ikeme
| ER400TRS USING PIC C PROGRAMMING |
Posted: Mon Nov 28, 2005 1:12 pm |
CAN SOMEONE HELP ME TO AMEND THIS CODE
ITS MET TO BE DOING
PIC C programme that will echo back every ASCII character received on the ER400TRS connected to the PICRadio PCB
#include <16F876.h>
//#device 16F876 ICD=TRUE
#fuses XT,NOWDT, NOPROTECT, NOPUT, NOBROWNOUT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, ERRORS)
unsigned char c;
while(TRUE) // do forever
// host is ready
// receive byte
if(!(input(PIN_C4)))
c=getc();
output_high(PIN_C3);
putc(c);
delay_ms(1000); // send characters every 1 sec
output_high(PIN_C2);
} _________________ erefaaco |
Posted: Mon Nov 28, 2005 1:38 pm |
Add the NOLVP fuse. Without that fuse, your program could be locking up
and you might falsely think it's due to a coding problem. Example:
#fuses XT,NOWDT, NOPROTECT, NOPUT, NOBROWNOUT, NOLVP |
asmallri
Joined: 12 Aug 2004 Posts: 1678 Location: Perth, Australia
Posted: Mon Nov 28, 2005 8:03 pm |
| Code: | #fuses XT,NOWDT, NOPROTECT, NOPUT, NOBROWNOUT, NOLVP
#define XTAL_FREQ 4000000
#use delay(clock=XTAL_FREQ,RESTART_WDT)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors, restart_wdt)
// Serial Ring Buffer and control registers
#define CCRSize 64 // Command Construction Buffer size
// Console Rx Ring Buffer control
byte RxHeadC; // Console Ring Buffer Head pointer
byte RxTailC; // Console Ring Buffer Tail pointer
// allocate communications buffer memory
#define RxCQsize 64 // Console Rx buffer size
byte RxBaseC[RxCQsize]; #locate Rx_BaseC = 0x0190 // Console Rx Buffer location
// Tell compiler where to find serial control registers and bits for PIC16F87x
#byte RCREG = 0x1A
#byte RCSTA = 0x18
#define OERR 1
#define CREN 4
#int_RDA
void serial_isr()
// ; test for overrun error
if (bit_test(RCSTA, OERR))
bit_clear(RCSTA, CREN); // clear continous receive bit
bit_set(RCSTA, CREN); // set continous receive bit
RxBaseC[RxHeadC++]=getc();
RxHeadC %= RxCQsize;
char getc_QConsole()
// getc_QConsole
// Routine to read (remove) a byte from the Console receive buffer
// On Entry:
// Rx_TailC points to next byte to be read from the logger receive buffer
// On Exit:
// Rx_TailC points to the next position in the buffer
// Calls:
Char RxChar;
RxChar = RxBaseC[RxTailC++];
RxTailC %= RxCQSize;
return(RxChar);
void main ()
int i;
disable_interrupts(global);
// setup_wdt(WDT_ON);
restart_wdt();
// initialise Console receive buffer pointers
RxHeadC = 0;
RxTailC = 0;
// initialise the console receive USART status
i = RCREG;
i = RCREG;
if (Bit_test(RCSTA,OERR))
// here on overrun error - need to reset the USART
bit_clear(RCSTA,CREN); // clear continous receive bit
bit_set(RCSTA,CREN); // set continous receive bit
// disable UART Rx interrupt
clear_interrupt(INT_RDA); // clear interrupt flag
enable_interrupts(INT_RDA); // enable the interrupt
enable_interrupts(global);
for (;;)
// host is ready
// receive byte
if (RxHeadC != RxTailC)
c=getc_QConsole();
putc(c);
_________________ Regards, Andrew
