying to explain to someone why something isn't working when I get to the "oh ..... never mind" part :-)
mikey
mikey
Page 2 of 2
