How do you. . .
Core2
How do you. . .
PostPosted: Mon Jan 18, 2010 9:17 am     Reply with quote
Hello everyone,
How do you START Timer1? Also, how do you ENABLE it after you disable it? Looking in the CCS C manual I didn't see a T1_ENABLE parameter, just the T1_DISABLE.
Thanks,
Duane
drh
PostPosted: Mon Jan 18, 2010 9:23 am     Reply with quote
T1_INTERNAL
David
PostPosted: Mon Jan 18, 2010 12:04 pm     Reply with quote
I thought that just set the clock for T1 to an internal source.
bkamen
PostPosted: Mon Jan 18, 2010 12:10 pm     Reply with quote
It also enables it.
If you look at the code that's generated in the setup command, enabling the timer is one of the things that resulting code does.
-Ben
PostPosted: Mon Jan 18, 2010 2:39 pm     Reply with quote
Good deal!
Thanks,
Duane
