allenhuffman
Joined: 17 Jun 2019 Posts: 644 Location: Des Moines, Iowa, USA
| 5.092 Passing struct into function can generate HUGE code. |
Posted: Wed Jan 29, 2020 4:48 pm |
SUMMARY: Yes, I know one can pass the address of a structure and that's much more efficient. This is just a sample to show a problem with code generation...
EDIT: See also http://www.ccsinfo.com/forum/viewtopic.php?t=58491
We previously found a bug with accessing elements of a structure where the compiler was miscalculating the offset to the data and walking past the end of the entire structure.
I think we found another related issue. For this example, I am passing a structure (the entire structure, not a pointer) in to a function.
1) If you pass in the structure item by actual number ([0]), it generates nice small acceptable code:
| Code: | .................... ShowThing (objects.things[0]);
00452: MOV #800,W0
00454: MOV #848,W1
00456: REPEAT #15
00458: MOV [W0++],[W1++]
0045A: CALL 3DA
2) BUT, if instead of using a hard-coded number, you are using a variable to be the index -- in this case, "n = 0;", it generates much more code:
| Code: | .................... int n = 0;
0045E: CLR 82E
.................... ShowThing (objects.things[n]);
00460: MOV 82E,W4
00462: MUL.UU W4,#16,W0
00464: MOV #800,W4
00466: ADD W0,W4,W0
00468: MOV #A,W4
0046A: REPEAT #A
0046C: MOV [W0++],[W4++]
0046E: MOV W5,848
00470: MOV W6,84A
00472: MOV W7,84C
00474: MOV W8,84E
00476: MOV W9,850
00478: MOV W10,852
0047A: MOV W11,854
0047C: MOV W12,856
0047E: MOV W13,858
00480: MOV W14,85A
00482: MOV W15,85C
00484: MOV W6,84A
00486: MOV W7,84C
00488: MOV W8,84E
0048A: MOV W9,850
0048C: MOV W10,852
0048E: MOV W11,854
00490: MOV W12,856
00492: MOV W13,858
00494: MOV W14,85A
00496: MOV W15,85C
00498: MOV W0,85E
0049A: MOV W7,84C
0049C: MOV W8,84E
0049E: MOV W9,850
004A0: MOV W10,852
004A2: MOV W11,854
004A4: MOV W12,856
004A6: MOV W13,858
004A8: MOV W14,85A
004AA: MOV W15,85C
004AC: MOV W0,85E
004AE: MOV W1,860
004B0: MOV W8,84E
004B2: MOV W9,850
004B4: MOV W10,852
004B6: MOV W11,854
004B8: MOV W12,856
004BA: MOV W13,858
004BC: MOV W14,85A
004BE: MOV W15,85C
004C0: MOV W0,85E
004C2: MOV W1,860
004C4: MOV W2,862
004C6: MOV W9,850
004C8: MOV W10,852
004CA: MOV W11,854
004CC: MOV W12,856
004CE: MOV W13,858
004D0: MOV W14,85A
004D2: MOV W15,85C
004D4: MOV W0,85E
004D6: MOV W1,860
004D8: MOV W2,862
004DA: MOV W3,864
004DC: MOV W10,852
004DE: MOV W11,854
004E0: MOV W12,856
004E2: MOV W13,858
004E4: MOV W14,85A
004E6: MOV W15,85C
004E8: MOV W0,85E
004EA: MOV W1,860
004EC: MOV W2,862
004EE: MOV W3,864
004F0: MOV W4,866
004F2: MOV W11,854
004F4: MOV W12,856
004F6: MOV W13,858
004F8: MOV W14,85A
004FA: MOV W15,85C
004FC: MOV W0,85E
004FE: MOV W1,860
00500: MOV W2,862
00502: MOV W3,864
00504: MOV W4,866
00506: MOV W5,868
00508: MOV W12,856
0050A: MOV W13,858
0050C: MOV W14,85A
0050E: MOV W15,85C
00510: MOV W0,85E
00512: MOV W1,860
00514: MOV W2,862
00516: MOV W3,864
00518: MOV W4,866
0051A: MOV W5,868
0051C: MOV W6,86A
0051E: MOV W13,858
00520: MOV W14,85A
00522: MOV W15,85C
00524: MOV W0,85E
00526: MOV W1,860
00528: MOV W2,862
0052A: MOV W3,864
0052C: MOV W4,866
0052E: MOV W5,868
00530: MOV W6,86A
00532: MOV W7,86C
00534: MOV W14,85A
00536: MOV W15,85C
00538: MOV W0,85E
0053A: MOV W1,860
0053C: MOV W2,862
0053E: MOV W3,864
00540: MOV W4,866
00542: MOV W5,868
00544: MOV W6,86A
00546: MOV W7,86C
00548: MOV W8,86E
0054A: MOV W15,85C
0054C: MOV W0,85E
0054E: MOV W1,860
00550: MOV W2,862
00552: MOV W3,864
00554: MOV W4,866
00556: MOV W5,868
00558: MOV W6,86A
0055A: MOV W7,86C
0055C: MOV W8,86E
0055E: MOV W9,870
00560: CALL 3DA
3) But you can make a temp structure, and assign the array[n] to it and then pass in that temp and it works just fine:
| Code: | .................... ThingStruct tempThing;
.................... tempThing = objects.things[n];
00564: MOV 82E,W4
00566: MUL.UU W4,#16,W0
00568: MOV #800,W4
0056A: ADD W0,W4,W0
0056C: MOV #830,W1
0056E: MOV W0,W2
00570: REPEAT #15
00572: MOV.B [W2++],[W1++]
.................... ShowThing (tempThing);
00574: MOV #830,W0
00576: MOV #848,W1
00578: REPEAT #15
0057A: MOV [W0++],[W1++]
0057C: CALL 3DA
This is at the heart of our latest crash. We had rebooting system and it narrowed it down to passing in a structure using a variable for the index. If it's [0], [3], [5], etc... the code works fine, but the moment it's an index of a variable we get hundreds of lines of MOV code and it's apparently walking over memory somewhere and crashing the stack or something.
Anyway, this is just something fun I thought I'd share, not that many people pass in structures to functions. :-)[/url] _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002.
Last edited by allenhuffman on Thu Jan 30, 2020 3:08 pm; edited 3 times in total |
Posted: Wed Jan 29, 2020 6:08 pm |
| Make sure to report it to CCS support so they can fix it. |
Posted: Thu Jan 30, 2020 1:01 am |
Slightly puzzled as to the nature of the object here.
If 'objects' is an array of structures, the normal access, would be:
objects[n].things
not
objects.things[n]
as you show.
You seem to be accessing an element inside an array, that is inside a
structure, not the 'entire structure', as you describe?. |
allenhuffman
Posted: Thu Jan 30, 2020 7:11 am |
| Ttelmah wrote: | Slightly puzzled as to the nature of the object here.
objects[n].things
not
objects.things[n]
as you show.
Yep. It happens even with just one of them. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Using: 24FJ256GA106, 24EP256GP202 and 24FJ64GA002. |
allenhuffman
Posted: Thu Jan 30, 2020 8:25 am |
Here's an example that doesn't even use sub-structures. I only used that in my example because that is what we are wanting to do, so I wanted code for CCS to use that replicated the type of stuff we were using.
main.h:
| Code: | #include <24FJ256GA106.h>
#device ICSP=1
#use delay(clock=32MHz,crystal=8MHz)
#use rs232(ICD)
#case
typedef struct
char name[100];
int value;
} ObjectStruct; |
main.c:
| Code: | #include <main.h>
#define NUM_OBJECTS 2
// Prototypes
void ShowObject (ObjectStruct object);
// Globals
ObjectStruct objects[NUM_OBJECTS];
int idx;
for (idx = 0; idx < NUM_OBJECTS; idx++)
objects[idx].value = (100 + idx);
ShowObject (objects[0]);
int n = 0;
ShowObject (objects[n]);
//TODO: User Code
printf ("object.value = %d\r\n", object.value);
// End of main.c |
Results:
.................... ShowObject (objects[0]);
003EA: MOV #800,W0
003EC: MOV #8D2,W1
003EE: REPEAT #65
003F0: MOV [W0++],[W1++]
003F2: CALL 378
003F6: CLR 8CE
.................... ShowObject (objects[n]);
003F8: MOV 8CE,W4
003FA: MOV #66,W3
003FC: MUL.SS W4,W3,W0
003FE: MOV #800,W4
00400: ADD W0,W4,W0
00402: MOV #A,W4
00404: REPEAT #32
00406: MOV [W0++],[W4++]
00408: MOV W5,8D2
0040A: MOV W6,8D4
0040C: MOV W7,8D6
0040E: MOV W8,8D8
00410: MOV W9,8DA
00412: MOV W10,8DC
00414: MOV W11,8DE
00416: MOV W12,8E0
00418: MOV W13,8E2
0041A: MOV W14,8E4
0041C: MOV W15,8E6
0041E: MOV W0,8E8
00420: MOV W1,8EA
00422: MOV W2,8EC
00424: MOV W3,8EE
00426: MOV W4,8F0
00428: MOV W5,8F2
0042A: MOV W6,8F4
0042C: MOV W7,8F6
0042E: MOV W8,8F8
00430: MOV W9,8FA
00432: MOV W10,8FC
00434: MOV W11,8FE
00436: MOV W12,900
00438: MOV W13,902
0043A: MOV W14,904
0043C: MOV W15,906
0043E: MOV W0,908
00440: MOV W1,90A
00442: MOV W2,90C
00444: MOV W3,90E
00446: MOV W4,910
00448: MOV W5,912
0044A: MOV W6,914
0044C: MOV W7,916
0044E: MOV W8,918
00450: MOV W9,91A
00452: MOV W10,91C
00454: MOV W11,91E
00456: MOV W12,920
00458: MOV W13,922
0045A: MOV W14,924
0045C: MOV W15,926
0045E: MOV W0,928
00460: MOV W1,92A
00462: MOV W2,92C
00464: MOV W3,92E
00466: MOV W4,930
00468: MOV W5,932
0046A: MOV W6,934
0046C: MOV W7,936
0046E: MOV W6,8D4
00470: MOV W7,8D6
00472: MOV W8,8D8
00474: MOV W9,8DA
00476: MOV W10,8DC
00478: MOV W11,8DE
0047A: MOV W12,8E0
0047C: MOV W13,8E2
0047E: MOV W14,8E4
00480: MOV W15,8E6
00482: MOV W0,8E8
00484: MOV W1,8EA
00486: MOV W2,8EC
00488: MOV W3,8EE
0048A: MOV W4,8F0
0048C: MOV W5,8F2
0048E: MOV W6,8F4
00490: MOV W7,8F6
00492: MOV W8,8F8
00494: MOV W9,8FA
00496: MOV W10,8FC
00498: MOV W11,8FE
0049A: MOV W12,900
0049C: MOV W13,902
0049E: MOV W14,904
004A0: MOV W15,906
004A2: MOV W0,908
004A4: MOV W1,90A
004A6: MOV W2,90C
004A8: MOV W3,90E
004AA: MOV W4,910
004AC: MOV W5,912
004AE: MOV W6,914
004B0: MOV W7,916
004B2: MOV W8,918
004B4: MOV W9,91A
004B6: MOV W10,91C
004B8: MOV W11,91E
004BA: MOV W12,920
004BC: MOV W13,922
004BE: MOV W14,924
004C0: MOV W15,926
004C2: MOV W0,928
004C4: MOV W1,92A
004C6: MOV W2,92C
004C8: MOV W3,92E
004CA: MOV W4,930
004CC: MOV W5,932
004CE: MOV W6,934
004D0: MOV W7,936
004D2: MOV W8,938
004D4: MOV W7,8D6
004D6: MOV W8,8D8
004D8: MOV W9,8DA
004DA: MOV W10,8DC
004DC: MOV W11,8DE
004DE: MOV W12,8E0
004E0: MOV W13,8E2
004E2: MOV W14,8E4
004E4: MOV W15,8E6
004E6: MOV W0,8E8
004E8: MOV W1,8EA
004EA: MOV W2,8EC
004EC: MOV W3,8EE
004EE: MOV W4,8F0
004F0: MOV W5,8F2
004F2: MOV W6,8F4
004F4: MOV W7,8F6
004F6: MOV W8,8F8
004F8: MOV W9,8FA
004FA: MOV W10,8FC
004FC: MOV W11,8FE
004FE: MOV W12,900
00500: MOV W13,902
00502: MOV W14,904
00504: MOV W15,906
00506: MOV W0,908
00508: MOV W1,90A
0050A: MOV W2,90C
0050C: MOV W3,90E
0050E: MOV W4,910
00510: MOV W5,912
00512: MOV W6,914
00514: MOV W7,916
00516: MOV W8,918
00518: MOV W9,91A
0051A: MOV W10,91C
0051C: MOV W11,91E
0051E: MOV W12,920
00520: MOV W13,922
00522: MOV W14,924
00524: MOV W15,926
00526: MOV W0,928
00528: MOV W1,92A
0052A: MOV W2,92C
0052C: MOV W3,92E
0052E: MOV W4,930
00530: MOV W5,932
00532: MOV W6,934
00534: MOV W7,936
00536: MOV W8,938
00538: MOV W9,93A
0053A: MOV W8,8D8
0053C: MOV W9,8DA
0053E: MOV W10,8DC
00540: MOV W11,8DE
00542: MOV W12,8E0
00544: MOV W13,8E2
00546: MOV W14,8E4
00548: MOV W15,8E6
0054A: MOV W0,8E8
0054C: MOV W1,8EA
0054E: MOV W2,8EC
00550: MOV W3,8EE
00552: MOV W4,8F0
00554: MOV W5,8F2
00556: MOV W6,8F4
00558: MOV W7,8F6
0055A: MOV W8,8F8
0055C: MOV W9,8FA
0055E: MOV W10,8FC
00560: MOV W11,8FE
00562: MOV W12,900
00564: MOV W13,902
00566: MOV W14,904
00568: MOV W15,906
0056A: MOV W0,908
0056C: MOV W1,90A
0056E: MOV W2,90C
00570: MOV W3,90E
00572: MOV W4,910
00574: MOV W5,912
00576: MOV W6,914
00578: MOV W7,916
0057A: MOV W8,918
0057C: MOV W9,91A
0057E: MOV W10,91C
00580: MOV W11,91E
00582: MOV W12,920
00584: MOV W13,922
00586: MOV W14,924
00588: MOV W15,926
0058A: MOV W0,928
0058C: MOV W1,92A
0058E: MOV W2,92C
00590: MOV W3,92E
00592: MOV W4,930
00594: MOV W5,932
00596: MOV W6,934
00598: MOV W7,936
0059A: MOV W8,938
0059C: MOV W9,93A
0059E: MOV W10,93C
005A0: MOV W9,8DA
005A2: MOV W10,8DC
005A4: MOV W11,8DE
005A6: MOV W12,8E0
005A8: MOV W13,8E2
005AA: MOV W14,8E4
005AC: MOV W15,8E6
005AE: MOV W0,8E8
005B0: MOV W1,8EA
005B2: MOV W2,8EC
005B4: MOV W3,8EE
005B6: MOV W4,8F0
005B8: MOV W5,8F2
005BA: MOV W6,8F4
005BC: MOV W7,8F6
005BE: MOV W8,8F8
005C0: MOV W9,8FA
005C2: MOV W10,8FC
005C4: MOV W11,8FE
005C6: MOV W12,900
005C8: MOV W13,902
005CA: MOV W14,904
005CC: MOV W15,906
005CE: MOV W0,908
005D0: MOV W1,90A
005D2: MOV W2,90C
005D4: MOV W3,90E
005D6: MOV W4,910
005D8: MOV W5,912
005DA: MOV W6,914
005DC: MOV W7,916
005DE: MOV W8,918
005E0: MOV W9,91A
005E2: MOV W10,91C
005E4: MOV W11,91E
005E6: MOV W12,920
005E8: MOV W13,922
005EA: MOV W14,924
005EC: MOV W15,926
005EE: MOV W0,928
005F0: MOV W1,92A
005F2: MOV W2,92C
005F4: MOV W3,92E
005F6: MOV W4,930
005F8: MOV W5,932
005FA: MOV W6,934
005FC: MOV W7,936
005FE: MOV W8,938
00600: MOV W9,93A
00602: MOV W10,93C
00604: MOV W11,93E
00606: MOV W10,8DC
00608: MOV W11,8DE
0060A: MOV W12,8E0
0060C: MOV W13,8E2
0060E: MOV W14,8E4
00610: MOV W15,8E6
00612: MOV W0,8E8
00614: MOV W1,8EA
00616: MOV W2,8EC
00618: MOV W3,8EE
0061A: MOV W4,8F0
0061C: MOV W5,8F2
0061E: MOV W6,8F4
00620: MOV W7,8F6
00622: MOV W8,8F8
00624: MOV W9,8FA
00626: MOV W10,8FC
00628: MOV W11,8FE
0062A: MOV W12,900
0062C: MOV W13,902
0062E: MOV W14,904
00630: MOV W15,906
00632: MOV W0,908
00634: MOV W1,90A
00636: MOV W2,90C
00638: MOV W3,90E
0063A: MOV W4,910
0063C: MOV W5,912
0063E: MOV W6,914
00640: MOV W7,916
00642: MOV W8,918
00644: MOV W9,91A
00646: MOV W10,91C
00648: MOV W11,91E
0064A: MOV W12,920
0064C: MOV W13,922
0064E: MOV W14,924
00650: MOV W15,926
00652: MOV W0,928
00654: MOV W1,92A
00656: MOV W2,92C
00658: MOV W3,92E
0065A: MOV W4,930
0065C: MOV W5,932
0065E: MOV W6,934
00660: MOV W7,936
00662: MOV W8,938
00664: MOV W9,93A
00666: MOV W10,93C
00668: MOV W11,93E
0066A: MOV W12,940
0066C: MOV W11,8DE
0066E: MOV W12,8E0
00670: MOV W13,8E2
00672: MOV W14,8E4
00674: MOV W15,8E6
00676: MOV W0,8E8
00678: MOV W1,8EA
0067A: MOV W2,8EC
0067C: MOV W3,8EE
0067E: MOV W4,8F0
00680: MOV W5,8F2
00682: MOV W6,8F4
00684: MOV W7,8F6
00686: MOV W8,8F8
00688: MOV W9,8FA
0068A: MOV W10,8FC
0068C: MOV W11,8FE
0068E: MOV W12,900
00690: MOV W13,902
00692: MOV W14,904
00694: MOV W15,906
00696: MOV W0,908
00698: MOV W1,90A
0069A: MOV W2,90C
0069C: MOV W3,90E
0069E: MOV W4,910
006A0: MOV W5,912
006A2: MOV W6,914
006A4: MOV W7,916
006A6: MOV W8,918
006A8: MOV W9,91A
006AA: MOV W10,91C
006AC: MOV W11,91E
006AE: MOV W12,920
006B0: MOV W13,922
006B2: MOV W14,924
006B4: MOV W15,926
006B6: MOV W0,928
006B8: MOV W1,92A
006BA: MOV W2,92C
006BC: MOV W3,92E
006BE: MOV W4,930
006C0: MOV W5,932
006C2: MOV W6,934
006C4: MOV W7,936
006C6: MOV W8,938
006C8: MOV W9,93A
006CA: MOV W10,93C
006CC: MOV W11,93E
006CE: MOV W12,940
006D0: MOV W13,942
006D2: MOV W12,8E0
006D4: MOV W13,8E2
006D6: MOV W14,8E4
006D8: MOV W15,8E6
006DA: MOV W0,8E8
006DC: MOV W1,8EA
006DE: MOV W2,8EC
006E0: MOV W3,8EE
006E2: MOV W4,8F0
006E4: MOV W5,8F2
006E6: MOV W6,8F4
006E8: MOV W7,8F6
006EA: MOV W8,8F8
006EC: MOV W9,8FA
006EE: MOV W10,8FC
006F0: MOV W11,8FE
006F2: MOV W12,900
006F4: MOV W13,902
006F6: MOV W14,904
006F8: MOV W15,906
006FA: MOV W0,908
006FC: MOV W1,90A
006FE: MOV W2,90C
00700: MOV W3,90E
00702: MOV W4,910
00704: MOV W5,912
00706: MOV W6,914
00708: MOV W7,916
0070A: MOV W8,918
0070C: MOV W9,91A
0070E: MOV W10,91C
00710: MOV W11,91E
00712: MOV W12,920
00714: MOV W13,922
00716: MOV W14,924
00718: MOV W15,926
0071A: MOV W0,928
0071C: MOV W1,92A
0071E: MOV W2,92C
00720: MOV W3,92E
00722: MOV W4,930
00724: MOV W5,932
00726: MOV W6,934
00728: MOV W7,936
0072A: MOV W8,938
0072C: MOV W9,93A
0072E: MOV W10,93C
00730: MOV W11,93E
00732: MOV W12,940
00734: MOV W13,942
00736: MOV W14,944
00738: MOV W13,8E2
0073A: MOV W14,8E4
0073C: MOV W15,8E6
0073E: MOV W0,8E8
00740: MOV W1,8EA
00742: MOV W2,8EC
00744: MOV W3,8EE
00746: MOV W4,8F0
00748: MOV W5,8F2
0074A: MOV W6,8F4
0074C: MOV W7,8F6
0074E: MOV W8,8F8
00750: MOV W9,8FA
00752: MOV W10,8FC
00754: MOV W11,8FE
00756: MOV W12,900
00758: MOV W13,902
0075A: MOV W14,904
0075C: MOV W15,906
0075E: MOV W0,908
00760: MOV W1,90A
00762: MOV W2,90C
00764: MOV W3,90E
00766: MOV W4,910
00768: MOV W5,912
0076A: MOV W6,914
0076C: MOV W7,916
0076E: MOV W8,918
00770: MOV W9,91A
00772: MOV W10,91C
00774: MOV W11,91E
00776: MOV W12,920
00778: MOV W13,922
0077A: MOV W14,924
0077C: MOV W15,926
0077E: MOV W0,928
00780: MOV W1,92A
00782: MOV W2,92C
00784: MOV W3,92E
00786: MOV W4,930
00788: MOV W5,932
0078A: MOV W6,934
0078C: MOV W7,936
0078E: MOV W8,938
00790: MOV W9,93A
00792: MOV W10,93C
00794: MOV W11,93E
00796: MOV W12,940
00798: MOV W13,942
0079A: MOV W14,944
0079C: MOV W15,946
0079E: MOV W14,8E4
007A0: MOV W15,8E6
007A2: MOV W0,8E8
007A4: MOV W1,8EA
007A6: MOV W2,8EC
007A8: MOV W3,8EE
007AA: MOV W4,8F0
007AC: MOV W5,8F2
007AE: MOV W6,8F4
007B0: MOV W7,8F6
007B2: MOV W8,8F8
007B4: MOV W9,8FA
007B6: MOV W10,8FC
007B8: MOV W11,8FE
007BA: MOV W12,900
007BC: MOV W13,902
007BE: MOV W14,904
007C0: MOV W15,906
007C2: MOV W0,908
007C4: MOV W1,90A
007C6: MOV W2,90C
007C8: MOV W3,90E
007CA: MOV W4,910
007CC: MOV W5,912
007CE: MOV W6,914
007D0: MOV W7,916
007D2: MOV W8,918
007D4: MOV W9,91A
007D6: MOV W10,91C
007D8: MOV W11,91E
007DA: MOV W12,920
007DC: MOV W13,922
007DE: MOV W14,924
007E0: MOV W15,926
007E2: MOV W0,928
007E4: MOV W1,92A
007E6: MOV W2,92C
007E8: MOV W3,92E
007EA: MOV W4,930
007EC: MOV W5,932
007EE: MOV W6,934
007F0: MOV W7,936
007F2: MOV W8,938
007F4: MOV W9,93A
007F6: MOV W10,93C
007F8: MOV W11,93E
007FA: MOV W12,940
007FC: MOV W13,942
007FE: MOV W14,944
00800: MOV W15,946
00802: MOV W0,948
00804: MOV W15,8E6
00806: MOV W0,8E8
00808: MOV W1,8EA
0080A: MOV W2,8EC
0080C: MOV W3,8EE
0080E: MOV W4,8F0
00810: MOV W5,8F2
00812: MOV W6,8F4
00814: MOV W7,8F6
00816: MOV W8,8F8
00818: MOV W9,8FA
0081A: MOV W10,8FC
0081C: MOV W11,8FE
0081E: MOV W12,900
00820: MOV W13,902
00822: MOV W14,904
00824: MOV W15,906
00826: MOV W0,908
00828: MOV W1,90A
0082A: MOV W2,90C
0082C: MOV W3,90E
0082E: MOV W4,910
00830: MOV W5,912
00832: MOV W6,914
00834: MOV W7,916
00836: MOV W8,918
00838: MOV W9,91A
0083A: MOV W10,91C
0083C: MOV W11,91E
0083E: MOV W12,920
00840: MOV W13,922
00842: MOV W14,924
00844: MOV W15,926
00846: MOV W0,928
00848: MOV W1,92A
0084A: MOV W2,92C
0084C: MOV W3,92E
0084E: MOV W4,930
00850: MOV W5,932
00852: MOV W6,934
00854: MOV W7,936
00856: MOV W8,938
00858: MOV W9,93A
0085A: MOV W10,93C
0085C: MOV W11,93E
0085E: MOV W12,940
00860: MOV W13,942
00862: MOV W14,944
00864: MOV W15,946
00866: MOV W0,948
00868: MOV W1,94A
0086A: SUB #66,W0
0086C: MOV #8E8,W4
0086E: REPEAT #32
00870: MOV [W0++],[W4++]
00872: MOV #8EA,W4
00874: REPEAT #32
00876: MOV [W1++],[W4++]
00878: MOV #8EC,W4
0087A: REPEAT #32
0087C: MOV [W2++],[W4++]
0087E: MOV #8EE,W4
00880: REPEAT #32
00882: MOV [W3++],[W4++]
00884: MOV #8F0,W0
00886: REPEAT #32
00888: MOV [W4++],[W0++]
0088A: MOV #8F2,W0
0088C: REPEAT #32
0088E: MOV [W5++],[W0++]
00890: MOV #8F4,W0
00892: REPEAT #32
00894: MOV [W6++],[W0++]
00896: MOV #8F6,W0
00898: REPEAT #32
0089A: MOV [W7++],[W0++]
0089C: MOV #8F8,W0
0089E: REPEAT #32
008A0: MOV [W8++],[W0++]
008A2: MOV #8FA,W0
008A4: REPEAT #32
008A6: MOV [W9++],[W0++]
008A8: MOV #8FC,W0
008AA: REPEAT #32
008AC: MOV [W10++],[W0++]
008AE: MOV #8FE,W0
008B0: REPEAT #32
008B2: MOV [W11++],[W0++]
008B4: MOV #900,W0
008B6: REPEAT #32
008B8: MOV [W12++],[W0++]
008BA: MOV #902,W0
008BC: REPEAT #32
008BE: MOV [W13++],[W0++]
008C0: SUB #CC,W14
008C2: MOV #904,W0
008C4: REPEAT #32
008C6: MOV [W14++],[W0++]
008C8: SUB #CC,W15
008CA: MOV #906,W0
008CC: REPEAT #32
008CE: MOV [W15++],[W0++]
008D0: MOV #908,W0
008D2: REPEAT #32
008D4: MOV [W0++],[W0++]
008D6: MOV #90A,W0
008D8: REPEAT #32
008DA: MOV [W1++],[W0++]
008DC: MOV #90C,W0
008DE: REPEAT #32
008E0: MOV [W2++],[W0++]
008E2: MOV #90E,W0
008E4: REPEAT #32
008E6: MOV [W3++],[W0++]
008E8: MOV #910,W0
008EA: REPEAT #32
008EC: MOV [W4++],[W0++]
008EE: MOV #912,W0
008F0: REPEAT #32
008F2: MOV [W5++],[W0++]
008F4: MOV #914,W0
008F6: REPEAT #32
008F8: MOV [W6++],[W0++]
008FA: MOV #916,W0
008FC: REPEAT #32
008FE: MOV [W7++],[W0++]
00900: MOV #918,W0
00902: REPEAT #32
00904: MOV [W8++],[W0++]
00906: MOV #91A,W0
00908: REPEAT #32
0090A: MOV [W9++],[W0++]
0090C: MOV #91C,W0
0090E: REPEAT #32
00910: MOV [W10++],[W0++]
00912: MOV #91E,W0
00914: REPEAT #32
00916: MOV [W11++],[W0++]
00918: MOV #920,W0
0091A: REPEAT #32
0091C: MOV [W12++],[W0++]
0091E: MOV #922,W0
00920: REPEAT #32
00922: MOV [W13++],[W0++]
00924: MOV #924,W0
00926: REPEAT #32
00928: MOV [W14++],[W0++]
0092A: MOV #926,W0
0092C: REPEAT #32
0092E: MOV [W15++],[W0++]
00930: MOV #928,W0
00932: REPEAT #32
00934: MOV [W0++],[W0++]
00936: MOV #92A,W0
00938: REPEAT #32
0093A: MOV [W1++],[W0++]
0093C: MOV #92C,W0
0093E: REPEAT #32
00940: MOV [W2++],[W0++]
00942: MOV #92E,W0
00944: REPEAT #32
00946: MOV [W3++],[W0++]
00948: MOV #930,W0
0094A: REPEAT #32
0094C: MOV [W4++],[W0++]
0094E: MOV #932,W0
00950: REPEAT #32
00952: MOV [W5++],[W0++]
00954: MOV #934,W0
00956: REPEAT #32
00958: MOV [W6++],[W0++]
0095A: MOV #936,W0
0095C: REPEAT #32
0095E: MOV [W7++],[W0++]
00960: CALL 378
allenhuffman
Posted: Thu Jan 30, 2020 8:40 am |
FYI, using it by pointer does something much more reasonable.
| Code: | .................... ShowObjectByPtr (&objects[0]);
009C6: MOV #800,W4
009C8: MOV W4,8D4
009CA: CALL 3D0
.................... n = 0;
009CE: CLR 8CE
.................... ShowObjectByPtr (&objects[n]);
009D0: MOV 8CE,W4
009D2: MOV #66,W3
009D4: MUL.SS W4,W3,W0
009D6: MOV #800,W4
009D8: ADD W0,W4,W5
009DA: MOV W5,8D4
009DC: CALL 3D0
(Former instructor soapbox mode...) Pointers in C are one of the main causes for errors and problems... Stray or uninitialized pointers can crash the system. Checking against NULL only proves it's set to something, but does not prove it's pointing to what you want. To make pointers more secure, you'd want to add more to the structure like ID values (or, for critical code, a checksum/CRC or similar), to reduce the chance of a bad pointer getting through.
Pointers are much more efficient and fast, and an easy way to pass something in and have it modified by the function. But, if that speed isn't as important as robustness, eliminating pointers (like many modern languages have done) eliminates those types of errors -- at the cost of extra CPU overhead.
For modifying data, you could do this:
| Code: | | function (&myStructure); |
...or you could safely pass in a copy and update the original like this:
| Code: | | myStructure = function (myStructure); |
The downside of that is you don't have a way to detect errors since you are using the return value for the updated structure. But, adding a simple error code item into the structure takes care of that.
It's slower and produces larger code, but can greatly reduce the amount of hours you might spend tracking down a stray pointer down the line :-)
(Off soapboax now. Sorry, my background was with an embedded operating system and many of our customers ran mission critical code -- traffic controllers and such -- so I got things like this hammered into me early on.) _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Thu Jan 30, 2020 1:42 pm |
CCS provided me an updated DLL to try, and its results are much nicer:
| Code: | .................... ShowObject (objects[0]);
003EA: MOV #800,W0
003EC: MOV #8D4,W1
003EE: REPEAT #65
003F2: CALL 378
003F6: CLR 8CE
003F8: MOV 8CE,W4
003FA: MOV #66,W3
003FE: MOV #800,W4
00400: ADD W0,W4,W0
00402: MOV W0,W5
00404: MOV #8D4,W4
00406: REPEAT #32
00408: MOV [W5++],[W4++]
0040A: CALL 378
allenhuffman
Posted: Wed Feb 12, 2020 9:53 am |
This is expected to be resolved in the next release after 5.092. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
allenhuffman
Posted: Mon Feb 24, 2020 11:43 am |
5.093 has been released. I have confirmed it fixes this issue. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
