hayee
Posted: Thu Mar 25, 2010 3:38 am |
Here is an example for SPI communication. One master and one slave.
In this code master reads the analog data and send to the slave using SPI.
For master
float adc1,adc2,value1;
int b0,b1,b2,b3;
setup_adc_ports(ALL_ANALOG);
setup_psp(PSP_DISABLED);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
// TODO: USER CODE!!
if (input(PIN_A5)==0)
set_adc_channel(0);
delay_ms(10);
adc1=read_adc();
adc2=(adc1*5)/1024;
value1=adc2;
printf("value is: %f \r\n",value1);
union convert
int8 b[4];
float fval;
val;
val.fval=value1;
b0=val.b[3];
b1=val.b[2];
b2=val.b[1];
b3=val.b[0];
spi_write(b0);
spi_write(b1);
spi_write(b2);
spi_write(b3);
delay_cycles(1);
For slave
float readnum(void);
float adc;
setup_spi(FALSE);
setup_vref(FALSE);
SET_TRIS_B (0xF0);
output_high(PIN_A5);
setup_spi(SPI_SLAVE | SPI_L_TO_H | SPI_CLK_DIV_4);
adc=readnum();
printf(" %f ",adc);
float readnum(void)
int8 b0,b1,b2,b3;
float result,value;
int32 x;
output_low(PIN_A5);
delay_us(100);
b0=spi_read(0);
b1=spi_read(0);
b2=spi_read(0);
b3=spi_read(0);
x=make32(b0,b1,b2,b3);
union convert
int32 y;
float fval;
val;
val.y=x;
result=val.fval;
return result;
