Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Calculator Project
Post new topic   Reply to topic    CCS Forum Index -> Code Library
sshahryiar
Calculator Project
PostPosted: Sat Feb 20, 2016 9:35 pm     Reply with quote
This is a simple calculator made with 7 segment display and a 4x4 keypad. Currently only integral calculations are supported.
keypad.h
#define col1         pin_A1
#define col2         pin_A2
#define col3         pin_A3
#define col4         pin_A5
#define col5         pin_E0
#define col6         pin_E1
#define col7         pin_E2
#define col8         pin_C0
#define sw0            !input(pin_B0)
#define sw1             !input(pin_B2)
#define sw2            !input(pin_B4)
#define sw3            !input(pin_B5)
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(D)
#use fast_io(E)
const unsigned char num[0x0A] = {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x07, 0x7F, 0x6F};
unsigned char buffer[0x08] = {0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40, 0x40};
unsigned char pos = 0x00;
unsigned char key = 0xFF;
short key_pressed = FALSE;
void segmented_display_init();
void clear_buffer();
keypad.c
#include "keypad_display.h"
void display_keypad_init()
   set_TRIS_A(0xD1);
   set_TRIS_B(0xFF);
   set_TRIS_C(0xFE);
   set_TRIS_D(0x00);
   set_TRIS_E(0xF0);
   output_D(0x00);
   setup_SPI(SPI_disabled | SPI_SS_disabled);
   setup_ADC(ADC_off);
   setup_ADC_ports(no_analogs);
   port_B_pullups(FALSE);
   setup_timer_0(T0_internal | T0_div_64 | T0_8_bit);
   set_timer0(0xD8);
   enable_interrupts(INT_RTCC);
#int_RTCC
void scan_display()
   set_timer0(0xD8);
   output_D(buffer[pos]);
   switch(pos)
      case 7:
         output_high(col1);
         output_low(col2);
         output_low(col3);
         output_low(col4);
         output_low(col5);
         output_low(col6);
         output_low(col7);
         output_low(col8);
          if(sw0)
            key_pressed = TRUE;
            key = 0x01;
         if(sw1)
            key_pressed = TRUE;
            key = 0x02;
         if(sw2)
            key_pressed = TRUE;
            key = 0x03;
         if(sw3)
            key_pressed = TRUE;
            key = 0x0A;
      case 6:
         output_high(col2);
         output_low(col1);
         output_low(col3);
         output_low(col4);
         output_low(col5);
         output_low(col6);
         output_low(col7);
         output_low(col8);
         if(sw0)
            key_pressed = TRUE;
            key = 0x04;
         if(sw1)
            key_pressed = TRUE;
            key = 0x05;
         if(sw2)
            key_pressed = TRUE;
            key = 0x06;
         if(sw3)
            key_pressed = TRUE;
            key = 0x0B;
      case 5:
         output_high(col3);
         output_low(col1);
         output_low(col2);
         output_low(col4);
         output_low(col5);
         output_low(col6);
         output_low(col7);
         output_low(col8);
         if(sw0)
            key_pressed = TRUE;
            key = 0x07;
         if(sw1)
            key_pressed = TRUE;
            key = 0x08;
         if(sw2)
            key_pressed = TRUE;
            key = 0x09;
         if(sw3)
            key_pressed = TRUE;
            key = 0x0C;
      case 4:
         output_high(col4);
         output_low(col1);
         output_��428col2);
         output_low(col3);
         output_low(col5);
         output_low(col6);
         output_low(col7);
         output_low(col8);
          if(sw0)
            key_pressed = TRUE;
            key = 0x0F;
         if(sw1)
            key_pressed = TRUE;
            key = 0x00;
         if(sw2)
            key_pressed = TRUE;
            key = 0x0E;
         if(sw3)
            key_pressed = TRUE;
            key = 0x0D;
      case 3:
         output_high(col5);
         output_low(col1);
         output_low(col2);
         output_low(col3);
         output_low(col4);
         output_low(col6);
         output_low(col7);
         output_low(col8);
      case 2:
         output_high(col6);
         output_low(col1);
         output_low(col2);
         output_low(col3);
         output_low(col4);
         output_low(col5);
         output_low(col7);
         output_low(col8);
      case 1:
         output_high(col7);
         output_low(col1);
         output_low(col2);
         output_low(col3);
         output_low(col4);
         output_low(col5);
         output_low(col6);
         output_low(col8);
      case 0:
         output_high(col8);
         output_low(col1);
         output_low(col2);
         output_low(col3);
         output_low(col4);
         output_low(col5);
         output_low(col6);
         output_low(col7);
   pos++;
   if(pos >= 8)
      pos = 0;
void clear_buffer()
   memset(buffer, 0x00, sizeof(buffer));
Main code
#include <16F877A.h>
#device *= 16
#fuses HS, PUT, PROTECT, CPD, NODEBUG, NOLVP, NOWDT, NOWRT, BROWNOUT
#use delay (clock = 10MHz)
#include "keypad_display.c"
#define no_op            0x0E
#define add               0x0A
#define sub               0x0B
#define mul               0x0C
#define div               0x0D
unsigned char operation = 0x00;
void setup();
unsigned long long get_number(short num_sel);
void show_value(signed long long  value);
unsigned long long power(unsigned char value);
   signed long long num1 = 0;
   signed long long num2 = 0;
   setup();
       while(key != 0x0F);
       num1 = get_number(TRUE);
       show_value(num1);
       num2 = get_number(FALSE);
       show_value(num2);
       switch(operation)
          case add:
             show_value((num1 + num2));
          case sub:
             show_value((num1 - num2));
          case mul:
             show_value((num1 * num2));
          case div:
             show_value((num1 / num2));
          case no_op:
             show_value(19999999);
void setup()
   disable_interrupts(GLOBAL);
   setup_timer_1(T1_disabled);
   setup_timer_2(T2_disabled, 255, 1);
   set_timer1(0x0000);
   set_timer2(0x00);
   setup_CCP1(CCP_off);
   setup_CCP2(CCP_off);
   display_keypad_init();
   unsigned char n = 0x00;
   unsigned char digits = 0x00;
   unsigned long long number = 0;
   unsigned char value[8];
   memset(value, 0x00, sizeof(value));
   clear_buffer();
      if(key_pressed)
          if((key >= 0) && (key <= 9))
              buffer[n] = num[key];
             value[n] = key;
             n++;
             digits++;
          delay_ms(400);
          if((n >= 7) || ((key >= 0x0A) && (key <= 0x0E)))
                if(num_sel == TRUE)
                   operation = key;
    for(n = 1; n <= digits; n++)
       number += value[(n - 1)] * power(digits - n);
    return number;
   unsigned char ch = 0;
   clear_buffer();
   if(value < 0)
      value = -value;
      buffer[0] = 0x40;
   if((value >= 0) && (value <= 9))
       ch = value;
       buffer[7] = num[ch];
   else if((value > 9) && (value <= 99))
       ch = (value / 10);
       buffer[6] = num[ch];
       ch = (value % 10);
   else if((value > 99) && (value <= 999))
       ch = (value / 100);
       buffer[5] = num[ch];
       ch = ((value / 10) % 10);
       ch = (value % 10);
   else if((value > 999) && (value <= 9999))
       ch = (value / 1000);
       buffer[4] = num[ch];
       ch = ((value / 100) % 10);
       ch = (value % 10);
   else if((value > 9999) && (value <= 99999))
       ch = (value / 10000);
       buffer[3] = num[ch];
       ch = ((value / 1000) % 10);
       ch = (value % 10);
   else if((value > 99999) && (value <= 999999))
       ch = (value / 100000);
       buffer[2] = num[ch];
       ch = ((value / 10000) % 10);
       ch = (value % 10);
   else if((value > 999999) && (value <= 9999999))
       ch = (value / 1000000);
       buffer[1] = num[ch];
       ch = ((value / 100000) % 10);
       ch = (value % 10);
      memset(buffer, 0x40, sizeof(buffer));
   unsigned char p = 0;
   unsigned long long temp = 1;
   for(p = 0; p < value; p++)
      temp *= 10;
   return temp;
Project demo video
https://www.youtube.com/watch?v=ZrfTvYYNqcA
https://www.facebook.com/MicroArena
SShahryiar
Jerson
View user's profile Send private message Visit poster's website Yahoo Messenger
PostPosted: Sun Feb 21, 2016 1:02 am     Reply with quote
There is ghosting in your numbers. I suggest you do the scan this way.
Example for only one digit is shown here.
void scan_display()
   set_timer0(0xD8);
   output_D(0x00);  // 0x00 turns off the segments by looking at your numtable
   switch(pos)
      case 7:
         output_high(col1);
         output_low(col2);
         output_low(col3);
         output_low(col4);
         output_low(col5);
         output_low(col6);
         output_low(col7);
         output_low(col8);
    } // end of switch
    output_D(buffer[pos]);   // now turn on the segments
sshahryiar
ghost
PostPosted: Sun Feb 21, 2016 1:09 am     Reply with quote
Thanks for the tip.... Very Happy
SShahryiar
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
