2-Chri
Program PIC with ICD3 via CCS compiler |
Posted: Fri Mar 23, 2012 2:19 pm |
I can't program the PIC16F628 with ICD3 via CCS compiler. Could anyone tell me the steps so to program. When I connect the ICD3 the icon "button" ICD is disable (in picture below).
Picture link :
http://i42.tinypic.com/11ru7eu.png |
2-Chri
Posted: Fri Mar 23, 2012 2:44 pm |
I have already install MPLAB® ICD3 and MPLAB®IDE Plug-in. I reinstall it and didn't change. Thanks! |
2-Chri
Posted: Fri Mar 23, 2012 3:19 pm |
Yes I have already install it and I reinstall now but I have the same problem. I can't make program. Thanks. |
Posted: Fri Mar 23, 2012 3:23 pm |
I don't have the IDE so I can't test this, but historically one complaint was
that Microchip ICD tools only work as Debuggers in the CCS IDE, and not
as Programmers for "Release" or Standalone programs.
Are you trying to use ICD3 for debugging (single-stepping, breakpoints,
etc.) ? Or, are you trying to use it to make a program in "Release" mode ? |
bkamen
Posted: Fri Mar 23, 2012 9:41 pm |
I use ICD's in MPLAB with CCS all the time.
Using an ICD2/3 in CCS's PCW seems like a bad idea.
MPLAB is a free download. Consider picking it up - CCS works fine within MPLAB.
2-Chri
Posted: Sat Mar 24, 2012 2:59 am |
Finally i put the MPLAB plug in and i work ccs compiler via MPLAB. Thanks for help. |
