setup_adc_ports generates incorrect assembly codes
epalite
PostPosted: Tue Apr 20, 2010 3:15 am     Reply with quote
setup_adc_ports generates following incorrect assemblies, on target 16F1827.
Compiler version "CCS PCM C Compiler, Version 4.104, 51616"
1. There are no registers at BANK 3 0x10 aka 0x190.
   0DB    1010     BCF 0x10, 0
   0DC    1090     BCF 0x10, 0x1
   0DD    1110     BCF 0x10, 0x2
2. ADPREF<1:0> is incorrectly selected. 0x1e should have both bit 0 and 1 set.
   0DF    101E     BCF 0x1e, 0
   0E0    149E     BSF 0x1e, 0x1
However, revising 16F1827.h on following lines helps to fix the ADPREF error.
#define VSS_1V024            0x1300        //| Range 0-1.024V
#define VSS_2V048            0x2300        //| Range 0-2.048V
#define VSS_4V096            0x3300        //| Range 0-4.096V
Full disassembly:
174:                  setup_adc_ports(sAN11 | VSS_1V024);
   0D5    3041     MOVLW 0x41
   0D6    0021     MOVLB 0x1
   0D7    009D     MOVWF 0x1d
   0D8    3010     MOVLW 0x10
   0D9    0023     MOVLB 0x3
   0DA    008D     MOVWF 0xd
   0DE    0021     MOVLB 0x1
   0E1    3000     MOVLW 0
   0E2    0023     MOVLB 0x3
   0E3    008C     MOVWF 0xc
Please confirm/regress and appreciates early fix on confirmation. Thanks!
PostPosted: Tue Apr 20, 2010 12:50 pm     Reply with quote
See this thread. If you believe you have found additional bugs, you
should also email CCS support:
http://www.ccsinfo.com/forum/viewtopic.php?t=42233
