treitmey
Posted: Mon Jul 24, 2006 3:45 pm |
Vs. 3.249 came out on March 23, 2006. So for four months nothing
was released. Since then, one or both of my maintenance contracts
have run out for PCM and PCH. Are they going to extend them for
four more months, to make up for that "dead time" ?. |
Darren Rook
Joined: 06 Sep 2003 Posts: 287 Location: Milwaukee, WI
Re: V4 |
Posted: Mon Jul 24, 2006 4:31 pm |
treitmey wrote: | But I have not seen it under the download page  |
It's only available to people who signed up for beta. You can ask at any time to be added to the Beta. _________________ I came, I saw, I compiled. |
treitmey
I will be patient |
Posted: Mon Jul 24, 2006 4:55 pm |
I will try to be patient. I'm on the list.
Quote: | Thank you for your interest in becoming a beta tester for Version 4.0. You have been added to our list |
dyeatman
Looking forward to the beta!! |
Posted: Mon Jul 24, 2006 9:47 pm |
I'm on the list for beta as well and waiting to be notified...
From the V4 preview it looks like a bunch of new stuff to check out!
I have a newly finished V3 project I'll port to V4 to see what happens. |
treitmey
Posted: Tue Jul 25, 2006 8:05 am |
I Got an invalid floating point from the download manager.
Made dir at c:\programfiles\PICC
dropped new *.crg files there
I have the dowload util at ..PICC\download
I ran the Download utility.
edit...image removed
Posted: Tue Jul 25, 2006 8:23 am |
same invalid floating point for me#
also, it told me there was a newer version of the CS software update utilty, even though I only downloaded it 5 minutes earlier
mikew |
bscogg
Error |
Posted: Tue Jul 25, 2006 9:08 am |
Same here. I believe I received this error before when upgrading to a new rev that needed new cfg files.
Waiting in anticipation.... |
mmprestine
Joined: 13 Jan 2004 Posts: 29 Location: Green Bay, Wisconsin
Posted: Tue Jul 25, 2006 9:15 am |
I have the same issue also. I have talked with tech support and they are working out a solution.
MP |
mmprestine
Posted: Tue Jul 25, 2006 11:48 am |
The downloader link has changed. You now download the new downloader without having to update it. I works pretty well.
MP  |
melstav
Posted: Tue Jul 25, 2006 12:27 pm |
I just downloaded the installer again, and the download utility is still doing exactly the same thing. "An Updated version is available" then floating point error.
And the download utility MUST be in the same directory as your 3.x install (or a subdirectory) AND you have to overwrite your pre-existing license files with the new ones before you can even get far enough for the thing to error out.
I refuse to overwrite my 3.x compiler with the 4 beta.
I'm on Windows XP Pro. |
treitmey
Posted: Tue Jul 25, 2006 1:34 pm |
Melstav, just make a copy.
I now have my V4 running |
melstav
Posted: Tue Jul 25, 2006 1:55 pm |
Quote: | Melstav, just make a copy. |
Did that already. Before I made my initial post.
Still doesn't change the fact that the download utility complains about needing an update and then errors out with "invalid floating point operation".
What version of Windows do you have? |
j_s_connell
Posted: Tue Jul 25, 2006 3:10 pm |
CCS v4 doesn't seem to install into MPLAB properly. Anyone else had this problem? |
dyeatman
Posted: Tue Jul 25, 2006 3:27 pm |
When trying to install the Download Manager under Win98 it complains about a missing GDIPLUS.DLL and, of course, I therefore cannot install the compiler.
Under XP everything seems to install with no problems. However, when running the Code Format utility it hangs and I have to abort and restart the entire program... need to check to see if this is one of the items that isn't supposed to work yet..:-) |
