arun Guest
| Load cell amplifier IC required or a high resolution ADC |
Posted: Tue Oct 05, 2004 11:34 pm |
Can anyone suggest some Load cell amplifier ICs, I tried using a MCP 3208 ADC directly with the load cell bridge arms , I find the output very low , as low as 1mV.
A higher resolution ADC might do , Microchip seems to have reached the limit with 12 bit ADCs.
I found some like CS 5520, CS 5516, but these are very expensive and sophisticated to use.
thanks
arun |
Will Reeve
Joined: 30 Oct 2003 Posts: 209 Location: Norfolk, England
Posted: Wed Oct 06, 2004 1:55 am |
I am using a AD8551 opamp as a load cell amplifer into a 10bit ADC (don't need the higher resolution as you seem to). Are you sure 12bits is not high enough?
Will |
sar
Posted: Thu Oct 07, 2004 12:57 pm |
We use both LTC2408 24bit A/D or INA125U (nice as it has built in programmable reference).
Woz |
Humberto
Posted: Thu Oct 07, 2004 6:55 pm |
I used the MCP3204 (4Chnnl) 12 bit ADC) wich is the young brother of the MCP3208
(8Chnnl) 12 Bit ADC and it function like a shame, but I noticed that for a good behaviour,
it needs a low impedance signal source. (say < 1K). Reading your comments,
I guess that you have a big impedance mismatch. I would think in an instrumentation
ampliffier as front end to get a good improvement matching the Load Cell with a low
impedance ADC.
I had to work around the MCP3208.C driver because it doesn´t work properly.
Best wishes,
Humberto |
Kenny
Posted: Thu Oct 07, 2004 8:05 pm |
Maxim have cheap single-supply instrumentation amplifiers suitable for strain gauge
applications like load cells.
MAX4462HESA has a fixed gain of 100.
I have used lots of these to amplify the signals from strain gauges on composite materials.
http://pdfserv.maxim-ic.com/en/ds/MAX4460-MAX4462.pdf
In your case if you really only have a 1mV signal from the load cell you will need a gain
of at least 1000 to get into the volts range. Gains greater than 1000 are generally not used
because of problems with noise and drift.
I suspect that you are using only a limited part of the load cell's range.
The MAX4194 is another one I have used with metals.
http://pdfserv.maxim-ic.com/en/ds/MAX4194-MAX4197.pdf
The gain can be set with a single resistor.
Both of these have a reference input that can be used to offset the output if the load cell
is used for both tension and compression.
I would recommend that if possible use a load cell more appropriate to the expected load
so as to get a bigger signal, and therefore a better signal/noise ratio. |
Will Reeve
Posted: Fri Oct 08, 2004 2:59 am |
The reference design for the AD8551 (from the datasheet) gives 0 to 40mV from the strain guage (running off 4v) and gives a 0 to 4V output. Perfect for the PIC. I guess you need anothe x4 gain to get your 0 to 1mV up to 4V which might give you some noise problems, layout would be quite critical.
Will |
kender
Posted: Fri Oct 08, 2004 11:58 pm |
I had a similar problem recently. My load cell had a differential output (S+ and S-) of +/- 200 mV full swing. I ended up using an instrumentation amplifier LT1167. Keep in mind though - most in-amos do not have a rail-to-rail output. If you need the R2R output - make you own "in-amp" out of R2R op-amps (such as LMC6462, LM6132).
Just my $.02.
Nick |
dave
Joined: 21 Dec 2003 Posts: 7 Location: Sheffield, South Yorks, UK
| Load cell bridges |
Posted: Sat Oct 09, 2004 1:41 am |
As you will probably know most load cell bridges are 350 ohm impedance, the usual standard for load cells is 2mV/volt, and most instrumentation has its own onboard 10 volt load cell bridge power supply so for full working range output of the load cell with 10 volts is 0-20mV.
Regards Dave |
rRolf Meier Guest
| LTC2408 Driver |
Posted: Wed Mar 04, 2009 2:48 pm |
| Anonymous wrote: | We use both LTC2408 24bit A/D or INA125U (nice as it has built in programmable reference).
Woz | Where did you get (buy) a Windows driver for the LTC2408 ?
Thank you and regards from Belgium Rolf |
kender
| Re: LTC2408 Driver |
Posted: Mon Apr 20, 2009 4:27 am |
| rRolf Meier wrote: | | Where did you get (buy) a Windows driver for the LTC2408 ? |
Hi Rolf,
LTC2408 has an SPI interface, which isn't intended for direct interfacing with PC. However, SPI can be bit-banged on the parallel port. That requires only a parallel port driver. Here's an app note by Maxim explaining how it can be done: http://www.maxim-ic.com/appnotes.cfm/an_pk/1142. You can also get results by googling "spi parallel port".
Another alternative is to buy a USB to SPI host adaptor, such as Aardvark made by TotalPhase, or USB-8451 made by National Instruments.
- Nick _________________ Read the label, before opening a can of worms. |
