Version 4 Comments
Goto page 1, 2, 3 ... 17, 18, 19  Next
treitmey
Version 4 Comments
PostPosted: Mon Jul 24, 2006 3:35 pm     Reply with quote
Has anyone downloaded V4?
It is on the news page
http://www.ccsinfo.com/newsdesk_index.php?newsPath=ALL
But I have not seen it under the download page Crying or Very sad
PostPosted: Mon Jul 24, 2006 3:45 pm     Reply with quote
Vs. 3.249 came out on March 23, 2006. So for four months nothing
was released. Since then, one or both of my maintenance contracts
have run out for PCM and PCH. Are they going to extend them for
four more months, to make up for that "dead time" ?.
Darren Rook
Re: V4
PostPosted: Mon Jul 24, 2006 4:31 pm     Reply with quote
It's only available to people who signed up for beta. You can ask at any time to be added to the Beta.
I came, I saw, I compiled.
treitmey
I will be patient
PostPosted: Mon Jul 24, 2006 4:55 pm     Reply with quote
I will try to be patient. I'm on the list.
Thank you for your interest in becoming a beta tester for Version 4.0. You have been added to our list
dyeatman
Looking forward to the beta!!
PostPosted: Mon Jul 24, 2006 9:47 pm     Reply with quote
I'm on the list for beta as well and waiting to be notified...
From the V4 preview it looks like a bunch of new stuff to check out!
I have a newly finished V3 project I'll port to V4 to see what happens.
treitmey
PostPosted: Tue Jul 25, 2006 8:05 am     Reply with quote
I Got an invalid floating point from the download manager.
Made dir at c:\programfiles\PICC
dropped new *.crg files there
I have the dowload util at ..PICC\download
I ran the Download utility.
edit...image removed
PostPosted: Tue Jul 25, 2006 8:23 am     Reply with quote
same invalid floating point for me#
also, it told me there was a newer version of the CS software update utilty, even though I only downloaded it 5 minutes earlier
mikew
bscogg
Error
PostPosted: Tue Jul 25, 2006 9:08 am     Reply with quote
Same here. I believe I received this error before when upgrading to a new rev that needed new cfg files.
Waiting in anticipation....
mmprestine
PostPosted: Tue Jul 25, 2006 9:15 am     Reply with quote
I have the same issue also. I have talked with tech support and they are working out a solution.
MP
mmprestine
PostPosted: Tue Jul 25, 2006 11:48 am     Reply with quote
The downloader link has changed. You now download the new downloader without having to update it. I works pretty well.
MP Wink
melstav
PostPosted: Tue Jul 25, 2006 12:27 pm     Reply with quote
I just downloaded the installer again, and the download utility is still doing exactly the same thing. "An Updated version is available" then floating point error.
And the download utility MUST be in the same directory as your 3.x install (or a subdirectory) AND you have to overwrite your pre-existing license files with the new ones before you can even get far enough for the thing to error out.
I refuse to overwrite my 3.x compiler with the 4 beta.
I'm on Windows XP Pro.
treitmey
PostPosted: Tue Jul 25, 2006 1:34 pm     Reply with quote
Melstav, just make a copy.
I now have my V4 running
melstav
PostPosted: Tue Jul 25, 2006 1:55 pm     Reply with quote
Did that already. Before I made my initial post.
Still doesn't change the fact that the download utility complains about needing an update and then errors out with "invalid floating point operation".
What version of Windows do you have?
j_s_connell
PostPosted: Tue Jul 25, 2006 3:10 pm     Reply with quote
CCS v4 doesn't seem to install into MPLAB properly. Anyone else had this problem?
dyeatman
PostPosted: Tue Jul 25, 2006 3:27 pm     Reply with quote
When trying to install the Download Manager under Win98 it complains about a missing GDIPLUS.DLL and, of course, I therefore cannot install the compiler.
Under XP everything seems to install with no problems. However, when running the Code Format utility it hangs and I have to abort and restart the entire program... need to check to see if this is one of the items that isn't supposed to work yet..:-)
Page 1 of 19
