hemnath
Posted: Sun Aug 06, 2017 9:43 pm |
To display the bargraph on GLCD, I used the below program.
Code: | void bargraph_disp()
int16 percent;
int c = 0;
// percent = Y02 * 100/10.0;
percent = 100;
if(percent <= 0)
percent = 0;
if(percent >= 100)
percent = 100;
if(percent >= 100)
bargraph_display(0xB0, 0x10, 0x00, 0xD8);
bargraph_display(0xB1, 0x10, 0x00, 0xB6);
bargraph_display(0xB2, 0x10, 0x00, 0x6D);
bargraph_display(0xB3, 0x10, 0x00, 0xDB);
bargraph_display(0xB4, 0x10, 0x00, 0xB6);
bargraph_display(0xB5, 0x10, 0x00, 0x6D);
bargraph_display(0xB6, 0x10, 0x00, 0xDB);
bargraph_display(0xB7, 0x10, 0x00, 0x36);
else if(percent >= 95)
bargraph_display(0xB0, 0x10, 0x00, 0xC0);
else if(percent >= 90)
bargraph_display(0xB0, 0x10, 0x00, 0x00);
else if(percent >= 85)
bargraph_display(0xB1, 0x10, 0x00, 0xB0);
else if(percent >= 80)
bargraph_display(0xB1, 0x10, 0x00, 0x80);
else if(percent >= 75)
for(c = 0; c <= 1; c++)
bargraph_display(0xB0+c, 0x10, 0x00, 0x00);
bargraph_display(0xB2, 0x10, 0x00, 0x6C);
else if(percent >= 70)
bargraph_display(0xB2, 0x10, 0x00, 0x60);
else if(percent >= 65)
for(c = 0; c <= 2; c++)
else if(percent >= 60)
bargraph_display(0xB3, 0x10, 0x00, 0xD8);
else if(percent >= 55)
bargraph_display(0xB3, 0x10, 0x00, 0xC0);
else if(percent >= 50)
for(c = 0; c <= 3; c++)
else if(percent >= 45)
bargraph_display(0xB4, 0x10, 0x00, 0xB0);
else if(percent >= 40)
bargraph_display(0xB4, 0x10, 0x00, 0x80);
else if(percent >= 35)
for(c = 0; c <= 4; c++)
bargraph_display(0xB5, 0x10, 0x00, 0x6C);
else if(percent >= 30)
bargraph_display(0xB5, 0x10, 0x00, 0x60);
else if(percent >= 25)
for(c = 0; c <= 5; c++)
else if(percent >= 20)
bargraph_display(0xB6, 0x10, 0x00, 0xD8);
else if(percent >= 15)
bargraph_display(0xB6, 0x10, 0x00, 0xC0);
else if(percent >= 10)
for(c = 0; c <= 6; c++)
else if(percent >= 5)
bargraph_display(0xB7, 0x10, 0x00, 0x30);
else if(percent <= 0)
for(c = 0; c <= 7; c++)
void bargraph_display(char address, char upper_address, char lower_address, char data)
glcd_command(address);
glcd_command(upper_address);
glcd_command(lower_address);
for(i = 0; i < 5; i++)
glcd_data(data);
When I compile the code, it occupies 7% of ROM. Is it possible to reduce the memory with much simpler program? Please help. |
