Graphic LCD
Goto page Previous  1, 2
hemnath
PostPosted: Sun Aug 06, 2017 9:36 pm     Reply with quote
Thank you very much Smile It works with
#device PASS_STRINGS option
hemnath
PostPosted: Sun Aug 06, 2017 9:43 pm     Reply with quote
To display the bargraph on GLCD, I used the below program.
void bargraph_disp()
   int16 percent;
   int c = 0;
//   percent = Y02 * 100/10.0;
   percent  = 100;
   if(percent <= 0)
      percent = 0;
   if(percent >= 100)
      percent = 100;
   if(percent >= 100)
      bargraph_display(0xB0, 0x10, 0x00, 0xD8);
      bargraph_display(0xB1, 0x10, 0x00, 0xB6);
      bargraph_display(0xB2, 0x10, 0x00, 0x6D);
      bargraph_display(0xB3, 0x10, 0x00, 0xDB);
      bargraph_display(0xB4, 0x10, 0x00, 0xB6);
      bargraph_display(0xB5, 0x10, 0x00, 0x6D);
      bargraph_display(0xB6, 0x10, 0x00, 0xDB);
      bargraph_display(0xB7, 0x10, 0x00, 0x36);
   else if(percent >= 95)
      bargraph_display(0xB0, 0x10, 0x00, 0xC0);
   else if(percent >= 90)
      bargraph_display(0xB0, 0x10, 0x00, 0x00);
   else if(percent >= 85)
      bargraph_display(0xB1, 0x10, 0x00, 0xB0);
   else if(percent >= 80)
      bargraph_display(0xB1, 0x10, 0x00, 0x80);
   else if(percent >= 75)
      for(c = 0; c <= 1; c++)
         bargraph_display(0xB0+c, 0x10, 0x00, 0x00);
      bargraph_display(0xB2, 0x10, 0x00, 0x6C);
   else if(percent >= 70)
      bargraph_display(0xB2, 0x10, 0x00, 0x60);
   else if(percent >= 65)
      for(c = 0; c <= 2; c++)
   else if(percent >= 60)
      bargraph_display(0xB3, 0x10, 0x00, 0xD8);
   else if(percent >= 55)
      bargraph_display(0xB3, 0x10, 0x00, 0xC0);
   else if(percent >= 50)
      for(c = 0; c <= 3; c++)
   else if(percent >= 45)
      bargraph_display(0xB4, 0x10, 0x00, 0xB0);
   else if(percent >= 40)
      bargraph_display(0xB4, 0x10, 0x00, 0x80);
   else if(percent >= 35)
      for(c = 0; c <= 4; c++)
      bargraph_display(0xB5, 0x10, 0x00, 0x6C);
   else if(percent >= 30)
      bargraph_display(0xB5, 0x10, 0x00, 0x60);
   else if(percent >= 25)
      for(c = 0; c <= 5; c++)
   else if(percent >= 20)
      bargraph_display(0xB6, 0x10, 0x00, 0xD8);
   else if(percent >= 15)
      bargraph_display(0xB6, 0x10, 0x00, 0xC0);
   else if(percent >= 10)
      for(c = 0; c <= 6; c++)
   else if(percent >= 5)
      bargraph_display(0xB7, 0x10, 0x00, 0x30);
   else if(percent <= 0)
      for(c = 0; c <= 7; c++)
void bargraph_display(char address, char upper_address, char lower_address, char data)
   glcd_command(address);
   glcd_command(upper_address);
   glcd_command(lower_address);
   for(i = 0; i < 5; i++)
      glcd_data(data);
When I compile the code, it occupies 7% of ROM. Is it possible to reduce the memory with much simpler program? Please help.
PostPosted: Mon Aug 07, 2017 12:14 am     Reply with quote
Probably not by much.
Just the 'numbers' table you showed at the start of your earlier code, occupies 3%. Add the code used for each routine, and 7% sounds very reasonable. However remember that things like this are only loaded once, so as your code gets larger, it will grow more slowly.
Page 2 of 2
