Micka
| struct of function's pointer |
Posted: Sat Jan 26, 2008 2:50 pm |
How to make a structure with function pointers like this :
struct test{
void (*tst)(int,char);
void (*tst2)(void*,char);
I have this error : Unknown type
Thanks for help |
Posted: Sat Jan 26, 2008 10:56 pm |
The program below demonstrates using a function pointer in a structure.
I tested this with PCH vs. 4.066 and it works. It displays the following:
You will notice that I have to move the function pointer from the
structure element into an intermediate variable ('temp') before I call it.
I couldn't find a way to do it without using the intermediate variable.
I don't have any more time to spend on it.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
// Create a simple function that displays some text.
void Hello(void)
printf("Hello World\n\r");
// Typedef a function pointer.
typedef void (*_fptr)(void);
// Create a structure that contains two variables
// and a fuction pointer. Initialize them.
struct
int8 value;
int8 temp;
_fptr func_ptr;
}My_struct = {0, 0, Hello};
// Create a temp variable to hold a function pointer.
_fptr temp;
// Copy the function pointer from the structure into 'temp'.
temp = My_struct.func_ptr;
// Call the Hello function.
(*temp)();
CCS has this on their versions page:
| Quote: | | 4.058 A bug involving pointers to functions is fixed |
If you have an earlier version there might be problems.
In that case, see this thread. It might help:
http://www.ccsinfo.com/forum/viewtopic.php?t=31637 |
Micka
Posted: Sun Jan 27, 2008 11:58 am |
| Thank you for your help. |
