Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
HMC1022 (GY-26) UART Compass Library
sshahryiar
PostPosted: Fri Jul 17, 2015 12:01 pm     Reply with quote
HMC1022.h
#define Default_I2C_Address 0xE0
#define Get_Angular_Measurement 0x31
#define Start_Calibration 0xC0
#define End_Calibration 0xC1
#define Set_Magnetic_Declination_High_Byte 0x03
#define Set_Magnetic_Declination_Low_Byte    0x04
#define no_of_data_bytes_returned 0x08
#define calibration_LED pin_C1
#use RS232(UART1, baud = 9600, stop = 1, parity = N, timeout = 1000)
float read_heading();
void calibrate_compass();
void factory_reset();
void set_I2C_address(unsigned char i2c_address);
void set_declination_angle(unsigned long angle);
HMC1022.c
#include "HMC1022.h"
     unsigned char s = 0;
     unsigned long CRC = 0x00;
     register float heading = 0;
     unsigned char data_bytes[no_of_data_bytes_returned] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
     putc(Get_Angular_Measurement);
     for(s = 0; s < no_of_data_bytes_returned; s++)
        data_bytes[s] = getc();
        if(s < 7)
            CRC += data_bytes[s];
     CRC = (CRC & 0xFF);
     if(CRC == data_bytes[7])
        for(s = 2; s < 7; s++)
           data_bytes[s] -= 0x30;
        heading = (data_bytes[2] * 100.0);
       heading += (data_bytes[3] * 10.0);
       heading += (data_bytes[4] * 1.0);
       heading += (data_bytes[6] * 0.1);
        heading = -1;
     return heading;
   unsigned char s = 0x00;
   putc(Start_Calibration);
   for(s = 0; s < 60; s++)
       output_high(calibration_LED);
      output_low(calibration_LED);
      delay_ms(900);
      delay_ms(400);
      delay_ms(600);
   putc(End_Calibration);
   putc(0xA0);
   putc(0xAA);
   putc(0xA5);
   putc(0xC5);
   putc(0xA0);
   putc(0xAA);
   putc(0xA5);
   putc(i2c_address);
   unsigned long hb = 0;
   unsigned char lb = 0;
   lb = (angle & 0x00FF);
   hb = (angle & 0xFF00);
   hb >>= 8;
   putc(Set_Magnetic_Declination_High_Byte);
   putc(hb);
   putc(Set_Magnetic_Declination_Low_Byte);
   putc(lb);
https://www.facebook.com/MicroArena
SShahryiar
