Posted: Wed Feb 25, 2015 3:58 pm |
I just compared your .LST file with mine and they're the same. So it's
got to be a hardware problem somewhere. |
Posted: Wed Feb 25, 2015 4:04 pm |
You have the RS232 passing through the LS157. Are you sure it's selected
for the correct channel ? |
Ringo42
Posted: Wed Feb 25, 2015 4:05 pm |
That makes sense but if I load old code on the board it runs fine. That's what confusing me. This was part of a much larger program, I just wanted to start printing out the rssi values. When I started making changes is when it got weird. Old HEX Files Still Run. Unfortunately I don't keep old lst files. _________________ Ringo Davis |
Posted: Wed Feb 25, 2015 4:09 pm |
| Can you find or re-create a source file that will run on that board ? |
Ringo42
Posted: Wed Feb 25, 2015 4:25 pm |
The mux pin is what selects which 232 to use.
So when it is set incorrectly you should miss the message.
My issue is that is seems to just quit.
I tried this
| Code: | #include "18f452.h"
#fuses hs,NOWDT,noprotect,put,nolvp
#device adc=10
#define TX_PIN PIN_C6
#define RX_PIN PIN_C7
#define BAUD_RATE 19200
#define Mux_sel PIN_E2
#define Mux_sel2 PIN_D4
#use rs232(baud=BAUD_RATE,xmit=TX_PIN,rcv=RX_PIN,errors,bits=8,parity=N,restart_wdt)
output_low(MUX_Sel);
output_low(MUX_Sel2);
printf("Start\r\n");
printf("Just set mux sel low \n\r");
delay_ms(254);
output_high(MUX_Sel2);
output_high(MUX_Sel);
printf("Just set mux sel high \n\r");
delay_ms(254);
while(TRUE);
and I get the message that the pin went low. Then the pin goes high (both of them) and it just stops.
Damn I'm an idiot...................................
I didn't catch the the while(TRUE); at the end. I always put that in the beginning with brackets around everything so it runs forever. That is what I have been looking for.
I moved it to the front and now it works.
Guess its been way too long since I worked on this stuff.
Thanks _________________ Ringo Davis |
gpsmikey
Posted: Wed Feb 25, 2015 11:35 pm |
Glad to see I'm not the only one that does things like that. Amazing how many times I have been part way through trying to explain to someone why something isn't working when I get to the "oh ..... never mind" part :-)
mikey _________________ mikey
