epalite
| setup_adc_ports generates incorrect assembly codes |
Posted: Tue Apr 20, 2010 3:15 am |
setup_adc_ports generates following incorrect assemblies, on target 16F1827.
Compiler version "CCS PCM C Compiler, Version 4.104, 51616"
1. There are no registers at BANK 3 0x10 aka 0x190.
0DB 1010 BCF 0x10, 0
0DC 1090 BCF 0x10, 0x1
0DD 1110 BCF 0x10, 0x2
2. ADPREF<1:0> is incorrectly selected. 0x1e should have both bit 0 and 1 set.
0DF 101E BCF 0x1e, 0
0E0 149E BSF 0x1e, 0x1
However, revising 16F1827.h on following lines helps to fix the ADPREF error.
#define VSS_1V024 0x1300 //| Range 0-1.024V
#define VSS_2V048 0x2300 //| Range 0-2.048V
#define VSS_4V096 0x3300 //| Range 0-4.096V
Full disassembly:
174: setup_adc_ports(sAN11 | VSS_1V024);
0D5 3041 MOVLW 0x41
0D6 0021 MOVLB 0x1
0D7 009D MOVWF 0x1d
0D8 3010 MOVLW 0x10
0D9 0023 MOVLB 0x3
0DA 008D MOVWF 0xd
0DE 0021 MOVLB 0x1
0E1 3000 MOVLW 0
0E2 0023 MOVLB 0x3
0E3 008C MOVWF 0xc
Please confirm/regress and appreciates early fix on confirmation. Thanks! |
