		| Author | Message |
		| arun Guest
				| Load cell amplifier IC required or a high resolution ADC |
				|  Posted: Tue Oct 05, 2004 11:34 pm |   |
				| Hi,
 Can anyone suggest some Load cell amplifier ICs, I tried using a MCP 3208 ADC directly with the load cell bridge arms , I find the output very low , as low as 1mV.
 A higher resolution ADC might  do , Microchip seems to have reached the limit with 12 bit ADCs.
 I found some like CS 5520, CS 5516, but these are very expensive and sophisticated to use.
 thanks
 arun
		| Will Reeve
				|  Posted: Wed Oct 06, 2004 1:55 am |   |
				| I am using a AD8551 opamp as a load cell amplifer into a 10bit ADC (don't need the higher resolution as you seem to). Are you sure 12bits is not high enough?
 Will
		| sar
		| Guest
				|  Posted: Thu Oct 07, 2004 12:57 pm |   |
				| We use both LTC2408 24bit A/D or INA125U (nice as it has built in programmable reference).
 Woz
		| Humberto
				|  Posted: Thu Oct 07, 2004 6:55 pm |   |
				| Hi,
 I used the  MCP3204 (4Chnnl) 12 bit ADC) wich is the young brother of the MCP3208
 (8Chnnl) 12 Bit ADC and it function like a shame, but I noticed that for a good behaviour,
 it needs a low impedance signal source. (say < 1K). Reading your comments,
 I guess that you have a big impedance mismatch. I would think in an instrumentation
 ampliffier as front end to get a good improvement matching the Load Cell with a low
 impedance ADC.
 I had to work around the MCP3208.C driver because it doesn´t work properly.
 Best wishes,
 Humberto
		| Kenny
				|  Posted: Thu Oct 07, 2004 8:05 pm |   |
				| Maxim have cheap single-supply instrumentation amplifiers suitable for strain gauge applications like load cells.
 MAX4462HESA has a fixed gain of 100.
 I have used lots of these to amplify the signals from strain gauges on composite materials.
 http://pdfserv.maxim-ic.com/en/ds/MAX4460-MAX4462.pdf
 In your case if you really only have a 1mV signal from the load cell you will need a gain
 of at least 1000 to get into the volts range. Gains greater than 1000 are generally not used
 because of problems with noise and drift.
 I suspect that you are using only a limited part of the load cell's range.
 The MAX4194 is another one I have used with metals.
 http://pdfserv.maxim-ic.com/en/ds/MAX4194-MAX4197.pdf
 The gain can be set with a single resistor.
 Both of these have a reference input that can be used to offset the output if the load cell
 is used for both tension and compression.
 I would recommend that if possible use a  load cell more appropriate to the expected load
 so as to get a bigger signal, and therefore a better signal/noise ratio.
		| Will Reeve
				|  Posted: Fri Oct 08, 2004 2:59 am |   |
				| The reference design for the AD8551 (from the datasheet) gives 0 to 40mV from the strain guage (running off 4v) and gives a 0 to 4V output. Perfect for the PIC.  I guess you need anothe x4 gain to get your 0 to 1mV up to 4V which might give you some noise problems, layout would be quite critical.
 Will
		| kender
				|  Posted: Fri Oct 08, 2004 11:58 pm |   |
				| I had a similar problem recently.  My load cell had a differential output (S+ and S-) of +/- 200 mV full swing.  I ended up using an instrumentation amplifier LT1167.  Keep in mind though - most in-amos do not have a rail-to-rail output.  If you need the R2R output - make you own "in-amp" out of R2R op-amps (such as LMC6462, LM6132).
 Just my $.02.
 Nick
		| dave
				| Load cell bridges |
				|  Posted: Sat Oct 09, 2004 1:41 am |   |
				| As you will probably know most load cell bridges are 350 ohm impedance, the usual standard for load cells is 2mV/volt, and most instrumentation has its own onboard 10 volt load cell bridge power supply so for full working range output of the load cell with 10 volts is 0-20mV. Regards Dave
		| rRolf Meier Guest
				| LTC2408  Driver |
				|  Posted: Wed Mar 04, 2009 2:48 pm |   |
				| Where did you get (buy) a Windows driver for the LTC2408 ? 	  | Anonymous wrote: |  	  | We use both LTC2408 24bit A/D or INA125U (nice as it has built in programmable reference).
 Woz
 Thank you and regards from Belgium    Rolf
		| kender
				| Re: LTC2408  Driver |
				|  Posted: Mon Apr 20, 2009 4:27 am |   |
				|  	  | rRolf Meier wrote: |  	  | Where did you get (buy) a Windows driver for the LTC2408 ? |
 Hi Rolf,
 LTC2408 has an SPI interface, which isn't intended for direct interfacing with PC.  However, SPI can be bit-banged on the parallel port.  That requires only a parallel port driver.  Here's an app note by Maxim explaining how it can be done: http://www.maxim-ic.com/appnotes.cfm/an_pk/1142.  You can also get results by googling "spi parallel port".
 Another alternative is to buy a USB to SPI host adaptor, such as Aardvark made by TotalPhase, or USB-8451 made by National Instruments.
 - Nick
 Read the label, before opening a can of worms.
