triskadecaepyon
| CCS PIC18F4520 Dev Kit + Xbee = problems |
Posted: Tue Mar 10, 2009 4:54 pm |
Currently I am trying to test out my 1mW Chip Antennae Xbee Transmitters with my PIC18F4520 dev kit, and I'm running into issues. As you might know, I cannot use the built in C6/C7 hardware UART pins as they are tied to a Max232 chip already, and don't have any pins I can tap them from. I have a logic level converter from 5 to 3.3 which is used on the xbee pins.
So what I am trying to do is:
Use C6/C7 as my hyper terminal to computer
use A1/A2 as the UART to XBEE
Send "+++" to the zigbee to enter into command mode, and receive "OK" back. I currently have the output from the zigbee on an Oscilloscope, and I'm checking for anything back.
Here's my code:
| Code: | #include <18f4520.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT
#use rs232 (baud=9600, STREAM=TERM, xmit=PIN_C6, rcv=PIN_C7)
#use rs232 (baud=9600, STREAM=XBEE, xmit =PIN_A2, rcv=PIN_A1,ERRORS,FORCE_SW,parity=N,bits=8) //A1 goes to TX0, A2 goes to RX1
#include <stdlib.h>
#include <input.c>
#define GREEN_LED PIN_A5 //Define the pins
#define YELLOW_LED PIN_B4
#define RED_LED PIN_B5
#define PUSH_BUTTON PIN_A4
unsigned char buffer = 0; //buffer
unsigned char recdata = 0; // variable for taking in data
setup_uart(9600, XBEE);
fprintf(TERM,"\r\n Sending test bit");
fprintf(XBEE,"X"); //send arbitrary data
delay_ms(1000); //delay 1 second
while(TRUE){
fprintf(XBEE,"+");//AT Command init
delay_ms(250);
fprintf(XBEE,"+");
delay_ms(250);
fprintf(XBEE,"+");
Currently I'm getting nothing back. For those of you who have used Xbee before, can you please help?
Last edited by triskadecaepyon on Tue Mar 10, 2009 7:48 pm; edited 1 time in total |
Posted: Tue Mar 10, 2009 5:00 pm |
| Post a link to the data sheet and schematic of your XBee board. |
triskadecaepyon
Posted: Tue Mar 10, 2009 6:29 pm |
Where is the spec sheet for this:
| Quote: | | series 1 Xbee Transmitters |
I want to see the specs on the serial interface. Is it RS-232, or TTL,
or inverted TTL levels ? What's the baud rate, etc. ? |
triskadecaepyon
Posted: Tue Mar 10, 2009 7:40 pm |
| PCM programmer wrote: | Where is the spec sheet for this:
Sorry about not being more specific:
http://www.sparkfun.com/commerce/product_info.php?products_id=8664
UART w/ baud 9600. |
triskadecaepyon
Posted: Wed Mar 11, 2009 4:33 pm |
| anyone? |
Posted: Wed Mar 11, 2009 5:06 pm |
| Quote: | | setup_uart(9600, XBEE); |
Don't use setup_uart() with a software UART. The CCS manual says:
| Quote: | setup_uart( )
Availability: This function is only available on devices with a built in UART. |
Delete the setup_uart() line.
| Quote: | | fprintf(XBEE,"X"); //send arbitrary data |
Does the data sheet say to do this ?
| Quote: | fprintf(XBEE,"+");//AT Command init
delay_ms(250);
fprintf(XBEE,"+");
delay_ms(250);
fprintf(XBEE,"+");
delay_ms(1000); |
You have a 1 second delay after sending the init string. But, you're using
a software UART to receive the response. There is no hardware buffer
to receive a byte when the software UART is used. If the PIC is not
looking at the Rx pin when the byte comes in, it will miss the byte.
What if the XBee unit sends a response before the 1000 ms is done ?
You will miss the byte.
Also, you are looking on a scope for the response. What if you miss it ?
You have a while() loop, to repeat the test, but what if the XBee unit
doesn't repeat the response ? What if it only sends it once, and it goes
by so fast that you miss it on the oscilloscope ?
I think it would be better to run the test one time (get rid of the while
loop) after power-up. Then look closely on the scope after you flip the
power-on switch for the board. Or, get rid of the final 1000 ms delay
and add some code to read the "OK" response from the XBee unit. |
partisan
Posted: Thu Jul 17, 2014 3:36 pm |
Hello guys. My name is Isaac. How are you?
Sorry for interrupt your conversation, but i really need help.
Guys, I connected the pin TXD of DB9 to pin R1IN of MAXRS232N and the pin R1OUT of MAX to pin RB2 of PIC18F4550. I'm using a xbee PROS2 too. The xbee is connected to PIC to receive and send data to another xbee and it is connected like this picture:
I'm using this code:
| Code: | #include <18f4550.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#FUSES HS //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES PUT //Power Up Timer
#use delay(clock=20000000) // Define frequĂȘncia do cristal em 20Mhz
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=XBEE)
#use rs232(baud=9600,parity=N,rcv=PIN_B2,bits=8,stream=BALANCA)
char caracter;
void main() { // ds1307_init() exemplos PICC
while(1) {
fprintf(XBEE, "x");
delay_ms(2000);
Just a simple test, but i receive just "...............". I'm using XCTU terminal and the baud rate is right "9600". What can be?
Ps: I've test the same with arduino and works.
Thank you[/img] |
Posted: Thu Jul 17, 2014 4:07 pm |
If you are using the hardware UART (pin C7 = Rx) to connect to the Tx
pin on the XBee, your circuit will not work. The hardware UART requires
a CMOS-level signal, which means the high level must be at least 4.0v
for a PIC running at 5v. Your XBee can only put a 3.3v high level,
so it won't work. The PIC can not receive the data correctly. |
