ER400TRS USING PIC C PROGRAMMING
ikeme
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Mon Nov 28, 2005 1:12 pm     Reply with quote
CAN SOMEONE HELP ME TO AMEND THIS CODE
ITS MET TO BE DOING
PIC C programme that will echo back every ASCII character received on the ER400TRS connected to the PICRadio PCB
#include <16F876.h>
//#device 16F876 ICD=TRUE
#fuses XT,NOWDT, NOPROTECT, NOPUT, NOBROWNOUT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, ERRORS)
unsigned char c;
while(TRUE) // do forever
// host is ready
// receive byte
if(!(input(PIN_C4)))
c=getc();
output_high(PIN_C3);
putc(c);
delay_ms(1000); // send characters every 1 sec
output_high(PIN_C2);
erefaaco
PostPosted: Mon Nov 28, 2005 1:38 pm     Reply with quote
Add the NOLVP fuse. Without that fuse, your program could be locking up
and you might falsely think it's due to a coding problem. Example:
#fuses XT,NOWDT, NOPROTECT, NOPUT, NOBROWNOUT, NOLVP
asmallri
PostPosted: Mon Nov 28, 2005 8:03 pm     Reply with quote
#define XTAL_FREQ 4000000
#use delay(clock=XTAL_FREQ,RESTART_WDT)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors, restart_wdt)
   // Serial Ring Buffer and control registers
#define   CCRSize   64      // Command Construction Buffer size
   // Console Rx Ring Buffer control
byte   RxHeadC;      // Console Ring Buffer Head pointer
byte   RxTailC;      // Console Ring Buffer Tail pointer
   // allocate communications buffer memory
#define RxCQsize   64      // Console Rx buffer size
byte   RxBaseC[RxCQsize];   #locate Rx_BaseC = 0x0190   // Console Rx Buffer location
   // Tell compiler where to find serial control registers and bits for PIC16F87x
#byte   RCREG = 0x1A
#byte   RCSTA = 0x18
#define   OERR    1
#define   CREN   4
#int_RDA
void serial_isr()
   // ; test for overrun error
   if (bit_test(RCSTA, OERR))
      bit_clear(RCSTA, CREN);      // clear continous receive bit
      bit_set(RCSTA, CREN);      // set continous receive bit
   RxBaseC[RxHeadC++]=getc();
   RxHeadC %= RxCQsize;
char getc_QConsole()
// getc_QConsole
//   Routine to read (remove) a byte from the Console receive buffer
// On Entry:
//   Rx_TailC   points to next byte to be read from the logger receive buffer
// On Exit:
//   Rx_TailC   points to the next position in the buffer
// Calls:
   Char RxChar;
   RxChar = RxBaseC[RxTailC++];
   RxTailC %= RxCQSize;
   return(RxChar);
void main ()
   int i;
   disable_interrupts(global);
//   setup_wdt(WDT_ON);
   restart_wdt();
   // initialise Console receive buffer pointers
   RxHeadC = 0;
   RxTailC = 0;
   // initialise the console receive USART status
   i = RCREG;
   i = RCREG;
   if (Bit_test(RCSTA,OERR))
      // here on overrun error - need to reset the USART
      bit_clear(RCSTA,CREN);      // clear continous receive bit
      bit_set(RCSTA,CREN);      // set continous receive bit
   // disable UART Rx interrupt
   clear_interrupt(INT_RDA);      // clear interrupt flag
   enable_interrupts(INT_RDA);      // enable the interrupt
   enable_interrupts(global);
   for (;;)
      // host is ready
      // receive byte
         if (RxHeadC != RxTailC)
            c=getc_QConsole();
            putc(c);
Regards, Andrew
