Help with 4x3 keypad library
ZeroF877A
PostPosted: Mon Mar 17, 2008 2:41 pm     Reply with quote
Hello, I'm relatively new to CCS (I started 3 days ago actually). So far I have managed to work with the LCD library properly, but when trying to use the KBD library, one problem comes up... Thing is, I'm not sure how is the keypad physically connected to the PIC.
I've used keypads before, but those were 4x4 keypads using a .ASM library (Been working with assembly for about 9 months). So I decided to ask here before trying something like:
char kbd_getc(){
#asm
#endasm}
And I'm not even sure if that'll work!
Thanks in advice for any help I can get!
Oh, by the way, I'm working with a PIC16F877 @ 4Mhz, using the CCS C compiler 4.023 (So says the Compiler version thingy). The libraries are the standard ones that come along in the "Drivers" folder.
PostPosted: Mon Mar 17, 2008 2:46 pm     Reply with quote
These threads talk about how to connect the keypad to the PIC:
http://www.ccsinfo.com/forum/viewtopic.php?t=21852
http://www.ccsinfo.com/forum/viewtopic.php?t=25488
http://www.ccsinfo.com/forum/viewtopic.php?t=23467
If that doesn't help, then post the manfacturer and part number of
your keypad. If possible, post a link to the data sheet for it.
If you are using a board that has a built-in keypad, then post the
above information for that board.
ZeroF877A
PostPosted: Mon Mar 17, 2008 3:00 pm     Reply with quote
Actually, it works perfectly fine. Just in case, I tested it using PortB and the respective pullups, but in my case, I need to make it woth with PortD, along with the LCD screen in that same port. Should I add hardware pullups, or should I trust the library when it says:
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
Thank you very much!
