interfacing 2 Pic16f877 via spi
shaan
PostPosted: Thu Mar 25, 2010 1:13 am     Reply with quote
I m using MpLab v7.01 & want to interface 2 pic16f877 controller in master/slave mode via spi. Wanted source codes for master & slave of transferring any data between them.
hayee
PostPosted: Thu Mar 25, 2010 3:38 am     Reply with quote
Here is an example for SPI communication. One master and one slave.
In this code master reads the analog data and send to the slave using SPI.
For master
   float adc1,adc2,value1;
   int b0,b1,b2,b3;
   setup_adc_ports(ALL_ANALOG);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // TODO: USER CODE!!
   if (input(PIN_A5)==0)
   set_adc_channel(0);
   delay_ms(10);
   adc1=read_adc();
   adc2=(adc1*5)/1024;
   value1=adc2;
   printf("value is: %f \r\n",value1);
   union convert
     int8 b[4];
     float fval;
    val;
    val.fval=value1;
    b0=val.b[3];
    b1=val.b[2];
    b2=val.b[1];
    b3=val.b[0];
    spi_write(b0);
    spi_write(b1);
    spi_write(b2);
    spi_write(b3);
         delay_cycles(1);
For slave
float readnum(void);
   float adc;
   setup_spi(FALSE);
   setup_vref(FALSE);
   SET_TRIS_B (0xF0);
   output_high(PIN_A5);
   setup_spi(SPI_SLAVE | SPI_L_TO_H | SPI_CLK_DIV_4);
    adc=readnum();
    printf(" %f ",adc);
float readnum(void)
   int8 b0,b1,b2,b3;
   float result,value;
   int32 x;
   output_low(PIN_A5);
   delay_us(100);
   b0=spi_read(0);
   b1=spi_read(0);
   b2=spi_read(0);
   b3=spi_read(0);
   x=make32(b0,b1,b2,b3);
   union convert
   int32 y;
   float fval;
   val;
   val.y=x;
   result=val.fval;
   return result;
PostPosted: Thu Mar 25, 2010 11:59 am     Reply with quote
See this thread for more SPI slave examples:
http://www.ccsinfo.com/forum/viewtopic.php?t=41025
