Humberto
| 74597 Driver |
Posted: Thu Jan 25, 2007 4:55 pm |
//// 74597.C ////
//// Driver for 74**597 8 Bit Shift Register with input latches ////
//// void init_597( ) ////
//// Must be called once in the initializacion. ////
//// int get_597_In( ) ////
//// Return the 8 parallel input data. ////
//// Autor: Humberto ////
// 74**597 8 Bit Shift Register with input latches
// PIN nomenclature used in the code is as follows:
// PIN OUT
// ___ ___
// Q1-| |- Vcc < = INPUTS
// Q2-| |- Q0
// Q3-| <|- PIN14 SER
// Q4-| <|- PIN13 SLOAD
// Q5-| <|- PIN12 RCK
// Q6-| <|- PIN11 SCK
// Q7-| <|- PIN10 SCLR
// Gnd-| >|- PIN9 Qout
// |________|
void init_597()
output_low(SCLR); // activate reset
delay_us(10); //
output_low(SCK); // idle level
output_low(RCK); // idle level
output_high(SLOAD); // select serial
output_high(SCLR); // deactivate reset
int get_597_In()
int8 i, value;
output_high(RCK); // Data loaded to input latches
delay_us(10);
output_low(RCK); // Freeze inputs
delay_us(10);
output_low(SLOAD); // Data transfer from input latch to
delay_us(10); // shift registers
output_high(SLOAD);
for(i=1; i<=8; i++) // Clock-in while collecting bits...
shift_left(&value,1,input(Qout));
output_high(SCK); // going up clock pulse
delay_us(10);
output_low(SCK); // recover idle level
return(value);
Humberto |
