Driver for linear access of 8 memory 24LC512 512KB!!
pikman
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Sun Jan 07, 2007 10:17 pm     Reply with quote
Hello, this simple driver allows to address 8 serial eeproms 24LC512 as one chip of 512KB (524.288 bytes), in my develop it has been of a lot of help, I hope also helps. Very Happy
Ariel.
////        Library for lineal address to a bank of 8 24LC512 chip memory      ////
////        0 to 0x07FFF                                                       ////
//// init_24512x8();  Call before the other functions are used                 ////
//// writeByte24512x8(a,d); Write the byte (int8)d to the address (int32)a     ////
//// d=ReadByte24512x8(a); Read the byte int8)d from the address (int32)a      ////
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_B1
#define EEPROM_SCL  PIN_B0
#endif
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define MULTIPLE_EEPROM_ADDRESS int32
#define EEPROM_SIZE   524288
void init_ext_eeprom()
   output_float(EEPROM_SCL);
   output_float(EEPROM_SDA);
void writeByte_24512x8(int32 memaddress, int8 data){
   int16 address;
   int8  controlbyte;
   short int status;
   address=memaddress;
   controlbyte=(0xa0 | ((make8(memaddress,2))<<1));
   i2c_start();
   i2c_write(controlbyte);
   i2c_write(address>>8);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
   // AckNolege pooling
   i2c_start();
   status=i2c_write(controlbyte);
   while(status==1)
   i2c_start();
   i2c_stop();
int8 readByte_24512x8(int32 memaddress){
    int16 address;
    int8  controlbyte;
    int8  data;
    address=memaddress;
    i2c_start();
    i2c_write(address);
    i2c_start();
    i2c_write(controlbyte|1);
    data=i2c_read(0);
    i2c_stop();
    return data;
BOB_SANTANA
PostPosted: Mon Jan 08, 2007 3:34 pm     Reply with quote
Excellent Work Pikman
Could you be kind enough just to do a quick example program
Thanks in advance
BOB_Santana Smile
last_turk
64K x 8 (512 Kbit)
PostPosted: Tue Mar 20, 2007 9:28 am     Reply with quote
24AA512/24LC512/24FC512 (24XX512*) is a 64K x 8 (512 Kbit)
and eeprom address must be 0 to 0xFFFF
thanks for all
pikman
PostPosted: Mon Apr 02, 2007 11:23 pm     Reply with quote
last_turk, I don't understant, my driver is to use whit 8 units 24AA512/24LC512/24FC512, is right you point there are 64KB (512 Kbit), but every one, 64kb x 8 = 512Kb ( or best 524288 bytes ), then adress you must enter is 0 to 0x07FFF, and not 0 to 0xFFFF as you say, when you use this driver of course.
treitmey
PostPosted: Tue Apr 03, 2007 8:07 am     Reply with quote
According to spec sheet section 5.1 there are 19 bits of address A0->A15 and
chip select bit A0,A1,A2.
I wrote a simular driver for a FRAM FM24C256
http://www.ccsinfo.com/forum/viewtopic.php?t=24099
But in my driver I use a multi-read to speed things up. And in that
multi read my driver can go accross chip boundries.
Have you thought about that?
Here is your spec sheet.
http://ww1.microchip.com/downloads/en/DeviceDoc/21754G.pdf
see page 8 5.1 Contiguous Addressing Across Multiple Devices
and page 9 6.2 Page Write ((what i call multiwrite)) up to 127 more writes.
and 8.3 Sequential Read.
