cvargcal
| Bootload CCS example |
Posted: Fri May 03, 2019 1:18 pm |
Hi, I want use the this example bootlooader, but no compiler
| Code: | ///////////////////////////////////////////////////////////////////////////
//// EX_BOOTLOADER.C ////
//// This program is an example stand alone bootloader. ////
//// This program must be loaded into a target chip using a device ////
//// programmer. Afterwards this program may be used to load new ////
//// versions of the application program. ////
//// This bootloader is designed to detect pin B5 low on reset. It ////
//// will then use the RS232 link to download a new program. ////
//// Otherwise the application program is started. ////
//// Use an RS232 link and the SIOW.EXE or CCS_BOOTLOADER.exe program ////
//// to load a new HEX file into the target chip. ////
//// Uncomment the define BOOTLOADER_MODE2X to use an alternate ////
//// bootloader that receives each line in the hex file twice and ////
//// compares them before acknowledging the line and writing it to ////
//// the target chip's memory. This mode only works with the ////
//// CCS_BOOTLOADER.exe program, add MODE2X to the command line to ////
//// use this mode. ////
//// This example will work with the PCM and PCH compilers. The ////
//// following conditional compilation lines are used to include a ////
//// valid device for each compiler. Change the device, clock and ////
//// RS232 pins for your hardware if needed. ////
//// (C) Copyright 1996,2014,2018 Custom Computer Services ////
//// This source code may only be used by licensed users of the CCS ////
//// C compiler. This source code may only be distributed to other ////
//// licensed users of the CCS C compiler. No other use, ////
//// reproduction or distribution is permitted without written ////
//// permission. Derivative programs created using this software ////
//// in object code form are not restricted in any way. ////
#include <18LF26K22.h>
#use delay( crystal=20MHz )
#use rs232(icd) //Text through the ICD
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) //Text through the UART
#define PUSH_BUTTON PIN_A4
#define _BOOTLOADER
//#define BOOTLOADER_MODE2X
#include <bootloader.h>
#include <loader.c>
#org LOADER_END+1,LOADER_END+2
void application(void) {
while(TRUE);
void main(void) {
if(!input(PUSH_BUTTON))
printf("\r\nBootloader Version 1.0\r\n");
// Let the user know it is ready to accept a download
printf("\r\nWaiting for download...");
load_program();
application();
#int_global
void isr(void) {
jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
Error
*** Error 71 "main.c" Line 73(1,2): Out of ROM, A segment or the program is too large application
Seg 00500-00500, 0002 left, need 00004 Orged
What its the solution please?
I am new with the bootlooder, I want update the PIC across the net by one module TPC to TTL. So my idea is update firmware remotely |
Posted: Fri May 03, 2019 2:33 pm |
Did you edit that file ? Or maybe you have an older compiler ?
You have the #org statement used with 16F PICs (PCM compiler),
but your PIC uses the PCH compiler. So you really need the statement
shown in bold below.
The current compiler has #if statements to automatically select the
correct #org statement. See below:
| Quote: | #if defined(__PCM__)
#elif defined(__PCH__)
#org LOADER_END+2,LOADER_END+4
#endif |
cvargcal
Posted: Sat May 04, 2019 5:51 pm |
| PCM programmer wrote: | Did you edit that file ? Or maybe you have an older compiler ?
#endif |
Yes, Now work!
Thanks |
