function within a struct
Storic
PostPosted: Tue Aug 07, 2007 4:54 am     Reply with quote
Can you assign a pointer to a function within a struct
typedef struct
        int8   Set1;
        int8   call;
        void   *function();     // pointer to a function
        } Call_struct ;
void    function()
        //insert code;
Confused
What has been learnt if you make the same mistake? Wink
PostPosted: Tue Aug 07, 2007 2:21 pm     Reply with quote
I'm not sure how to reference a function pointer as a structure element.
I mean, when you call the function. It kept giving me an "Expect ;" error.
So, I just moved the function pointer from the structure element into
a temp variable (declared as a function pointer), and had it call the
"Hello" function. Then it compiled, and it worked. It displays this:
Hello World
There may be a way to do it. I just don't have any more time to spend
on it. Here's the working test program. This was tested with vs. 4.049.
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
void Hello(void)
printf("Hello World\n\r");
typedef void (*_fptr)(void);
struct
 int8   Set1;
 int8   call;
 _fptr func_ptr;
}Call_struct;
_fptr temp;
Call_struct.func_ptr = Hello;
temp = Call_struct.func_ptr;
(*temp)();
Storic
PostPosted: Tue Aug 07, 2007 6:10 pm     Reply with quote
Thankyou,
I have slightly modified your code to expand on the function call
#include <18f67J10.h>
#device *=16
#device adc=8
#FUSES H4_SW                    //High speed osc with SW enabled 4x PLL
#FUSES NODEBUG                  //No Debug mode for ICD
//#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode enabled
#FUSES STVREN                   //Stack full/underflow will cause reset
#FUSES NOPROTECT                //Code not protected from reading
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES IESO                     //Internal External Switch Over mode enabled
#FUSES PRIMARY                  //Primary clock is system clock when scs=00
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=20000000)
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7,enable = PIN_C1, ERRORS)
void Hello(void)
void Thankyou(void)
printf("thankyou for your help\n\r");
void Goodby(void)
printf("coding on \n\n\r");
typedef void (*_ptr)(void);
typedef struct
 int8   Set1;
 int8   call;
 void   *func_ptr;
}Call_struct;
Call_struct key[3];
int i,j =0;
_ptr temp[3];
key[0].func_ptr = Hello;
key[1].func_ptr = Thankyou;
key[2].func_ptr = Goodby;
for (i=0;i<=2;++i) {temp[i] = key[i].func_ptr;}
(*temp[0])();
(*temp[1])();
delay_ms(2000);
(*temp[2])();
Thanks Smile Shocked
Pret
PostPosted: Wed Aug 08, 2007 12:33 am     Reply with quote
Anyway.... function pointers is not supported by CCS due the PIC lack of stack. Sice all local variables are stored as global, compiler must know the entire calling tree before. A function pointer breaks this roule.
In the above example, compile makes an workaround. Internally he's saving tags to functions instead pointers. When a call occurs, internally he substitute with switch (tag) and calls the right function. You can find this in CCS help.
PostPosted: Wed Aug 08, 2007 1:22 am     Reply with quote
Actually, the compiler does create a pointer to the function, as you can
see in the .LST file code below. This is generated from the program
that I posted earlier in this thread.
Unfortunately, there's a bug in it. It's not storing the MSB of the 'Hello()'
function address. The program works if the function is in the first 256
bytes of program memory, but it fails if it's located higher in program
memory.
... void Hello(void)
.... printf("Hello World\n\r");
0030:  CLRF   0C
0032:  MOVF   0C,W
0034:  RCALL  0004
0036:  INCF   0C,F
0038:  MOVWF  00
003A:  MOVF   00,W
003C:  BTFSS  F9E.4
003E:  BRA    003C
0040:  MOVWF  FAD
0042:  MOVLW  0D
0044:  SUBWF  0C,W
0046:  BNZ   0032
0048:  RETLW  00
... Call_struct.func_ptr = Hello;
0068:  MOVLW  00      // *** BUG -- MSB of address is not saved.
006A:  MOVLW  30
006C:  MOVWF  08
... temp = Call_struct.func_ptr;
006E:  CLRF   0B
0070:  MOVFF  08,0A
.... (*temp)();
0074:  CLRF   FEA
0076:  MOVLW  0A
0078:  MOVWF  FE9
007A:  RCALL  0022
So, I came up with a fix for that. I declared the function pointer
in the structure as an 'int16'. Then in main(), when I assign the
the function pointer to 'temp', I cast it to an _fptr. In fact, that
last part doesn't seem to be needed.
Here's a revised program with the changes given above.
#include <18F452.h>
#org 0x1000,0x1030
void Hello(void)
struct
 int8   Set1;
 int8   call;
 int16  func_ptr;
}Call_struct;
_fptr temp;
temp = (_fptr)Call_struct.func_ptr;
(*temp)();
Here's part of the .LST file for the revised program. You'll note that
the 'Hello()' function is at 0x1000, because it's now org'ed there.
If you look at the line where the address of 'Hello' is loaded into the
structure element, you'll see that it's getting the full 16-bit address now.
It works when I run it in MPLAB simulator. I tested this with vs. 4.046.
1000:  CLRF   0C
1002:  MOVF   0C,W
1004:  CALL   0008
1008:  INCF   0C,F
100A:  MOVWF  00
100C:  MOVF   00,W
100E:  BTFSS  F9E.4
1010:  BRA    100E
1012:  MOVWF  FAD
1014:  MOVLW  0D
1016:  SUBWF  0C,W
1018:  BNZ   1002
101A:  RETLW  00
.................... Call_struct.func_ptr = Hello;
0052:  MOVLW  10
0054:  MOVWF  03
0056:  MOVLW  00
0058:  MOVWF  08
005A:  MOVFF  03,09
.................... temp = (_fptr)Call_struct.func_ptr;
005E:  MOVFF  09,0B
0062:  MOVFF  08,0A
.................... (*temp)();
0066:  CLRF   FEA
0068:  MOVLW  0A
006A:  MOVWF  FE9
006C:  RCALL  0026
Pret
PostPosted: Wed Aug 08, 2007 2:58 am     Reply with quote
Interesting...but:
The compiler does not permit pointers to functions so that the compiler can know at compile time the complete call tree. This is used to allocate memory for full RAM re-use. Functions that could not be in execution at the same time will use the same RAM locations. In addition since there is no data stack in the PICĀ®, function parameters are passed in a special way that requires knowledge at compile time of what function is being called. Calling a function via a pointer will prevent knowing both of these things at compile time. Users sometimes will want function pointers to create a state machine. The following is an example of how to do this without pointers:
enum tasks {taskA, taskB, taskC};
run_task(tasks task_to_run) {
switch(task_to_run) {
case taskA : taskA_main(); break;
case taskB : taskB_main(); break;
case taskC : taskC_main(); break;
Anyway, i tried some time ago to make a generic timer that take a pointer to a function to execute it recurrently. This was not working. Then after i found the reason from help. Maybe for simple and predictable calls works...
