Double line characters on LCD
Willie Erasmus
PostPosted: Wed Mar 19, 2003 1:59 am     Reply with quote
Hi all
Does anybody know how to write double line characters on a LCD? Can somebody tell me how to do it?
Willie
Original Post ID: 12820
Tomi
Re: Double line characters on LCD
PostPosted: Wed Mar 19, 2003 4:40 am     Reply with quote
If you use lcd.c then you have to insert a simple newline:
"First line\nSecond line"
If you don't use lcd.c then you have to set display address to 64 to access the 1st char of 2nd line.
:=Hi all
:=Does anybody know how to write double line characters on a LCD? Can somebody tell me how to do it?
:=Thanks
:=Willie
Original Post ID: 12823
Willie Erasmus
PostPosted: Wed Mar 19, 2003 4:44 am     Reply with quote
Thanks Tomi
...but I didn't put myself clearly. I want to know how to write double-high characters on a LCD?
Willie
Original Post ID: 12824
Tomi
PostPosted: Wed Mar 19, 2003 6:08 am     Reply with quote
Double-high means e.g. 10 mm characters on a 5mm LCD panel or do you have a graphic LCD panel?
If you have an alphanumeric LCD then I think you have a limited choice: you can define "I(left line) I(right line) _(underscore) _(upperscore) \ and / characters onto the 8-character user code space, so e.g. "MU" looks like this:
I\/I I I
I I I_I
I think it is a hard way. Much better to buy a 10mm chr height LCD Smile .
If you have a graphic LCD then it is more easier Smile : e.g. I implemented 16-point Courier font (cca. 8mm height on a 0.5mm pitch LCD) in a 18F452.
Original Post ID: 12828
Richard Slater
PostPosted: Wed Mar 19, 2003 7:28 am     Reply with quote
:=Hi all
:=Thanks
:=Willie
Hi there, am I right in thinking that you want to define a character set which uses 4 characters (ie double the size in each direction)?
If so you need to define four characters in the LED module's user RAM for each double-size char you want to display on the screen. Place them two on the top, two on the bottom to get the char you want. I have not done this, but it must be very easy to do, look on the internet for routines to define characters in RAM, or write you own. there is plenty of information around. I beleive that you will have to write a new four chars to RAM for every char you wish to display, as there is not enough user ram to define four times the ASCII table.
Hope this points you in the right direction
Richard
Original Post ID: 12830
Tomi
PostPosted: Wed Mar 19, 2003 8:18 am     Reply with quote
Of course theoretically you have right but keep in mind that the rest of the LCD panels (or at least the rest of those I know Smile ) have only a small user RAM to store 8 user characters what means 2 possible 2-size chars to display simple texts e.g. "papa", "mama", "byby" etc.
:=:=Hi all
:=:=Does anybody know how to write double line characters on a LCD? Can somebody tell me how to do it?
:=:=Thanks
:=:=Willie
:=Hi there, am I right in thinking that you want to define a character set which uses 4 characters (ie double the size in each direction)?
:=If so you need to define four characters in the LED module's user RAM for each double-size char you want to display on the screen. Place them two on the top, two on the bottom to get the char you want. I have not done this, but it must be very easy to do, look on the internet for routines to define characters in RAM, or write you own. there is plenty of information around. I beleive that you will have to write a new four chars to RAM for every char you wish to display, as there is not enough user ram to define four times the ASCII table.
:=Hope this points you in the right direction
:=Richard
Original Post ID: 12833
Greg Kuric
PostPosted: Wed Mar 19, 2003 1:51 pm     Reply with quote
Does anyone have, or is there, a file LIKE lcd.h for graphic LCDs. Could you post a link if a file like this is around.
Thanks ...
Original Post ID: 12846
