sshahryiar
Joined: 05 May 2010 Posts: 92 Location: Dhaka, Bangladesh
Calculator Project |
Posted: Sat Feb 20, 2016 9:35 pm |
This is a simple calculator made with 7 segment display and a 4x4 keypad. Currently only integral calculations are supported.
keypad.h
#define col1 pin_A1
#define col2 pin_A2
#define col3 pin_A3
#define col4 pin_A5
#define col5 pin_E0
#define col6 pin_E1
#define col7 pin_E2
#define col8 pin_C0
#define sw0 !input(pin_B0)
#define sw1 !input(pin_B2)
#define sw2 !input(pin_B4)
#define sw3 !input(pin_B5)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
const unsigned char num[0x0A] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F};
unsigned char buffer[0x08] = {0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40};
unsigned char pos = 0x00;
unsigned char key = 0xFF;
short key_pressed = FALSE;
void segmented_display_init();
void clear_buffer(); |
keypad.c
Code: | #include "keypad_display.h"
void display_keypad_init()
set_TRIS_A(0xD1);
set_TRIS_B(0xFF);
set_TRIS_C(0xFE);
set_TRIS_D(0x00);
set_TRIS_E(0xF0);
output_D(0x00);
setup_SPI(SPI_disabled | SPI_SS_disabled);
setup_ADC(ADC_off);
setup_ADC_ports(no_analogs);
port_B_pullups(FALSE);
setup_timer_0(T0_internal | T0_div_64 | T0_8_bit);
set_timer0(0xD8);
enable_interrupts(INT_RTCC);
#int_RTCC
void scan_display()
set_timer0(0xD8);
output_D(buffer[pos]);
switch(pos)
case 7:
output_high(col1);
output_low(col2);
output_low(col3);
output_low(col4);
output_low(col5);
output_low(col6);
output_low(col7);
output_low(col8);
if(sw0)
key_pressed = TRUE;
key = 0x01;
if(sw1)
key_pressed = TRUE;
key = 0x02;
if(sw2)
key_pressed = TRUE;
key = 0x03;
if(sw3)
key_pressed = TRUE;
key = 0x0A;
case 6:
output_high(col2);
output_low(col1);
output_low(col3);
output_low(col4);
output_low(col5);
output_low(col6);
output_low(col7);
output_low(col8);
if(sw0)
key_pressed = TRUE;
key = 0x04;
if(sw1)
key_pressed = TRUE;
key = 0x05;
if(sw2)
key_pressed = TRUE;
key = 0x06;
if(sw3)
key_pressed = TRUE;
key = 0x0B;
case 5:
output_high(col3);
output_low(col1);
output_low(col2);
output_low(col4);
output_low(col5);
output_low(col6);
output_low(col7);
output_low(col8);
if(sw0)
key_pressed = TRUE;
key = 0x07;
if(sw1)
key_pressed = TRUE;
key = 0x08;
if(sw2)
key_pressed = TRUE;
key = 0x09;
if(sw3)
key_pressed = TRUE;
key = 0x0C;
case 4:
output_high(col4);
output_low(col1);
output_��428col2);
output_low(col3);
output_low(col5);
output_low(col6);
output_low(col7);
output_low(col8);
if(sw0)
key_pressed = TRUE;
key = 0x0F;
if(sw1)
key_pressed = TRUE;
key = 0x00;
if(sw2)
key_pressed = TRUE;
key = 0x0E;
if(sw3)
key_pressed = TRUE;
key = 0x0D;
case 3:
output_high(col5);
output_low(col1);
output_low(col2);
output_low(col3);
output_low(col4);
output_low(col6);
output_low(col7);
output_low(col8);
case 2:
output_high(col6);
output_low(col1);
output_low(col2);
output_low(col3);
output_low(col4);
output_low(col5);
output_low(col7);
output_low(col8);
case 1:
output_high(col7);
output_low(col1);
output_low(col2);
output_low(col3);
output_low(col4);
output_low(col5);
output_low(col6);
output_low(col8);
case 0:
output_high(col8);
output_low(col1);
output_low(col2);
output_low(col3);
output_low(col4);
output_low(col5);
output_low(col6);
output_low(col7);
pos++;
if(pos >= 8)
pos = 0;
void clear_buffer()
memset(buffer, 0x00, sizeof(buffer));
Main code
Code: | #include <16F877A.h>
#device *= 16
#fuses HS, PUT, PROTECT, CPD, NODEBUG, NOLVP, NOWDT, NOWRT, BROWNOUT
#use delay (clock = 10MHz)
#include "keypad_display.c"
#define no_op 0x0E
#define add 0x0A
#define sub 0x0B
#define mul 0x0C
#define div 0x0D
unsigned char operation = 0x00;
void setup();
unsigned long long get_number(short num_sel);
void show_value(signed long long value);
unsigned long long power(unsigned char value);
signed long long num1 = 0;
signed long long num2 = 0;
setup();
while(key != 0x0F);
num1 = get_number(TRUE);
show_value(num1);
num2 = get_number(FALSE);
show_value(num2);
switch(operation)
case add:
show_value((num1 + num2));
case sub:
show_value((num1 - num2));
case mul:
show_value((num1 * num2));
case div:
show_value((num1 / num2));
case no_op:
show_value(19999999);
void setup()
disable_interrupts(GLOBAL);
setup_timer_1(T1_disabled);
setup_timer_2(T2_disabled, 255, 1);
set_timer1(0x0000);
set_timer2(0x00);
setup_CCP1(CCP_off);
setup_CCP2(CCP_off);
display_keypad_init();
unsigned char n = 0x00;
unsigned char digits = 0x00;
unsigned long long number = 0;
unsigned char value[8];
memset(value, 0x00, sizeof(value));
clear_buffer();
if(key_pressed)
if((key >= 0) && (key <= 9))
buffer[n] = num[key];
value[n] = key;
n++;
digits++;
delay_ms(400);
if((n >= 7) || ((key >= 0x0A) && (key <= 0x0E)))
if(num_sel == TRUE)
operation = key;
for(n = 1; n <= digits; n++)
number += value[(n - 1)] * power(digits - n);
return number;
unsigned char ch = 0;
clear_buffer();
if(value < 0)
value = -value;
buffer[0] = 0x40;
if((value >= 0) && (value <= 9))
ch = value;
buffer[7] = num[ch];
else if((value > 9) && (value <= 99))
ch = (value / 10);
buffer[6] = num[ch];
ch = (value % 10);
else if((value > 99) && (value <= 999))
ch = (value / 100);
buffer[5] = num[ch];
ch = ((value / 10) % 10);
ch = (value % 10);
else if((value > 999) && (value <= 9999))
ch = (value / 1000);
buffer[4] = num[ch];
ch = ((value / 100) % 10);
ch = (value % 10);
else if((value > 9999) && (value <= 99999))
ch = (value / 10000);
buffer[3] = num[ch];
ch = ((value / 1000) % 10);
ch = (value % 10);
else if((value > 99999) && (value <= 999999))
ch = (value / 100000);
buffer[2] = num[ch];
ch = ((value / 10000) % 10);
ch = (value % 10);
else if((value > 999999) && (value <= 9999999))
ch = (value / 1000000);
buffer[1] = num[ch];
ch = ((value / 100000) % 10);
ch = (value % 10);
memset(buffer, 0x40, sizeof(buffer));
unsigned char p = 0;
unsigned long long temp = 1;
for(p = 0; p < value; p++)
temp *= 10;
return temp;
Project demo video
https://www.youtube.com/watch?v=ZrfTvYYNqcA _________________ https://www.facebook.com/MicroArena
SShahryiar |
Jerson
Joined: 31 Jul 2009 Posts: 70 Location: Bombay, India
Posted: Sun Feb 21, 2016 1:02 am |
There is ghosting in your numbers. I suggest you do the scan this way.
Example for only one digit is shown here.
Code: | void scan_display()
set_timer0(0xD8);
output_D(0x00); // 0x00 turns off the segments by looking at your numtable
switch(pos)
case 7:
output_high(col1);
output_low(col2);
output_low(col3);
output_low(col4);
output_low(col5);
output_low(col6);
output_low(col7);
output_low(col8);
} // end of switch
output_D(buffer[pos]); // now turn on the segments
sshahryiar
