PWM pins that are not CCP
Jim
PostPosted: Sun May 07, 2006 3:13 pm     Reply with quote
Hi;
I'm using the pic18f4331 which has 2 ccp pins and 8 pwm pins. I've seen plenty of code for setup_ccpX(ccp_pwm) and I understand the math behind it, but how dow I set up the other PWM pins that are not CCP ? Could someone provide a code snippet? thanks
PostPosted: Sun May 07, 2006 3:35 pm     Reply with quote
Look at the EX_POWER_PWM.C file for an example. It's in this folder:
c:\Program Files\PICC\Examples
Look in the CCS manual to see an explanation of the functions used
in that example file.
http://www.ccsinfo.com/downloads.php
Jim
I don't have that
PostPosted: Sun May 07, 2006 4:04 pm     Reply with quote
I don't have that code example.. I must have an older version but I don't have that in my examples file. Could you just post a snippet?
PostPosted: Sun May 07, 2006 6:08 pm     Reply with quote
According to the forum rules posted here, we're not supposed to post
CCS example files. See item #10:
http://www.ccsinfo.com/forum/viewtopic.php?t=26245
You might be able to get CCS support to send it to you, if you
email them and ask for it. Give them your compiler registration
number so they know you own the compiler. I don't know for
sure if this method will work.
jim
any would do
PostPosted: Sun May 07, 2006 6:10 pm     Reply with quote
I don't need the code right from the example
any would do..
Jim
Got a snippet
PostPosted: Mon May 08, 2006 7:50 am     Reply with quote
I got a snippet from support .. thanks anyway
