sshahryiar
Joined: 05 May 2010 Posts: 94 Location: Dhaka, Bangladesh
| HMC1022 (GY-26) UART Compass Library |
Posted: Fri Jul 17, 2015 12:01 pm |
HMC1022.h
#define Default_I2C_Address 0xE0
#define Get_Angular_Measurement 0x31
#define Start_Calibration 0xC0
#define End_Calibration 0xC1
#define Set_Magnetic_Declination_High_Byte 0x03
#define Set_Magnetic_Declination_Low_Byte 0x04
#define no_of_data_bytes_returned 0x08
#define calibration_LED pin_C1
#use RS232(UART1, baud = 9600, stop = 1, parity = N, timeout = 1000)
float read_heading();
void calibrate_compass();
void factory_reset();
void set_I2C_address(unsigned char i2c_address);
void set_declination_angle(unsigned long angle);
HMC1022.c
#include "HMC1022.h"
unsigned char s = 0;
unsigned long CRC = 0x00;
register float heading = 0;
unsigned char data_bytes[no_of_data_bytes_returned] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
putc(Get_Angular_Measurement);
for(s = 0; s < no_of_data_bytes_returned; s++)
data_bytes[s] = getc();
if(s < 7)
CRC += data_bytes[s];
CRC = (CRC & 0xFF);
if(CRC == data_bytes[7])
for(s = 2; s < 7; s++)
data_bytes[s] -= 0x30;
heading = (data_bytes[2] * 100.0);
heading += (data_bytes[3] * 10.0);
heading += (data_bytes[4] * 1.0);
heading += (data_bytes[6] * 0.1);
heading = -1;
return heading;
unsigned char s = 0x00;
putc(Start_Calibration);
for(s = 0; s < 60; s++)
output_high(calibration_LED);
output_low(calibration_LED);
delay_ms(900);
delay_ms(400);
delay_ms(600);
putc(End_Calibration);
putc(0xA0);
putc(0xAA);
putc(0xA5);
putc(0xC5);
putc(0xA0);
putc(0xAA);
putc(0xA5);
putc(i2c_address);
unsigned long hb = 0;
unsigned char lb = 0;
lb = (angle & 0x00FF);
hb = (angle & 0xFF00);
hb >>= 8;
putc(Set_Magnetic_Declination_High_Byte);
putc(hb);
putc(Set_Magnetic_Declination_Low_Byte);
putc(lb);
_________________ https://www.facebook.com/MicroArena
SShahryiar |
