Core2
| How do you. . . |
Posted: Mon Jan 18, 2010 9:17 am |
Hello everyone,
How do you START Timer1? Also, how do you ENABLE it after you disable it? Looking in the CCS C manual I didn't see a T1_ENABLE parameter, just the T1_DISABLE.
Thanks,
Duane |
drh
Joined: 12 Jul 2004 Posts: 194 Location: Hemet, California USA
Posted: Mon Jan 18, 2010 9:23 am |
T1_INTERNAL _________________ David |
Posted: Mon Jan 18, 2010 12:04 pm |
| I thought that just set the clock for T1 to an internal source. |
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Mon Jan 18, 2010 12:10 pm |
It also enables it.
If you look at the code that's generated in the setup command, enabling the timer is one of the things that resulting code does.
Posted: Mon Jan 18, 2010 2:39 pm |
Good deal!
Thanks,
Duane |
