Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Bootload CCS example
cvargcal
PostPosted: Fri May 03, 2019 1:18 pm     Reply with quote
Hi, I want use the this example bootlooader, but no compiler
////                      EX_BOOTLOADER.C                              ////
////  This program is an example stand alone bootloader.               ////
////  This program must be loaded into a target chip using a device    ////
////  programmer.  Afterwards this program may be used to load new     ////
////  versions of the application program.                             ////
////  This bootloader is designed to detect pin B5 low on reset.  It   ////
////  will then use the RS232 link to download a new program.          ////
////  Otherwise the application program is started.                    ////
////  Use an RS232 link and the SIOW.EXE or CCS_BOOTLOADER.exe program ////
////  to load a new HEX file into the target chip.                     ////
////  Uncomment the define BOOTLOADER_MODE2X to use an alternate       ////
////  bootloader that receives each line in the hex file twice and     ////
////  compares them before acknowledging the line and writing it to    ////
////  the target chip's memory.  This mode only works with the         ////
////  CCS_BOOTLOADER.exe program, add MODE2X to the command line to    ////
////  use this mode.                                                   ////
////  This example will work with the PCM and PCH compilers.  The      ////
////  following conditional compilation lines are used to include a    ////
////  valid device for each compiler.  Change the device, clock and    ////
////  RS232 pins for your hardware if needed.                          ////
////     (C) Copyright 1996,2014,2018 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS    ////
//// C compiler.  This source code may only be distributed to other    ////
//// licensed users of the CCS C compiler.  No other use,              ////
//// reproduction or distribution is permitted without written         ////
//// permission.  Derivative programs created using this software      ////
//// in object code form are not restricted in any way.                ////
#include <18LF26K22.h>
#use delay( crystal=20MHz )
#use rs232(icd)                                  //Text through the ICD
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) //Text through the UART
#define PUSH_BUTTON PIN_A4
#define _BOOTLOADER
//#define BOOTLOADER_MODE2X
#include <bootloader.h>
#include <loader.c>
 #org LOADER_END+1,LOADER_END+2
void application(void) {
  while(TRUE);
void main(void) {
   if(!input(PUSH_BUTTON))
      printf("\r\nBootloader Version 1.0\r\n");
      // Let the user know it is ready to accept a download
      printf("\r\nWaiting for download...");
      load_program();
   application();
#int_global
void isr(void) {
   jump_to_isr(LOADER_END+5*(getenv("BITS_PER_INSTRUCTION")/8));
Error
*** Error 71 "main.c" Line 73(1,2): Out of ROM, A segment or the program is too large application
Seg 00500-00500, 0002 left, need 00004 Orged
What its the solution please?
I am new with the bootlooder, I want update the PIC across the net by one module TPC to TTL. So my idea is update firmware remotely
PostPosted: Fri May 03, 2019 2:33 pm     Reply with quote
Did you edit that file ? Or maybe you have an older compiler ?
You have the #org statement used with 16F PICs (PCM compiler),
but your PIC uses the PCH compiler. So you really need the statement
shown in bold below.
The current compiler has #if statements to automatically select the
correct #org statement. See below:
#if defined(__PCM__)
#elif defined(__PCH__)
#org LOADER_END+2,LOADER_END+4
cvargcal
PostPosted: Sat May 04, 2019 5:51 pm     Reply with quote
Yes, Now work!
