Program PIC with ICD3 via CCS compiler
2-Chri
PostPosted: Fri Mar 23, 2012 2:19 pm     Reply with quote
I can't program the PIC16F628 with ICD3 via CCS compiler. Could anyone tell me the steps so to program. When I connect the ICD3 the icon "button" ICD is disable (in picture below).
Picture link :
http://i42.tinypic.com/11ru7eu.png
PostPosted: Fri Mar 23, 2012 2:34 pm     Reply with quote
Search Google for this:
site:ccsinfo.com -forum ICD3
Get this:
http://www.ccsinfo.com/newsdesk_info.php?newsdesk_id=103
2-Chri
PostPosted: Fri Mar 23, 2012 2:44 pm     Reply with quote
I have already install MPLAB® ICD3 and MPLAB®IDE Plug-in. I reinstall it and didn't change. Thanks!
PostPosted: Fri Mar 23, 2012 2:56 pm     Reply with quote
But did you install this one, from the CCS download page:
MPLAB® ICD2, MPLAB® ICD3 & MPLAB® REAL ICE™ Interface
http://www.ccsinfo.com/downloads/setup_mctools.exe
2-Chri
PostPosted: Fri Mar 23, 2012 3:19 pm     Reply with quote
Yes I have already install it and I reinstall now but I have the same problem. I can't make program. Thanks.
PostPosted: Fri Mar 23, 2012 3:23 pm     Reply with quote
I don't have the IDE so I can't test this, but historically one complaint was
that Microchip ICD tools only work as Debuggers in the CCS IDE, and not
as Programmers for "Release" or Standalone programs.
Are you trying to use ICD3 for debugging (single-stepping, breakpoints,
etc.) ? Or, are you trying to use it to make a program in "Release" mode ?
bkamen
PostPosted: Fri Mar 23, 2012 9:41 pm     Reply with quote
I use ICD's in MPLAB with CCS all the time.
Using an ICD2/3 in CCS's PCW seems like a bad idea.
MPLAB is a free download. Consider picking it up - CCS works fine within MPLAB.
-Ben
2-Chri
PostPosted: Sat Mar 24, 2012 2:59 am     Reply with quote
Finally i put the MPLAB plug in and i work ccs compiler via MPLAB. Thanks for help.
