74597 Driver
Humberto
74597 Driver
PostPosted: Thu Jan 25, 2007 4:55 pm     Reply with quote
////                             74597.C                             ////
////  Driver for 74**597  8 Bit Shift Register with input latches    ////
////  void init_597( )                                               ////
////                    Must be called once in the initializacion.   ////
////  int get_597_In( )                                              ////
////                    Return the 8 parallel input data.            ////
////  Autor: Humberto                                                ////
// 74**597  8 Bit Shift Register with input latches
// PIN nomenclature used in the code is as follows:
//       PIN OUT
//       ___  ___
//   Q1-|        |- Vcc                   < = INPUTS
//   Q2-|        |- Q0
//   Q3-|       <|- PIN14 SER
//   Q4-|       <|- PIN13 SLOAD
//   Q5-|       <|- PIN12 RCK
//   Q6-|       <|- PIN11 SCK
//   Q7-|       <|- PIN10 SCLR
//  Gnd-|       >|- PIN9  Qout
//      |________|
void init_597()
   output_low(SCLR);      // activate reset
   delay_us(10);          //
   output_low(SCK);       // idle level
   output_low(RCK);       // idle level
   output_high(SLOAD);    // select serial
   output_high(SCLR);     // deactivate reset
int get_597_In()
int8 i, value;
  output_high(RCK);       // Data loaded to input latches
  delay_us(10);
  output_low(RCK);        // Freeze inputs
  delay_us(10);
  output_low(SLOAD);      // Data transfer from input latch to
  delay_us(10);           // shift registers
  output_high(SLOAD);
  for(i=1; i<=8; i++)     // Clock-in while collecting bits...
      shift_left(&value,1,input(Qout));
      output_high(SCK);   // going up clock pulse
      delay_us(10);
      output_low(SCK);    // recover idle level
  return(value);
Humberto
